Review: Skilhunt H03RC
6 posts / 0 new
Lumeniac
Lumeniac's picture
Last seen: 5 hours 59 min ago
Review example was provided by manufacturer. Here is a H03RC product page.
H03 is #1 headlamp here in Russia (and I think in other ex-USSR countries) for it`s price\usability\functionality ratio. The only feature, that this model lacks is battery charge function. Now it is fixed, welcome H03 RC.
size :
length – 101,7mm
Head diameter – 23,5mm мм ( 25,3 with button)
Body diameter – 21,9mm
Inside diameter – 18,9 мм.
*weight : *
H03RC– 49g.
- headstrap rubber holder – 15g.
- holder + headband – 31 g.
- vertical headband – 10 g.
Comparing to H03, this model is gust 1,8mm longer and 5g heavier
PACKAGE AND APPEARANCE
Производитель отошёл от привычной желтой коробки, выбрав для этой модели используемую в обычных фонариках. Черная, с синим тиснением внешняя шкурка скрывает толстостенную картонную коробку.
This time that`s the same box that Skilhunts use for 18650 flashlights, not yellow box that we used to see in H02\H0
Inside, in foam rubber lays H03RC itself.
Below foam rubber that are cardboard cover that hides all the includes. The rest ones are the same, the only addition here is USB charge cable.
As I mentioned above, difference between RC and regular H03 is almost invisible. If Skilhunt decided to choose regular charge port below head, under rubber plug, that would have led to about 10mm extra length and worse waterproof. Positive side of this would be not using original Skilhunt charge cable, any micro-USB would work. So, as usually, it`s own PROs and CONs.
TIR optic is the same. The same is XM-L2
One more minor difference is location of print with logo.
Cooling ribs are qiute deep. OMG, I have to repeat that all you know from previous version )
Rhombic knurling is quite good for greep.
Rubber button also serves as indicator, with RED-GREEN LEDs inside.
Small threads are perfectly lubricated.
Tail spring is not that thick, but it shouldn’t be.
Tail magnet can be replaced with spare plastic round.
Though headlamp is short, there are still some space to place spring at head, good.
I unscrewed ring at contact plate, thougt that would let me haul out charge electronic – no way. Seems that it was placed from bottom part of head, of glued. BTW, body is also glued to head, there is no way to unscrew it.
The last that need to be mentioned is a charge cable. It is plastic round with RED-BLUE indicator LEDs inside. Connection part consists of round “-“ and small “+” stick in the centre. There are also Type-C plug to use for phone charging.
Everything seems to be OK except one really CON which is really weak magnet. Just move cable or headlamp little bit at magnet at contact plate will loose contact with head. So there is no way to charge headlamp on the move. Both cable and H03RC must stand still to keep connnection. This SHOULD be fixed with stronger magnet.
I assume that charge electronics locate in cable and head includes only some shortage-protection circuite.
BTW, i personally prefer mini-usb charge port, as i can use it with any cable.
I put H03RC in water, everything works great.
When I connected multimeter to both + and – at head contact plate, device showed 0.003A.
Overall impression is the same as for previous version – everything is nice. Besides weak magnet.
UI
The same, absolutely the same. The same perfect UI that I like here soo much.
There is mode memory.
From OFFF: a short click – ON , a long click – LOW, double click – TURBO .
From ON, a long click – OFFF,short click – cycle throw modes. 3x click start strobe and 2 beacons. To cycle between them, make a double click..
Submodes: Each mode has 2 presets, like L2\L1. To change – quick double click.
Power indication.
When voltage drops down lower than 3.3V, indicator flashes twice every 2s; lower than 3V, indicator flashes 3 times every second), and also as a locator.
LOCKOUT
1.5 sec press to lock in and out.
I think 1.5 sec is to short , 3-4 sec is better. Or other way like 2 press+hold. At least, you always can physically lock headlamp.
PERFORMANCE
Manufacturer offers both NW and CW.
NW is little bit yellish to me. Check below. Still, it`s way better than CW. May be there will be Nichia version? I bet a lot of people prefer pay pair of extra bucks for better tint.
No visible PWM shimmering at any mode.
When LED reaches 70 degrees hot, H03 activates stepdown from T1 to T2
Light is perfectly diffused, very convenient for close-range work. There are also version with diffusor (H03F) and with OP (H03R).
still it can illuminate wide area around
H03RC has good stabilization. For test i used 18650GA
BTW, when you H03 turns OFF and you still need some light, just unscrew tailcap and then return it back. After this start LOW mode, you `ll get about 30 min of extra time in this mode )
Charge amperage is decent, 1A.
OVERALL IMPRESSION
Skilhunt is in rough situation. They offer set of excellent headlamps with different optic and K. RC and non-RC. And there is almost no way to make them better (except better magnet which is just fix of current version, not new one). What about H03RC – good build quality (as before), perfect UI and light. Just fix magnet, the rest is really good.
Edited by: Lumeniac on 03/09/2018 - 06:25
Delta_V
Last seen: 3 months 4 weeks ago
Nice, thanks for the review. Been waiting to see a review of the RC model. Would be nice to see a test of the charging function to check the charging current and cutoff voltage.
I actually really like that charging cable. Other magnetic charging solutions require their own cable, so you need separate cables for your flashlight and phone. But with more devices using Type C, you could use this cable as your primary cable to charge both your phone and flashlight.
edit: Sorry, missed your note towards the end that noted ~1A charging current.
Nev
Looks like they’ve modified the rubber holder , Thumbs Up
SKV89
Last seen: 7 hours 18 min ago
I wonder if there is a risk of short circuiting like the Olight H2R Nova on this one.
I just received my Skilhunt H03 yesterday and it is a very simple budget headlamp. Nothing fancy, no bells and whistles like some of the other more expensive headlamps. Here is a ceiling bounce brightness comparison between different headlamps that I have:
Skilhunt H03: 139 lux
Armytek Wizard Pro XPL v3 WW: 141
Olight H2R Nova NW unit 1 (older nice warm rosy tint): 318
Olight H2R Nova NW unit 2 (newer ugly green tint): 280
Acebeam H15 CW: 315
Acebeam H15 NW: 324
Note that the Acebeam H15 is much floodier than the other flashlights and ceiling bounce method favors narrower beams so the H15 should produce significantly more lumens than the rest.
Delta_V
OP reported 0.003A across the charging terminal when measured with a multimeter, so that doesn’t seem to be a problem.
beastlykings
beastlykings's picture
Last seen: 4 months 6 days ago
Oh man I would really love to see the other side of that driver and see how the charging is wired up. Does the driver handle it, or is there a second board? My favorite thing about the OG H03 is the ease of swapping out that driver for a TA driver.
