What did you mod today?
Where did u get the stainless steel bezel?
It look nice
Please scroll up :slight_smile:
It’s the standard C8 SS bezel, filed down.
I did some brain surgery on my modded Tiara today. Some time ago, the switch bezel was a bit loose, and carefully tapping it down somehow resulted in the tiny SMD switch exploding into a bunch of little pieces. I set it aside until I was a bit more experienced at soldering, but ordered some replacement tactile switches in the mean time.
It’s a somewhat involved “mod” because the switch board isn’t really accessible without removing the front bezel and desoldering the three tiny control wires attached to the back. In my case, I had to melt the optic to make a channel to grab the bezel, but the approach would be different with a stock Tiara. After desoldering the leads, I used hot air to reflow the switch board and pick off the broken switch (extremely nerve wracking with those tiny components beside it), then added a replacement and put it all back together. It’s working perfectly now, and I’m pretty stoked I was able to complete the repair considering I’d never held a soldering iron before a few weeks ago :smiley:
Good work on the Tiara. Even Armytek can not prevent their lights from being modded :smiling_imp:
Nice bling on the C8 bezel Yokiami! And that sounds like a perfect focus for the XP-L Hi.
If you build it they will come.
Then they will disassemble it, chop it up, hack all the internals, reassemble it screaming in output! Because that’s how they roll at BLF. :smiley:
Must have been very difficult polishing that optic back up :smiley:
Well done :+1:
Both, might have to blow it out again using a compressor, maybe i can use the one that comes with my car, since i don’t own a spare tire anymore
I demolished a brand new Solarforce Z2 today, trying to get the bezel off by heat and force. The centerpiece around the has melted, the reflector started flaking bits off, the threads on the pill section were chipped open in multiple places, and the bezel will still not move.
Decided that it was a lousy host after all anyway.
I changed the LED of my faulty BLF GT and fitted a 2nd centering piece. I made some more pics:
German: Superthrower Lumintop BLF GT - Laberthread und Versand | Taschenlampen Forum
English: Superthrower Lumintop BLF GT - Laberthread und Versand | Taschenlampen Forum
Picture-Galery:BLF GT | Taschenlampen Forum
Nice job on the extra center piece! In hope that the new led will be trouble-free!
Nice job on the centering ring, ring! :+1:
I wonder if painting it black will take some of the Halo away?
Is the centering ring bar tight to the mcpcb hold down screws, or is the clearance around the screws?
Thanks!
I could paint it black, it could take a bit of the corona around the hotspot. … but its only aditional light output wich would be lost. … dont know, if I want to make it black.
The centering bar is not screwed donw, it lies lose on the mcpcb around the screws.
Nice job wieselflinkpro!
I tried to open my GT in the vice, without success, i definitely need to use bigger tools
A few quick documentation photos of another Armytek mod I did recently, following the excellent instructions from Clemence here. The Prime Pro bezel has no thread locker and can theoretically be removed with just friction, but mine was so tight I had to make the tool Clemence suggests here, which worked perfectly. The hardest part of the mod for me was threading the leads back through the rivet holes while working around the delicate control wires behind the switch board. My C1 Pro now has a 219C and I’m using it with a slightly floody optic while waiting on a few options from Aliexpress.
I sacrificed my old C2 to get the remains of the Shadow JM35 working again, after I botched the pill removal. Driver is a CF-FX-17A. I also used an extension tube which I think I bought from DX years ago.
:cool: lego-job! ^
Today a mod with nothing revolutionary in it, just making a very nice and robust EDC:
*black S2+ host with short tube
*green o-ring at the lens swapped for a transparent one
*tried a smooth S2+ reflector but that produced a weird red-ish spot in the middle of the hotspot, went for the stock OP-reflector and the beam was fine.
*Nichia 219C SM4070e R9050 soldered on a 16mm Noctigon soldered to the pill
*BLF A6 driver fixed for voltage spikes with an extra 5 Ohm resistor, and added 680 Ohm bleeder resistor
*no spring bypasses, and kept the stock thin ledwires to keep the current down
*swapped the tail spring for a smaller one to reduce the tension on the 18350 battery.
*Lexel’s lighted tail ring with 6 leds, 4.7 kOhm resistors for each 3 leds, 3xblue led 3xpink led
*transparent 16mm tail cover.
The current (measured tail off with a clamp meter) on a full 1200 mAh Keeppower high drain 18350 was still between 7 and 8A, but I reckon with resistance of the tail it will be 5-6A, gradually going down with the battery draining, which is good. Output on high is 700 lumen, user interface beam and tint is great.
I modded a short grey S2+ today with 4x 5000K Nichia Optisolis leds. Build post here: Output and voltage test of 5000K and 3000K Nichia Optisolis leds - #2 by djozz
CRX Brass Puck :slight_smile:
