I am a green horn in the modding department myself , still learning by the day and trial and error many times.
If it was not for the help and knowledge Dale has given me all along and TomE in the beginning , I would still be scratching my head and wondering what to doā¦ā¦.lol
Thanks for the info, knew about overdriving single die but thought maybe the MTG2 was different and reached its max point around the max spec.
Got confused because Iāve read where you canāt use a FET driver the 2nd gen multi-die XHP50.2 and XHP70.2 but I think thatās because theyāre low VF, but I should have realized MTG2 wasnāt though since my EagleTac MX25L3 MT-G2 is rated at 2750lm (2375 ANSI) which is already above Cree max spec. Not sure how much current itās pushing.
Iām wondering what the lumen output would be over-driving an MTG2 at 4.9A (w/stock driver in the TC20).
The MT G2 would be more under driven at 4.9 amps I think , you would have to get into the 12 or more amps range to really start driving the MT G2 hard.
As far as the XHP 50.2 or 70.2 you need 6 volts for them so the āstandardā FET wouldnāt work if you are looking at the 3 volt FET drivers.
There are a good many Buck and Boost drivers though that will drive the larger emitters much harder than the recommended specs say from Cree.
EDIT: you can actually get the FET with the 6 Volt setup and use them just fine in the lights with the XHP 50.2 and 70.2.
If the forward voltage is too high as it is in some emitters (like the XP-L2 I know for sure) then using smaller gauge wires and limiting the current flow can be done and still stay within the āsafeā zone.
The MT G2 I have not messed with but I think it would be the same for it.
The MT-G2 is in a sweet spot between 7A and 9A, peaks at around 12A but can take up to around 16A. Max output is around 4300 lumens or so. Itās a huge fat die, color in the output is a favorite of mine, itās not a thrower except by sheer force, much like the 70, but the 70.2 can certainly make more lumens and throw further as a smaller die (quad die of course, the MT-G2 is considered an array with 72 dies).
Last time I was counting I had some 11 lights with the MT-G2, not sure what I have now. The thing to look at is balance, output for the amperage consumed and a blend of performance vs heat, as well as color of the light to meet preference. So itās a mixed bag of goods, very seldom is sheer output or sheer throw the be all end all.
Oh Thanks a lotā¦ one of those āmust havesā is it? I didnāt order it yesterday, man I have so many lights and have spent so much money lately. Got my hospital bill paid off from the surgery in June and feel good about that, but wow does it ever put a dent in the old thin billfold!
Haha, yeah. The lights sitting next to me getting charged, itās plugged into the 3.0 USB port on my desktop, still in the red. I donāt think it will charge very fast. At least not fast enough. Iām being lazy. Both my Opus chargers are full of 18650ās that arrived from Llion Wholesale today. I have an Xtac VC4 not doing a thing. I āshouldā plug it in huh? LOL! This TC20 is just the right size, not too long, not too fat, obviously at 3800 lumen I assume it will put out a NICE amount of throw and spill. And itās a Thrunite, itās got some tooth to the knurling! That is a HUGE plus with me as a feature because my hands are always on the slick/dry side. Edit: Oh, my 6000 lumen Nitecore (edit) TC28 TM28 :person_facepalming: arrived too. The batts are on the charger :+1:
I hate to add thisā¦ (just buy one when you can :money_mouth_face: )
ā¦Size-wise, I canāt think of a better host for single emitter / single cell 26650. And I know that for you, in the end, itās just a host :smiling_imp:
TC28?? Thought this was a joke, then I realized your typoā¦.T M 28
Nice light!- BlackShadow Terminator on Steroids! It should have some good throw, needs a handle thoughā¦ I donāt see a tripod mounting hole on the side where you could adapt one, or am I missing it?
EDIT: I see now NHM10 handle fits: (and comes free with it?)
Me too. I also have olight r50 xhp70 as wellā¦ this tc20 is very small and brightā¦ what i like about this light is user interface and driverā¦ thrunite driver are bulletproof.
No handle, no batteries. Just the charger. Compared to my TM26GT, this thing is bright I did a comparison ceiling bounce, oh man. Data states 45min on turbo. It gets warm. It was not a free item, but I seen the handle for them. And it does have a tripod mounting hole. :+1:
By the way, (I may have said this already) this Thrunite TC20CW really impresses the heck out of me. Itās just perfect in every way I need it to be. I highly recommend it if you thought about getting one.
This has to tell you something positive, I just bought a 2nd one.
EDIT, a pocket clip would have been a nice addition to the TC20!!!
