Charles,
Could you elaborate a bit on pros/cons of TC20 vs DQG? Iām attracted to DQG becuase it is substantially smaller - that makes a large difference for me as to whether light actually gets used or remains a shelf queen. Everything else about the TC20 seems better to me, wondering if itās worth it for extra size.
Price:
DQG won! no matter with or without coupon code for both lights.
Machining & built quality:
TC20 won! DQG has no comparison.
Size:
DQG is much smaller, But TC20 has built-in charger, very Convenience in case of emergencies, camping & travel. All you need is a power bank.
Beam & tint:
I like DQG NW V2 better, Tint is cream white 5000k similar to my Emisar D4 XP-G2 S4 3D. I also like big even hotspot from TIR.
TC20 NW has good tint & beam ,but you can clear notice tint shift in close distance. However, TC20 is much brighter.
Reliability:
All my Thrunite flashlight refuses to die no matter how I abuse them. One of my DQG broken because the switch failed.
Others:
DQG has a very small switch, hard to find in the dark, It also feels kinda weak.
TC20 has a soft clicky feel switch with battery indicator built-in.
I love both lights! If I can only pick oneā¦ā¦ā¦. Thrunite TC20!
Iāve always wanted that DQG 26650, glad I didnāt get it yet since now itās on itās 3rd version.
Wondering why Charles said the Machining/Build quality has no comparison? Iāve read the Machining and Annodizing was good, (Itās good on my DQG 18650 Tiny 1st) And the knurling on 26650 Tint III it looks great. Unless heās just referring to the switch. Not sure if thereās been switch issues on the 26650 v3 like there was on the most recent 18650 versions.
Donāt see really how we can compare a 7x TIR LED to a single reflectored LED, isnāt the DQG more of a flooder? Yeah theyāre both compact, high output 26650, but birds of a different feather I thought. Got to have both.
If you use your finger across DQG body up & down, you will feel many sharp edges around all over the body (stainless bezel, heat sink fins & lanyard hole). All my acebeam/Thrunite/Olight/Fenix have machining Chamfer for every single edge. So, you wonāt fell any sharp edge in your hand.
I have two DQG 26650, one doesnāt pass my waterproof test & some minor Scratches on TIR lens. Another one received with broken O-ring & did not incoulde any spare o-ring. I never have such problems with Thrunite flashlights.
I know Iām hell bent to find aggressive knurling lately!
The DQG is a nice compact bright light, but I wouldnāt be considering it if it didnāt have that awesome DQG knurling.
Just ordered a Wowtac A3S zoomie, looks like the same knurling as Thrunite. Hope so.
I only posted about it here for the knurling discussion Yes a different class in output and style, but as far as build quality/construction I think Wowtac may be pretty close if not equal to Thrunite? The switch appears to be the same too. Just hoping for the same knurling as TC20 has, and it does appear to be.
While the Wowtac (Atactical) lights I have , which is almost all of them , are very good quality and designed much like the Thrunite lights in the same class and type , Thrunite does still have an edge on the knurling design.
Wowtac does receive technical support from Thrunite and follows many of their design features , but the knurling although it is good on the Wowtac , still isnāt quite as good , or as aggressive as Thrunite.
Although similar the Thrunite knurling is a slightly larger pattern and slightly more raised.
Below picture (Left to Right) is the Thrunite TC12 V2 ā¦.the Wowtac A1S V2ā¦.and the Wowtac A3S
Well gosh robo, why didnāt you go ahead and use the TC20 in this comparison?
Yes, knurling class is what I was referring too. I too have the A3 (from robo) and while the knurling is good on it itās not to the level of the DQG Tiny nor is the anodizing Type III in my opinion.
