What's the average time to step down from turbo to 1800l m? Mine has not arrived yet, but I sort of regret ordering it now that I know it has a very tight hot spot instead of a more even flood.
kirman, the hot spot isn’t really all that tight unless you take steps to make it so. The reflector is comparatively shallow and orange peel in texture with the big XHP-70.2 so the hot spot at any real distance is quite large. It has been widely reported to have a nice spill that’s useful as well, so it should be very much an excellent general purpose light in stock form.
Pretty sure I saw where someone put DC Fix on the lens and was very very pleased with the result…
I saw the same expected ship date when I ordered mine. I was therefore surprised that it shipped in about 4 days.
W
They are shipped from the USA from Amazon wharehouse.However this light is very popular. I ordered on Feb 22 and recieved on a Sunday Feb 25.
I think DC-Fix should be able to fix the tint shift and diffuse the hotspot as I’ve done it on over a dozen flashlights already. However, I still wish Thrunite used the A and D (rosy) tints instead of the B and C (yellow greenish) tints. DC-Fix does not change the tint. But yellow/green on this light is not as bad as some of the other lights I’ve seen.
I'm already looking forward to it then, thanks
Your order was on good timing. 2nd batch preordered, they shipped it on feb 13th…
Just when I think I'm the only one that does things like that I read your post!
Still thinking about dqg tiny 26650 instead because of smaller size. I know it has substantially less max output than TC20, but I’m wondering if it is also less efficient at lower outputs. Would the TC20 run substantially longer at around 100 lumens than the dqg? 500 lumens? (I realize neither light has these exact outputs programmed, just thrown out their as hypotethetical values for sake of bigger question of efficiency)
The TC20 is boosting a 4.2V cell to supply a 6V emitter so the actual current draw from the cell is going to be close to 50% more than current supplied to the emitter. The DQG is boosting a 4.2V cell to supply 21V to the 7 emitters at 1A actual emitter current in Turbo. So the DQG is probably hitting the cell harder in the long run.
I know this about the DQG because I modified mine to take a Cree COB at 21V 1A. (It’s technically an 18V COB but requires 21V to run 1A current at the emitter. At this level, as supplied by the stock DQG driver, it produces 2004 lumens out the front from the mule configuration with an AR coated lens.) I have this COB also as a light source for my Carolina Reaper, running on a power supply, and at .450 mA to the emitter it,s burning through 17.18V. This where I set it with the light within 2 inches of the plant. This is supposed to be a 96 CRI COB.
At any rate, the TC20 should be more efficient on the cell, runtimes should be correspondingly longer.
Thanks.
Does anyone that owns the Olight R50 know if the Thrunite TC20 will fit in the R50 holster?
If I use unprotected IMR battery can I safely charge it with the Thrunite TC 20 Flashlight or do I need a separate charger ?
Today I also became the owner of TC20 :).
The package went the entire 5 days. Flashlight very pleasant, shines wide and strong enough. I like it very much. With measurements, the turbo collection is 10A. Color NW and it came out to me 4959K. Despite the ideal temperature, some bile is. BLF Q8 is clean, despite the slightly lower temperature. Overall, it’s really good:
Of course, I checked the supplied Thrunite battery. I have a comparison for Lii-50. The original is slightly less turbo, but not the whole 10%. The problem is time, because in turbo it lasts 47 seconds and goes down rapidly. On the Lii-50, the turbo will heal for 150 seconds and then it slowly descends for another minute. The flashlight is already very hot 62 degrees Celsius.
That’s not all that hot, try running it at 20A to the emitter for a while
Y’all are killin me, how can I resist when y’all write all this great stuff about this light?
Haha I also tried to resist and what? Waste of time
Has anyone gotten an emitter current read yet? What, about 3.6A to the emitter? Would like to find out what the driver is pushing up top…
So 6V diode, which gives us 30W, hmm 10W loss on the controller. 75% efficiency
Thanks Komeko for the valuable info. I received my TC20 two weeks ago and the color temperature is slightly warmer than my zebralight sc5w II 4500k. It is much warmer than my 5000k flashlights and close to my 4000k flashlights, which I prefer. However, it is high above the BBL line so it has more green than my other flashlights. I’m curious where did you order yours from and when did you receive it? I don’t really know how to read your color chart but is yours above or below the BBL line? Is it more or the greenish or rosy side? If it’s below the BBL and more on the rosy side, I want to buy another one because it’s such a perfect practical flashlight and the only thing I currently don’t like about it is the B or C greenish tint they use instead of A or D rosy tint.
It will be 3C near the main line and near 3B. For me, there is no green, there is more yellow which gives the impression of a warmer color than it really is. BLF Q8 has a lower temperature and it seems cooler because it is not so much yellow.
I ordered on the company website and the shipping was from Amazon.
