I love to write my own firmwares and I specially love to squeeze as many features as possible in a single firmware (for instance different strobes, ramping and discrete modes, momentary or not momentary, colors, diagnostic output and much more). But even I - as the creator of the firmware - have to carry an instruction sheet with me since I can’t remember everything after some days of not accessing the configuration mode.
And from time to time I build lights for some narrow friends and - even if they admire the multiple capabilities - they mostly prefer a much simpler interface. So I’m probably going to add a lock mode to my full featured firmware: after configuring the UI to what the user wants a lock can be applied (and released ) by using a 3 (or more) digit password (typed in with multiple switch clicks). I’m using a password already to lock some security related configuration aspects (for instance temperature limits) so I know it’s doable.
Just out of curiosity - what’s the simple interface you have in your mind?
You definitely have a short in the black emitter wire or that same circuit on the driver.
It’s not the battery or the programming in the light. The side switch is functionin normally and doesn’t know there is a problem. So there is a short before the driver circuit.
You clearly have not met my wife.
She can take any flashlight, and immediately put it into some program state where it becomes unusable. The Q8 is no exception. I’ve even accidentally put it into some obscure mode a couple of times myself.
I can look up the Narsil cheat-sheet and do a factory reset easy enough. My wife would probably just throw the flashlight away.
The Q8 is a very flexible light, and I like it for that. But, I wouldn’t give one to someone that just wants a basic flashlight.
The Q8 was not designed with a ‘muggle mode’ set, like the BLF X5 and X6. In those lights it works simple and well and it is pretty hard to exit it. Fhe FW3A will probably again have a muggle mode set.
Off the top of my head; I believe I would be happy with just ramp on and off. Being able to stop and resume during ramping.
Maybe a direct on at last used intensity and a direct off.
A flashlight.
Maybe blink the green button if battery is running low.
Anything else left in there needs to be thoroughly protected from accidental activation.
All three uses resulted in the user getting a strobe going, and no idea how to stop it. The light is too bright to allow this to happen by accident when someone is handling the light. It can be harmful if someone is looking at it, or is pointed at a moving vehicle, or even just someone in a precarious position being strobed by accident. It hurts. The strobe has some utility for personal defense.
It depends if it was strobe.
If you are in RAMPING it is relatively hard to get there. A double click to turbo and then a double click to strobe.
If you’re in strobe wait a second, then you can turn it off.
If you are in MODES you can easily get in STROBES by holding the button. Again wait a second to turn off.
Or the blinks from the settings are mistaken as strobes.
You land in in the settings blink if you ramp for longer than 8 seconds.
If you then try to shut the lamp by one click, you land in MODES setting, Further clicks change the settings.
When the lamp calmed down and you try to ramp by a hold you are in MODES and you start STROBES.
So the beginner has a fucked up lamp which does alwasy STROBES instead of RAMPING
Solution:
do a factory reset from MODES
Precaution:
Tell the newbie don’t hold the button for 8 seconds. If it starts blinking don’t touch the button!
@Tom E
One thing to prevent this fail path in a future version could be to change the setting for MODES to two click and for RAMPING to one click.
But if the user clicks double it is the same.
It’s very easy to accidentally activate, and I did it several times before disabling it.
The way to get instant max is to double-click to turbo. My assumption to get out of turbo is another double-click. Bad assumption! After making that mistake a couple of times around my wife, I had to go to the doctor to get the Q8 removed from my posterior. It made me wish I made the mistake on a smaller light.
It’s important that people buy a light to fit their needs.
I’ve passed on buying many lights simply because they had a quirky UI.
Alternety, if you like the size, power, beam pattern, etc… of the Q8, but want a custom UI that is simpler to operate, you might consider talking to ToyKeeper about flashing a different UI to it. You could probably just send her the head of the light and it’s relatively easy for her to reflash it.
I’m sure ToyKeeper has some type of muggle mode UI that will fit your needs and can remove all the excess stuff you don’t need.
Possible choices are:
Anduril
RampingIOS (Emisar D4)
QLite Momentary
Moppydrv
Yes, it only took a few accidental activations before I followed the procedure to program out the strobes for good. Well, I think I had to do it a couple of times, because I had to factory-reset the light because I messed around with other settings.
Has anyone made step by step instructions how to disable strobe in ramping mode?, that would be great for newbie who just want that option disabled
Hold the button for 8 seconds….after that I´m confused
UPDATE
I think after many times I tried it works like this
Hold the button for 8 seconds….wait until it blinks first 2 and then 4 times then it´s on the blinky mode setting number 4 and then click one time to disable then wait many seconds and it should work or I just got lucky.
Same here shirnask…… :+1:
Young person to old, no one so far has had a problem. They were NOT seasoned ‘flashlight people’ either. My nephew’s, son of age 7; got it right away. And my neighbor of 79 had no problem either. I am an ‘older fart’ myself and it is a no brainer to me in ramping mode. ON…. RAMP UP & DOWN AT WILL…. OFF
Same here Glenn… Personally, I also am completely happy with the default factory stock RAMPING UI.
It is so simple in fact, I think Lumpy Rutherford could have understood it easily enough to have taught Theodore.
And like you, to this point; my Q8’s have worked flawlessly also. :+1:
They were/are well done lights at a fantastic price!!!
Yes, that is correct. The first 2 fast blinks are to just get your attention. It’s the slower blinks after those 2 that tell you what menu setting you are at. The 4th setting (in ramping mode) is for strobes/blinkies.
