13576 posts / 0 new
808Hi
Last seen: 10 min 29 sec ago
I’ll take 4 lanterns.
jmike
jmike wrote:
My first group buy purchase, so hope I’m following protocol here…
1 please!
Oops, sorry for the double-post, just want the one, please.
Way to make a first (and second, I guess) impression….
—jmike
jkbam
Put me down for 1 please.
Cheers
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 14 hours ago
KawiBoy1428 wrote:
How about some Host’s to purchase now, while this goes on and on and on…. please! Innocent
The host design isn’t finalized, and really the only pieces which could be easily swapped are the MCPCB and optics. A mod host would be a complete light minus those two parts. The driver is not swappable without making your own layout for this specific host.
Firelight2 wrote:
I vote for XPL HI 5D
The emitter poll hasn’t started. Smile
dbmeed wrote:
how difficult would it be to make it ramp down smoothly rather than distinct step downs when it starts to get too hot?
That’s already done. Adjustments shouldn’t be visible to humans.
spaceminions wrote:
but also ramp back up
… and that has been working for a long time. Smile
After it throttles itself down, hold a block of ice against the light and it should ramp up pretty quickly… much faster than a D4, since the D4 had a throttle-up speed limit of “turtle” to prevent oscillations.
joechina wrote:
If you flash Andúril on the Q8 it should also work. But you need to get the regulation right for every type of lamp.
I’ve been trying to make it “just work” on a wide variety of hosts, from the tiny hot D4-219c to the large and moderate 500-lumen BLF Lantern. So far it’s working on most, but still doesn’t like the D4-219c on full turbo yet. That light is pretty much the worst case, so once that is working it should be fine everywhere else too.
It’s fine on FW3A XP-G2 at 3A, but I doubt it’ll adjust fast enough on FW3A 219c at full turbo. So it needs more tweaking.
higbvuyb
Last seen: 3 months 3 days ago
Put me down for 1, please.
joechina
Last seen: 2 days 1 hour ago
I am not sure if I want a poll about the emitters.
I think it would be better if the team members get the second prototype and they swap in the first prototype different LEDs and optics. (XPG2, XPG3, frosted, clear, dif. angles)
Then compare the different lamps side by side. And then the team should choose.
It would be nice if the team shoot for the nicest beam and not for the highest lumen.
(And please no green in it)
Polls deliver normally an average result and we have to judge on pictures and the lamp not in the hand.
joechina
Would a silicon heat transfer pad help for the 219C to get the heat quicker to the µC?
Would a turbo with only 2.5A help?
zak.wilson
Last seen: 12 hours 30 min ago
With “turbo” being a FET, it isn’t possible to limit the current to a specific amount. The max-regulated mode should be 3A.
Ceilingbounce – flashlight testing and runtime graphs for Android
spaceminions
Well yeah, that’s why I said
spaceminions wrote:
… will not only ramp down smoother …, but also ramp back up “just as well” if you cool it off …
The point is that the q8 doesn’t, and the d4 does it very weakly, but this one should be somewhat faster than the turning of the seasons and yet smooth. Silly It will be ‘cool’ to have that updated behavior. Of course, for cool factor, optical configuration (which should absolutely be called photonic programming or something equally fun) is definitely cool.
Card Carrying CRI baby https://b.thumbs.redditmedia.com/laMC7BGhREfYTRQjYe2I5FMjTF1IjrmM6bPLK9SKEXU.png
WaylonJennings
I agree. I trust the team with lights in hand will make a better decision than the rest of us looking at beam shots. In addition, I think that a team working hard to make a nice, efficient light is likely to be mindful of tint and not just go for max lumens. Wink
zak.wilson
A lot of us here have built FET triples before. It’s not necessary to have this specific host in hand to have previous experience with the emitters and optics in question. People should keep in mind this will heat up faster than a Convoy host with a big spacer though.
ToyKeeper
ToyKeeper's picture
Exactly. The emitters and optics are pretty standard and lots of people have experience with them. The main differences here are:
  • The edges of the optic aren’t covered by the bezel.
  • The host has less mass than most triples.
  • The host’s double-tube design may reduce heat-shedding capacity a little.
So, normal BLF-triple performance and output traits except it needs extra care for thermal behavior.
I don’t personally care much how bright turbo is, because even XP-G2 at ~2250 lm is plenty for my purposes. Really, I could be mostly happy with 1×7135 and only 150 lm. I care more about the beam and tint and heat. Plus, of course, non-performance-related traits like host design and interface.
On mine, I’ve left the ceiling at the maximum regulated level of ~3A, with FET modes only available via turbo. This is the default configuration, but it can be changed with a few clicks.
adrn77
Last seen: 1 month 1 week ago
interested
cabfrank
Last seen: 15 hours 11 min ago
TK, you rock, but I’d guess almost everyone else does care how bright it is.
zak.wilson
I mostly don’t care about the peak output. 3500 lumens for 12 seconds is only a marginally better party trick than 2900 lumens for 11 seconds. I use my lights to see things, and given that, CRI, tint near the blackbody line and tint evenness across the beam are generally above output on my list of priorities.
Heat matters a bit, but I expect the differences to be moderate at max-regulated and only really significant on the FET channel.
I used to care about output more, but as I’ve collected more lights, I haven’t found big output in small lights all that useful. When I pick a pocketable 1×18650 light to bring with me, I don’t find myself thinking “this one has a higher max setting, so I’ll bring it”. If I do expect to be using a lot of light, I bring a larger light that uses multiple 18650s.
spaceminions
Peak doesn’t matter (to me) much like zak said, and since these ramp in brightness, you can exchange heat for brightness or vice versa easily. So I don’t really mind too much if it’s not as bright as it could be; it’s a triple. It’s not going to be as good as the d4, but it will still be very bright. That’s all I really need to know. This is going to be a very nice looking little light with a nice price tag; why make the light more expensive or let it fall down on its apparent quality as soon as you turn it on? You won’t remember the difference in brightness on a light you’re not using at one set level, but you can see the difference in the quality of the beam at every setting.
marcoaml78
Last seen: 7 months 2 weeks ago
interested
All-purpose lights:
Reylight Lan TI, Maratac TLL, BLF Q8, Emisar D4, Nitecore TINI
Chargers:
Nitecore SC4 UM10
Bike lights:
Niterider Lumina 700, Niterider Pro Enduro 770
Mountain biker, hiker
DB Custom
DB Custom's picture
Last seen: 5 hours 18 min ago
I know it’ll be a shocker but I don’t care about max output in this light either and hope for the greater good the package focus’s on tint over lumens with weight given to thermal maintenance. Quality here, as it’s an elegant light with elegant UI.
cabfrank
Promise you won’t make it brighter when you get it then. Big Smile
Pulsar
Pulsar's picture
Last seen: 2 months 5 hours ago
I bet he can’t make that promise haha
pinkpanda3310
pinkpanda3310's picture
Last seen: 4 hours 54 min ago
Max output is not much an issue for me as well, fully regulated is probably a better option for a light like this. In the same respect I don’t need a technical UI but none of which will turn me off. I don’t know if the optics have been talked about much but my preference for practical little lights are to be floody. That’d make an ace edc Davie
DB Custom
DB Custom's picture
What I can promise is that if they get the emitter right and I find it pleasing I won’t do anything to it at all as far as modification goes. Will just use it. If the emitter choice leaves something to be desired then I will change the emitters, but this only to give me a better color and/or beam profile.
This is, for all practical purposes, a custom flashlight. As such, I will honor it’s inventor…. Wink (which is why I cast a vote to keep it styled as originally intended)
Cobra502
Am I on the list if not add me in for one
shirnask
shirnask's picture
Last seen: 1 hour 3 min ago
Yes, exactly this
skinny_tie
skinny_tie's picture
Last seen: 10 hours 7 min ago
I agree with everyone who has expressed a preference for quality of light and overall balance over maximum output. I also think the default configuration with the ramp ceiling set at the max regulateded level and FET mode for turbo sounds great.
I’m really excited about this light and the direcition it’s heading. It was the look of Fritz15’s original design that hooked me, but I don’t mind the design changes at all.
At this point I’m equally excited about Andúril and the prospect of having a FW3A, a Q8, and a a fleet of Emisars (which I don’t yet own) all running the same great firmware.
Crimsonnj
Last seen: 2 weeks 1 day ago
Interested in one
Pulsar
Pulsar's picture
Yes, exactly this
Yup
Light Years
Light Years's picture
Last seen: 19 hours 29 min ago
Add me to the list please
JasonWW
JasonWW's picture
Last seen: 15 min 41 sec ago
skinny_tie wrote:
At this point I’m equally excited about Andúril and the prospect of having a FW3A, a Q8, and a fleet of Emisars (which I don’t yet own) all running the same great firmware.
All run different firmware. All are ramping, though.
Click this to go to signature links.
zak.wilson
They can all run the same firmware if you have an AVR programmer.
