Thrunite TC20 - XHP70 - 3800lm
448 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 month 1 week ago
The XHP-70.2 is a 6V emitter. It has 4 dies wired 2S2P and is typically set up on a 6V board but there are 12V boards that run 4S to the 4 dies. It would be prudent, of course, to check voltage at the emitter to ensure it is indeed set up as a 6V system, which I’m sure it is because robo measured 4.9A at the emitter which would be quite high if it was 12V.
The MT-G2 is a 6V emitter and like the XHP-70/70.2 it can be overdriven substantially over the Cree datasheet specs. Substantially! I’ve run the fat MT-G2 at over 16A, the 70.2 at well over 18A. Am quite certain the Thrunite isn’t approaching anywhere near these overdriven levels.
The larger MT-G2 would indeed lose lumens at the same current draw as the original 70.2, I would be willing to lose lumens for the tint of the larger emitter. Not worried about this one being for throw, have plenty of other lights that fill that niche… Wink
Edit: Nice job by the way robo! Very clean slice and dice! Wink
beam0
beam0's picture
Thanks for the info, that’s awesome and good to know the MTG can handle such high current, I want to use it in a couple of lights at some point. I’ve got the EagleTac MX25L3 with MT-G2 P0 EasyWhite (5000K) It has a real nice beam.
So I take it the MTG’s output doesn’t increase if driven at over the 3A datasheet spec? (I guess that’s what is meant by “Max Light Output”)
The one I’m looking at for the lights is MT-G2 Q0 (5000K) it seems to be the one that’s available everywhere, not sure the difference of P0 vs Q0 but I think P0 is only CRI 70, maybe Q0 is CRI 80-90?
There’s no mention of Q0 that I can see on any of the Cree MT-G2 data sheets, this was also mentioned on a thread here back in 2014.
robo819
robo819's picture
Last seen: 10 hours 7 min ago
beam0 ,,,,,,,,,
The Cree data sheet is showing what they rate the emitters output at the given amperage and is the Cree recommended maximum.
As with any of the emitters that we over drive , From the MT G2 down to the smaller emitters , they all will gain output as the current increases , up to the point that you over drive them too much and then they simply will over heat and burn out.
A good example would be the XP-L HI which has become a favorite for modders. Cree list the max current at 3 amps with a maximum light output of 1095 lumens.
The XP-L HI is overdriven easily up to 7 amps and beyond and when it is driven at 6.5 to 7 amps the output (depending on light , reflector size etc.) will also increase from the listed 1095 lumens to easily 1450 to 1600 lumens. I have modded a good many lights myself with these emitters and see numbers consistently go over the 1500 lumen mark when driven double or more the listed amperage.
There is of course a point when you will get all the lumens you can and then more current , if the emitter handles it, will simply cause even more heat than what is already caused by over driving the emitter , with no more lumen gain.
Of course you will have a lot more heat to go along with the increased current and I am pretty sure a shorter life span of the emitter , although I am not too sure of how much shorter life span , as I have yet to have a properly over driven emitter burn out , with some of them 2 and 3 years old.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
ARsee
ARsee's picture
I wish I could absorb the knowledge all you experienced modders have. The more I read, the more CooKoo I get. LOL!
robo819
robo819's picture
I am a green horn in the modding department myself , still learning by the day and trial and error many times.
If it was not for the help and knowledge Dale has given me all along and TomE in the beginning , I would still be scratching my head and wondering what to do…….lol
beam0
beam0's picture
robo819 wrote:
beam0 ,,,,,,,,,
Thanks for the info, knew about overdriving single die but thought maybe the MTG2 was different and reached its max point around the max spec.
Got confused because I’ve read where you can’t use a FET driver the 2nd gen multi-die XHP50.2 and XHP70.2 but I think that’s because they’re low VF, but I should have realized MTG2 wasn’t though since my EagleTac MX25L3 MT-G2 is rated at 2750lm (2375 ANSI) which is already above Cree max spec. Not sure how much current it’s pushing.
I’m wondering what the lumen output would be over-driving an MTG2 at 4.9A (w/stock driver in the TC20).
robo819
robo819's picture
The MT G2 would be more under driven at 4.9 amps I think , you would have to get into the 12 or more amps range to really start driving the MT G2 hard.
As far as the XHP 50.2 or 70.2 you need 6 volts for them so the “standard” FET wouldn’t work if you are looking at the 3 volt FET drivers.
There are a good many Buck and Boost drivers though that will drive the larger emitters much harder than the recommended specs say from Cree.
EDIT: you can actually get the FET with the 6 Volt setup and use them just fine in the lights with the XHP 50.2 and 70.2.
If the forward voltage is too high as it is in some emitters (like the XP-L2 I know for sure) then using smaller gauge wires and limiting the current flow can be done and still stay within the “safe” zone.
The MT G2 I have not messed with but I think it would be the same for it.
DB Custom
DB Custom's picture
The MT-G2 is in a sweet spot between 7A and 9A, peaks at around 12A but can take up to around 16A. Max output is around 4300 lumens or so. It’s a huge fat die, color in the output is a favorite of mine, it’s not a thrower except by sheer force, much like the 70, but the 70.2 can certainly make more lumens and throw further as a smaller die (quad die of course, the MT-G2 is considered an array with 72 dies).
Last time I was counting I had some 11 lights with the MT-G2, not sure what I have now. The thing to look at is balance, output for the amperage consumed and a blend of performance vs heat, as well as color of the light to meet preference. So it’s a mixed bag of goods, very seldom is sheer output or sheer throw the be all end all.
ARsee
ARsee's picture
My TC20CW arrived. The battery is on the charger. Thumbs Up
I like it and I haven’t put juice to it yet!!
DB Custom
DB Custom's picture
Oh Thanks a lot… one of those “must haves” is it? I didn’t order it yesterday, man I have so many lights and have spent so much money lately. Got my hospital bill paid off from the surgery in June and feel good about that, but wow does it ever put a dent in the old thin billfold!
ARsee
ARsee's picture
Haha, yeah. The lights sitting next to me getting charged, it’s plugged into the 3.0 USB port on my desktop, still in the red. I don’t think it will charge very fast. At least not fast enough. I’m being lazy. Both my Opus chargers are full of 18650’s that arrived from Llion Wholesale today. I have an Xtac VC4 not doing a thing. I “should” plug it in huh? LOL! This TC20 is just the right size, not too long, not too fat, obviously at 3800 lumen I assume it will put out a NICE amount of throw and spill. And it’s a Thrunite, it’s got some tooth to the knurling! That is a HUGE plus with me as a feature because my hands are always on the slick/dry side. Edit: Oh, my 6000 lumen Nitecore (edit) TC28 TM28 Facepalm arrived too. The batts are on the charger Thumbs Up
Franz
Last seen: 6 months 3 days ago
Ow God I’ve tried to resist and seeing this thread was enough for me…….
I did try to order in hkequipment and it is out of stock……. DANM!
beam0
beam0's picture
Thanks, a lot of good info here.
beam0
beam0's picture
I did try to order in hkequipment and it is out of stock……. DANM! !https://www.worldofugly.de/ugly/448.gif!
If I had to get rid of all my lights and keep only two… TC20 would be one of the two. Love
DB Custom
DB Custom's picture
Y’all aren’t helping, I had it in the cart and was in PayPal… AGAIN… and remembered I shouldn’t, closed it out… AGAIN! Silly
Franz
In the next attempt you will buy…. certainly
beam0
beam0's picture
I hate to add this… (just buy one when you can Cash )
…Size-wise, I can’t think of a better host for single emitter / single cell 26650. And I know that for you, in the end, it’s just a host Evil
beam0
beam0's picture
ARsee wrote:
.Edit: Oh, my 6000 lumen Nitecore TC28 Facepalm arrived too. The batts are on the charger Thumbs Up
TC28?? Thought this was a joke, then I realized your typo….T M 28
Nice light!- BlackShadow Terminator on Steroids! It should have some good throw, needs a handle though… I don’t see a tripod mounting hole on the side where you could adapt one, or am I missing it?
EDIT: I see now NHM10 handle fits: (and comes free with it?)
Newlumen
Newlumen's picture
Me too. I also have olight r50 xhp70 as well.. this tc20 is very small and bright.. what i like about this light is user interface and driver.. thrunite driver are bulletproof.
ARsee
ARsee's picture
OOPS, FIXED Thumbs Up
.Nice light!- BlackShadow Terminator on Steroids! It should have some good throw, needs a handle though… I don’t see a tripod mounting hole on the side where you could adapt one, or am I missing it?
No handle, no batteries. Just the charger. Compared to my TM26GT, this thing is bright I did a comparison ceiling bounce, oh man. Data states 45min on turbo. It gets warm. It was not a free item, but I seen the handle for them. And it does have a tripod mounting hole. Thumbs Up
By the way, (I may have said this already) this Thrunite TC20CW really impresses the heck out of me. It’s just perfect in every way I need it to be. I highly recommend it if you thought about getting one.
This has to tell you something positive, I just bought a 2nd one.
EDIT, a pocket clip would have been a nice addition to the TC20!!!
DB Custom
DB Custom's picture
Not sure where you got that about today being the last day, the email they sent me says valid through April 15.
ARsee
ARsee's picture
I won’t say that I’m not confusing it with another offer, I never got the email you mention. I will edit my above!!
charles lin
charles lin's picture
Last seen: 4 weeks 1 day ago
TC20 is my first purchase of 2018 & it’s worth every penny! I like it a lot.
Size comparison:
Blf Q8/ Nitecore EC4SW/ HaikeLite SC02/ Olight R50vn/ Thrunite TC20/ DQG Tiny 26650 3th V2
Tint comparison: WB set 5000k
Blf Q8( xp-l 4500k)/ Nitecore EC4SW/ HaikeLite SC02/ Olight R50vn(dedome XHP-50)/ Thrunite TC20/ DQG Tiny 26650 3th V2(XP-G2 NW)
beam0
beam0's picture
Size comparison:
Great post, nice lights!
I like the Haikelite, how did you get the in the tan color? Did it came that way?
Are those discontinued? It looks like no one has them, Gearbest has an Arrival Notice for the “White” color. (I wonder if it’s really white?)
SKV89
Last seen: 6 hours 48 min ago
Thanks for the tint comparison. Would you say the tint is slightly on the green side?
BLightSam
Last seen: 1 year 9 months ago
Solely based on the observation that TC20 is smaller than even X6, TC20 should get piping hot on Turbo. Isn’t this the case?
charles lin
TC20 NW has very nice cream white hotspot & yellowish corona in close distance. Just like all other Cree XHP70.2 LEDs. It’s just the nature of new full covered phosphor LED, no big deal! I dislike hint of green tint from the dedome/shave dome LED more!
No, it is white color not Tan color. The picture may catch the orange light from my Radiant Heater.
Haikelite “white” color is a similar color of TC20’s switch.
ARsee
ARsee's picture
komeko
komeko's picture
Oh, crap, you have four lights that I want to buy (SC-02, TC-20, DQG and Q8). I love NW around 5000K and the least discoloration. Tell me which of the flashlights are you most happy with? I am asking about color, size, modes, etc. I care about a big leak.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
robo819
robo819's picture
charles lin wrote: TC20 NW has very nice cream white hotspot & yellowish corona in close distance. Just like all other Cree XHP70.2 LEDs. It’s just the nature of new full covered phosphor LED, no big deal! I dislike hint of green tint from the dedome/shave dome LED more!
charles………
I dont know if you saw my post HERE but if you get a good slice on the emitter first , then cut straight down right at the edges of the die itself very carefully and get all that other phospor off , then the beam will actually have less greenish cast in it and tighten up some also.
Getting that layer of phosphor off around the die itself is key to getting rid of what I call the “Olive” cast around the main hotspot.
Note this is based on the CW emitter……..the NW emitter would probably get way too warm or yellow if the slice and dice method was used.
