Also someone mentioned frosted TIR, this second image is sorta what you will get if you diffuse it:
Almost no hotspot and very nice spill, great for close range use.
How about a really tiny lamp, using one AA cell or a 14500.
Similar to a UTorch 01, but with a better interface, and maybe a little more power…?
I’d like a small, elegant, titanium light. BLF style.
Seeing how Astrolux sells their TI3A for $16 I can’t help but think that a much better BLF light has to be doable for $25 (preorder price). And I want one.
So:
I think that LED locator would be cheaper than tritium. And if connected to the driver it could act as an indicator as well. Or with RGB led the colour could be configurable to best suit the garment.
I’d like it the most with the switch in the tail, but I’m not sure if doing the FW3A thing is feasible in a titanium light (I guess with Al internal tubing - yes). It would make the light thicker though.
Thoughts?
I’d like another light of this style.
18650 with 16 Yuji VTC-5730 LEDs. No overcurrent to maintain CRI 9790, ~400 OTF lumens.
A double-tube 10440 light doesn’t make much sense because it would lose the advantage of being thin. It’s also difficult to fit a complicated driver into something that size. But perhaps a 16340 light could work? It seems like it’d be a lot easier, at least.
I still want a BLF version of the Olight S-Mini.
I also still want a small BLF 14500 light. Could be like a smaller FW3A, could be like the brass AA clicky.
16340 or 14500 would work great in a woman’s purse, but not so well in a jacket’s inner pocket….too thick.
But I wonder what is the factor limiting minimum tube thickness? Size of PCB contacts? Strength necessary when joining them into one?
I have been looking for a good quality mid-size thrower for a while now and I just thought of bringing it up here. What I have in mind is a 3 or 4 cell Q8 style battery tube with a 2.8 to 3” head. Throw in good heat management, an efficient driver and Narsil or other great UI and BLF would have a nice light that would fill a hole in my line-up.
How would that differ from the Q8?
Single reflector with a 35 HI or other throwy led. In my mind that was implied, but my mind is not always clear.
I’m sure there are lights like that already out there, they just need a driver swap. Maybe a Haikelite MT07S or Klarus G35 with one of Lexels drivers.
When his boost driver comes out you could build an even smaller thrower using a 26650. Like the Utorch uto2 which is very cheap.
Don’t wait for BLF to make it. Make it yourself! Lol
I have a MK35 that I might upgrade with a GT/Narsil driver and a 4000K or 4500K led swap. Wish me luck, I’m goin in! The 4000K in the GT has gotten me hooked. I just bought a MX30L4Cvn with XPL Hi 4000K which is now my favorite balanced light.
. GOOD LUCK!!! . :+1: .
Extremely compact 21700 flashlight powerbank.
Initial, somewhat incorrect sketch:
I drew it without glass protecting the lens. I’m not sure it that’s a great choice especially that bezel blocks some light, just like it is with S2+ triples.
And there is no place to put threads between head and body tube, so this is a unibody light with press-fit driver. Not sure if that’s feasible with USB and maybe a button on the other side. You can remove the driver by poking it from the optic side.
Why did I say “maybe a button on the other side”? Because I’m wondering if a button assembly plugged into USB slot wouldn’t be a good idea.
It seems that “extremely compact for its battery type” is a very common desire. In general, I’d like to see more lights which are barely bigger than the fuel tank.
Unusually, I’d like to suggest not a from-scratch project but a special edition of existing light.
DQG Spy Ti which has low-bin XP-G2 replaced with Samsung LH351D. Warm CRI90. That’s it.
Well, extra points for shortening it to 10150 or 10160.
ADDED:
Or AR coated lens.
Or glow o-ring.
OK. There are a few things that could be done better.
But nevertheless this is a good light that’s extremely close to being a great light.
I’ve had the concept in my head for a long time…I made some drawings before…but just couldn’t make it right.
Now I managed to put all the pieces together.
Welcome A7, a pocket hotrod.
Features:
Here’s the drawing, next to a rough outline of Emisar D4.
Inspirations (alphabetically):
DB Custom’s Titanium X6, DQG Tiny 18650, DQG Tiny 26650, Emisar D4, Led4Power’s works, Zebralights
Do you have a bigger picture to share? (pm?)
No, I don’t.
I draw stuff pixel by pixel in gimp. This technique limits me heavily, but that’s what I’m capable of.
If you need larger, simply zoom it.
Why not use something like sketchup or solidworks…
Sketchup doesn’t work on FreeBSD. I contemplated learning CAD before but never reached that point…
