13.5mm driver at KD
6 posts / 0 new
brted
brted's picture
Last seen: 1 month 1 hour ago
13.5mm driver at KD
Saw this under new items at KD today. You have to buy five at a time, but it looks like it could be a good option for people with AA lights that have died and you can't use a 17mm board.
http://www.kaidomain.com/ProductDetails.aspx?ProductID=11063
fran82
Last seen: 5 hours 37 min ago
Description says for AA/AAA. It is impossible to fit in an AAA because most AAA use 10mm ones.
Also it could arrive as a single unit not 5 pcs pack
However, good tip!
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
brted
brted's picture
KD does themselves no favors by providing so little information. It doesn't say what the 5 modes are or whether it can be used with lithium-ion cells. And, I agree that there are not many AAA lights that will be able to use this driver and only the pictures indicate you will actually get 5 pieces instead of 1.
phlowcus
Of course you get 5! KD may have rubbish descriptions etc. but when KD says "5pcs bla" it means they ship 5pcs.
Hrvoje
Last seen: 1 day 1 hour ago
Could be good to upgrade Tank 007 E07. Inside diameter of the led/driver assembly is 13.05 mm, so with a little bit of sanding this one could fit. Ordered anyway.
Hrvoje
old4570
Last seen: 2 months 6 days ago
5 modes ,  ok , thats nice ...   Wonder what size driver the Akoray 103 has ?
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
