Central hole is “only” to coamp PCB + Reflector together. The body/shelf diameter is much bigger.
I thought I can rotate LEDs around PCB center so I can fit both 4040 and 5050 on one PCB without interfering with screws, but I can't because screw cavities in reflector allow for only one position (45deg).
There is one solution - using flat countersunk screws for PCB clamping, is that ok?
That means pcb must have countersunk holes, but I think it's doable by factory.
Except that in all but the first 500 Q8’s the holes in the shelf do not have threads.
Edit: the first 500 may not have threads either but the screws were just forced in.
Edit2: can someone else help out further?, I’m rather sick atm, need stop doing things for a while.
Interest list updated. Current to here.
led4power, thank you for looking into this and hopefully taking it on!
firedome, how many boards are you interested in? You have a post at 60
and a post at 88 :
You are currently in the list for one.
For the first 500 flashlights, the Screws holds the MCPCB on the shelf/head of the Flashlight.
On all other Q8, the Screws go throu the shelf, the MCPCB and screw into the reflector.
I would say, do not care about the first 500 (I have two of them and one later Q8) and make 4 holes near the LED-Pads.
For the first 500 everyone have to find a solution, e.g. with countersink screws, or without screws (clamping all together with an adapter/old mcpcb over the centerscrew of the reflektor).
Yep, same thing I found when trying to keep the screw holes. That is why we decided it was best to just leave them out.
Sadly we never did find a good option for keeping the screw holes and the double footprints. The dual footprint doubles the market for the mcpcb’s so that was important.
The best option was to use a washer and a longer center screw to sandwich the reflector, mcpcb and shelf all together. This is ideal IMHO.
You could even sell the washer and longer screw with the mcpcb to make it super simple.
This is what I would do if I were you, I prefer the reflector provide the clamping force anyways, it is a more even pressure.
I was on the list for two boards, I’m still interested.
If both footprints are not on the same board, I would like 1 board for 4040 and 1 board for 5050.
Thanks djozz, but what is purpose of big central screw in this version? Two small screws clamp everything anyway?
Currently, I see 3 solutions to dual footprint-screws interference problem:
- Using only central screw and washer like TA said, problem is that it doesn't protect pcb from twisting,
- Making separate mosX pcbs for 4040 and 5050, but they are 1.55mm tall, would be that a problem?
- Making just 4040 Cu DTP version, but I'm not sure about percentage of people form list that want 4040 vs 5050?
Do XM-L size LEDs fit without reflector modifications?
Big screw clamps reflector to pcb from backside.
Reflector openings are 6.5mm (according to the drawings from CAD files that were shared by Miller).
That big screw does not much, except fixing the ledboard to the reflector, in the first run it probably helped fixing things in place during assembly to prevent shearing off leds. It is something that Thorfire came up with, it was not how I designed it in the first place and we just left it because we could not see harm. And now it comes handy to fix the whole thing with the washer if the small screw holes are left out. I think that will work fine without twisting becoming a problem.
The reflector base is a bit wider than the cavity in which the MCPCB sits. That cavity is 2.2mm deep, so the 2.0mm board is sunken in by .2 mm. The base of the center pieces is .5 mm, so you have .3 mm room to play with, a bit less because the reflector is clamping on the centerpieces, squeezing them slightly I guess. In any case, you will not get away with a 1.55mm MCPCB.
I guess no one has checked the fitment of XM-L leds before? I just did: by just a bit a XM-L does not fit the reflector holes. But the fix is easy if you have a reamer (a few dollars on Banggood gets you a reamer thst does this job fine).
This is the stock reflector opening that does not fit an XM-L2:
Some light reaming makes it look like this:
Now a standard XM-butterfly centerpiece fits and the reflector is XM-L2 ready.
Buck drivers ready
What is the size of central screw,and what washer dimension would be optimal?
If others don't have anything against, this could be solution, which means boards will not have 2 smaller screw holes.
No one has tried this solution yet, will do some fiddling and come back to this…
Ok, I hacked something together. I figured a washer would require making extra holes for the wires anyway, so I made it a piece of aluminium 35×10×3mm with a 4mm hole in the middle, well, not really in the middle, it was a quick hack :innocent:
The screw is M4, and from the back of the shelf to decently screwed in the hole in the reflector (there is a bit more than 3mm deep working threading in the reflector so you have some play) you need 16mm of threading (so the threaded part needs to be 16mm + the thickness of your washer/piece). In place it looks like this and I must say it works fine: after fixation like this, the closing of the bezel does not move anything anymore. But this was without thermal paste, that may slide a bit better. Still, I think it works.
Ok the white driver is for 4S only and one buck engine. The black driver is for 4S or 2S2P and 2 buck engines for more power.
For the Black one: Vcc and ground are the inputs to the driver. + and - is for connecting the batteries with 4S and for 2S2P its connected to Vcc and ground?
Whats the maximum current for one buck-engine? 8A?
4S is for original 3535 MCPCB with XHP35 and 2S2P is for 5050 MCPCB with XHP50, isn’t it?
Prices?
The only hard thing is to fix the tube on the head without rotating at the correct orientation to the driver and make a tailcap with carrousel-PCB
Do you have enough space over/between the inductors for a washer or reflector-holder, like djozz showed?
Yes, I think that the single mounting screw is the best idea. It is simple and works. There is no worry about the assembly spinning as the wires can spin freely in the center hole without binding.
Looking forward to this project coming to fruition. I’m planning on putting MZ 90CRI 3v 5700K leds in my Q8.
In most cases it is not real. Q8 threads are not synchronized with driver screw holes.
This decision is not safe. To make it more durable, you need to add extra pcb and fix it on the tube, and change driver pads to the design that allows rotation.
A driver with pads that allows rotation are a different driver design as shown.
I have 2 Skyray King with similar designs, as you can see here:
2. Version Adapterplatte für Flattop-Akkus 2015-04-29-4117
But with the design of lexel (and others of cause), we need a tailcap-pcb which allows rotation and the tube has to be fixed to the head at the correct orientation.
