I never even noticed the 9 series CPU’s from AMD ( AM3+ )
The new stuff looks interesting , but prices are high …
I saw the 9590 cpu’s 4.7ghz stock and 5 ghz Turbo … This will be my last upgrade unless I can find RAM to match what I have …
I used to be such a hardware junky , now apparently I don’t care anymore … ( Never noticed the 9 series )
Currently running a FX 8370E @ 4.1ghz , and it feels slow … ( Video editing )
Oh well , I will hold onto this MB for a while longer … If I am lucky the 9590 might run 5ghz …
Yeah , oh well … So it matters not which processor you run … Either can be exploited ….
Yeah , only answer is to get off the internet … Burn your modem … Unplug the cable … And find something else to do …
Oh well ! Matters not … The new CPU has been ordered ! I need more speed …
Might go with the Nepton 140XL liquid cooler as well > would require surgery to my case ! ( If I want another 16gig of ram )
Those CPUs are obsolete, like 5 years old.
It’s literally just an overclocked FX8xxx CPU that costs double.
Even when it was released the FX9xxx CPUs were complete crap, they produce massive amounts of heat and didn’t perform any better than the intel CPUs from 5 years ago.
Save up and buy a new current-gen motherboard+CPU that isn’t an outdated induction heater.
The new cpu’s are over valued ….
DDR4 is expensive …
MB’s are expensive …
Graphics cards are over valued
Only thing that is decent is Hard drive prices , monitors have at last come down in price as well .
For now I hope for 5ghz … I will double my ram when I put in the water cooler ( aircooler blocks ram slots )
And I may buy a bigger SSD … Maybe next year I will go for a new CPU / RAM / MB / Graphics … Doing that right now would cost me nearly 2 grand …
To be honest , I don’t have 2 grand to surf the net a little faster …
I found the lowest priced FX 9590 ( new from newegg ) , Cooler Master Nepton 140XL ,
I will graft the Nepton into my Antec Case ( Not really made to handle it ) . It will shoe horn in .
This will then free up ram slots , so hopefully I can find some 16 gig of matching ram …
Then maybe 6 months down the track I will throw in a 1TB SSD … ( Currently 250MB SSD with a 2TB Hybrid )
Just need to crunch video faster … Intel CPU’s are good for Video crunching , but a long time ago I took the AMD road .
There is a whole new CPU technology emerging that will make current CPU’s look and feel very old …
Not sure how many years to filter down to consumers ( joe six pack ) , but expect a serious leap in computation power possibly by 2020 , oh and more $$
+ The CPU I have now is overclocked about 800mhz ( 24-7 ), I don’t remember but power might be around 220Watts + ( and then some ) …
Been overclocking for 2 decades now , always pushing … A long long time ago I was on the leading edge of performance , I no longer have the money or contacts to sift through dozens of CPU’s looking for a really good one … The 9590 supposedly does 5ghz Turbo … I wait and see , if the CPU is half way decent it will 5ghz 24-7 with good cooling .
1) You don’t need to buy the highest end product.
You can buy a cheap ryzen 5 or 7 and get better performance than the obsolete 7 year old FX CPUs.
2) DDR4 is expensive because of a current memory shortage, you can get cheaper stuff on ebay or craigslist or just wait for prices to drop.
8 or 16GB isn’t too expensive.
3) motherboards are not expensive, do some research and you will find that there are many good ones that are less than $100-150
4) CPU frequency is not how you measure performance. Just because a CPU gets 5GHz and another gets 4 does not mean that the 5GHz CPU performs better. There are many other factors.
5) As I said before the FX9000 series is literally just overclocked FX8000s. They cost more, use a huge amount of power, and barely perform any better. You’re wasting your money on a marginal increase when you could save that money to upgrade to a better CPU+mobo in the near future
6) If you want to overclock an FX9000 CPU you will need a dual 280mm AIO or better cooling, like a $500 custom watercooling loop. Even with a 140 it will be overheating at stock speeds.
7) It does not cost $2k to upgrade to a recent generation CPU and motherboard, clearly you need to do a lot more research on components before buying.
8) If you choose to buy literally the worst CPU in existence, the 9590, it’s your money and it is up to you, so I can’t stop you from wasting it.
I have been playing since 93 … ( Computers )
I haven’t played with water for a long time …
And I dont mean to be rude , but I was not really fishing for advice … ( There are simply too many expert opinions out there )
The road I have taken , is the road I will ho till 2019 … My current 8 core runs 4100mhz , a 9590 will be faster ( not comparing to anything else ) …
Can the Nepton 140XL handle the 9590 ? ( I am going to find out ) …
Apparently the Nepton 140 kicks most 240s to the curb , if the reviewers are not lying … I have a very old Frio air cooler handling 4100mhz just fine … ( Fans @ 1500rpm )
As for the $100 to $150 M/B’s , they dont do what I want …
My current board is the ASUS Crosshair V Formula ( old stuff now but a fine board in its day )
Yeah … Ever since intel brought out their Quad cores , AMD has pretty much sucked Intel dust …
I know this … I built Intel computers for my friend , and they just roosted me for Video encoding .
I was going to go to the new CPU , but costing things = Just not on the cards for now … So just upgrading what I have …
Which will then allow me to upgrade another computer with my old CPU … ( I have a spare 890FX M/B doing nothing )
It’s the budget option .
Depending on the calculator used , either 235 Watts or 245 Watts , 24-7 for ?? Years ….
I can’t remember when I got this CPU , but from day one it did 4000mhz ( 4ghz )
Cooling 240 Watt is not hard …
Generally overclocking is all about finding the wall … ( Wall = when the CPU needs huge Voltage increases to scale further )
Some CPU’s hit the wall early , worst I ever had gave about 50mhz ( long time ago ) …
I had a few that only did 100mhz …
THe Holly grail of CPU’s is the one that overclocks 100% … ( Celeron 466 comes to mind ) ( Some Q6600 also did 100% overclocks )
Generally if you can find a CPU that overclocks 50% you should be very happy …
These days , one might be happy with 25% …
I don’t run anything stock :
My current cpu is lapped , my heatsink is lapped … ( Does it help ? - I think so )
When the water cooler gets here , the waterblock will be lapped , and the 9590 will be lapped …
Anyhow , will be interesting never the less , I havent done anything with my computer for maybe 5 years ( except put in a larger SSD and HDD )
So this will be interesting at the very least .
