For me the issue is that this is not a light that you can put down and leave on. I’m pretty sure I torched my batteries just from testing this sucker. I honestly think this thing is dangerous and even a potential fire hazard.
This is definitely an enthusiast flashlight and is not meant to be left on at high modes unattended. As an enthusiast, I prefer not having thermal protection than having very fast step downs that makes the turbo mode nearly useless, which is sadly the case with the majority of high lumen flashlights. However, a user programmable thermal protection like the Emisar would be nice though.
well yes but it is a very dumb idea to power this kind of light on and leave it unattended on turbo mode, its not meant for that stuff really… The manual even says the light gets very hot quickly.
Wellp, it’s like a car with a 500hp engine. You can get nice acceleration right off the line, but you can also get stoopit in a hurry and go sliding off a curve into a ditch.
Thermal stepdown should be a true thermal stepdown, not just via a timer, even user-selectable. Think unattended in a room vs walking outside in subzero temps.
Ideally, you want a temp sensor right on the mcpcb, right next to the LED. Then sense the actual temperature and use a decent PID algorithm to step down to a max temp. You don’t want a sudden drop in brightness, nor any oscillation between bright and dim, but set it like a hotplate or soldering-iron.
Unfortunately, that requires a special mcpcb, special driver, special UI/code, etc., so it’s only for a truly custom design.
And yeah, people endlessly grexing about stepdown being too much, too soon, a dealbreaker, “useless”, etc., I wouldn’t want the headaches associated with designing it in except as a failsafe to keep the light/batteries from going supernova.
I get it and I’m an enthusiest and I know how to handle a light like this. But when it’s sold as having thermal regulation and it in fact gets hot enough to cause burns then it’s a problem.
It’s more like a car with a 500 horsepower engine but no cooling system. Sure you can take it out for short runs but if you drive it more than a few minutes it will burn itself up.
I don’t get it. It’s advertised as having thermal regulation, but doesn’t have it? And they were going to ‘sneak’ that by? Maybe it has it but it’s just not working right?
I get that, and a conflict between safety spex and actual operation is indeed a problem.
But most lights are handheld, and if you feel your hand starting to cook, you lower the power, so even a light with no/defective thermal regulation could still be “safe”.
Hell, I left my S2+ tailstanding to light a room via ceiling bounce, and couldn’t even grab it long enough to turn it off like 5min later. Dumb move on my part.
Make it a designed-in air-cooled engine and we can agree. At least with a temp gauge, you can see it’s cooking itself to death and back off… or keep driving it hard and watch it melt internally.
I had a waterpump blow its seal and start leaking coolant. No gauge in the car, just the idiot-light. Feathered the throttle the rest of the way to work. Air-cooled it enough to get the light off, only barely starting to glow on uphill runs.
Afternoon, topped it off with water (held), and made the whole trip home the same way. Idiot-light never even went on.
Point being, even a completely unregulated light can still be used safely with a little care and common sense. If regulation is off or nonexistent, yeah, that’s a problem if it’s specced to have it and be operational, but it still doesn’t mean it’s a fire-hazard unless it’s misused/abused.
Space-heaters can be perfectly safe… just don’t put it next to nice flammable curtains.
Where did you see that it was advertised as having thermal regulation? Can you show me the post? From my memory, it hasn’t ever been advertised that way on this thread.
I’ve always been wondering whether this has temperature regulation and low voltage protection throughout the group buy. Seems we’ve confirmed it doesn’t have temperature regulation but I still want to know if it has low voltage protection. Not having thermal protection to me is kind of a plus since I use the flashlight in my hand for practical purposes. But I do hope it has low voltage protection although I never really run my flashlights until its dead though.
Umm, I don’t know that, I was just looking at post 1342 …… and assumed. Perhaps I’m in error. My bad if so.
(wait, there it is on that diagram. Internal 55 degrees thermal control?)
Just wanted to share something interesting. I just received my Pflexpro S2+ with triple Nichia NVSL219BT 219b 4000k emitters and OMG the tint is BEAUTIFUL! Much better than the many 219c 4000k and 5000k and even 219b flashlights that I have. Super good buy if you are interested in a well-built EDC with good customizable UI. https://www.pflexpro.com/Nichia-219-…b-3up-3.8a.htm
Also I compared this light to the Haikelite MT09R XHP70.2 80+ CRI 4000k and surprisingly the tint was pretty much indistinguishable. That means if anyone wants to match the legendary perfect NVSL219BT tint in a high powered flashlight, swapping in the XHP70.2 4000k 80+CRI will do the job. The 4000k version of the MT09R is no longer available after the GB. So glad I got the 4000k version.
Aso Terry, I would like to request that Haikelite consider offering the XHP70.2 80+ CRI 4000k emitter as a standard option in future Haikelite flashlights and not just as a GB special. Having a high power lumen monster with the renowned Nichia NVSL219BT tint is just one of a kind awesome.
The lack of thermal protection is just a typical breakdown in manufacturing communication, I would guess. The light was planned to have it, but nobody told the programmer. Drivers done and shipping, programmer probably discovers the mistake, but decides to keep it quiet and play ignorant. Nobody tells the marketing or distribution people, light ships and the issue is not discovered until customers burn themselves an report it.
Welcome to the difficulties of managing a Chinese manufacturing process.
