It’s now in flash sale until 20th March for only $6.99 ($12.29)
Successor of most popular compact Lii-100.
Apparently someone from Liitokala reads BLF and saw all those lii-100 voltmeter mods
They even added current readout!
EDIT:
A6 code 2017FNL expired, 8a955d still works. For Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 coupon code 76648A works.
I generally try to remove expired deals from the list in first post, but I’m not able to check everything all the time and end dates are most of the time not disclosed and/or change. Some very old coupons still work, others can be disabled and then reeanbled again.
Both are listed - in fact also another one (older one with 2$ higher price but also working).
It’s best to use search function (Ctrl-F in most browsers) and check for all deals in first post.
New headlamp from Xanes with 2x XP-L2 LEDs. It’s now in preorder: first 50 pcs for $12.99, up to 500pcs for $13.59, then $16.99 and final price is supposed to be $25.49.
2x Cree XP-L2 CW
2 Aluminium OP reflectors
1x18650 power supply
6 modes with stepless dimming
micro USB rechargeable
max output up to 1650lm (with decent high drain battery - Samsusng INR18650-30Q is suggested)
Apparently there’s no moonlight if the description is accurate. Lowest setting seems to be ~200lm
This however looks like a nice candidate for modding - I was thinking XP-L HI CW with reflector for throw in one socket and high CRI Nichia with TIR Optics as second LED for close range flood beam.
