BLF GT official support thread [FAQ updated 11 Jan 2018]
I have seen it somewhere in the GT-Thread.
I am the second who showed it.
I’m not sure who to send this to so please excuse me ,To anyone that could help me Thank You
I haven’t heard anything about my BLF GT w/batteries starting to get a little concerned at this point if it will ever show up, could someone please let me know what’s going on ,Thank You I think I was # 975 I paid for it on 12-10-2017,Thank You I’m not sure if this is the right Neal to contact.
Any Help would be greatly appreciated…
Check post #1 of the GT thread. The last orders (about 50 lights) should be picked up by the shippers today. Sometime after that Neal will get the tracking numbers and send them out to the customers. That’s the latest news I’ve heard.
Just noticed something strange; when I turn on the GT it flashes 3 times and then dims a bit. If I perform the battery test (triple tick) it looks like it is indicating 2.2V? I have tested (and recharged) the batteries and they are at 4.2V.
Also, sometimes when I turn on the light it flashes 8 times and then switches off. I have performed a ‘factory reset’ (perhaps my son played around with it and messed up the configuration) but this gives the same results. What could this be?
That is very strange. It is possible that the resistor that lets the driver know the voltage is messed up I suppose but it is a rather odd thing to have happen.
Are you using button top cells?
Did it always do this? Or did it just start doing it?
NarsilM thinks the voltage is too low.
3 blinks indicate low voltage protection kicks in and the lamp steps back.
But I have no clue about the reason
I ordered the light together with the recommended button top batteries (so directly from Lumintop).
It has been working fine for the last few weeks, last night I saw the issue for the first time and decided to look into it this evening.
Personally I’m not that handy with a soldering iron but I have some colleagues who are; is there a way they can test if the resistor is not functioning properly?
Hmm, that is very strange indeed, particularly if it was working and is not now. That makes even less sense.
First thing I would do is rule out the batteries and carriers. First look over both carriers by eye for any signs of damage, shorts, loose or missing screws. Then try some other cells if you have them. Only use one carrier, try that single carrier in both the front and back position, try the other carrier ect.
See if any combo of cells and carrier makes a difference.
If none of that helps at all, then I think we have ruled out the cells and carrier and the issue must lie in the driver.
Next step would be to pull out the driver, this is pretty simple and you can try getting a good picture of it for us to look at. See if you notice any shorts or missing components.
Do you have the ability to reflash the mcu?
Thanks for your rapid response; I will try everything you mentioned above and report back here with the results.
I have no experience with reflashing an mcu but always can dive into that if needed…
Reflashing the MCU should not be needed, it is just another thing that is reasonably easy to test if you have the flasher.
Do you have a multimeter? That will be needed to test the voltage on the driver if nothing else works.
If you have a multi meter, you can also test the 4 cells when they’re mounted in the carrier and make sure they are around 16+ volts.
Yes, another good test to run.
Ok, I tried the various carrier combinations and that did not help. I also used a multi-meter and both carriers measure 16.99 volts but still the voltage check of the light itself reports 2.2 volts (and I get either 3 flashes and the the light dims or 8 flashes and the light switches off).
I’ll try to open the head, inspect the driver and take some pictures next…
Edit: hmm, tips on how to get to the driver? :slight_smile:
Driver retainer might be loose. Remove battery tube and flip the head over, the large Aluminum ring with 4 holes is the driver retainer. Check if it’s tight. This retainer needs to be removed to get the driver out.
Correct, a pair of small needle nose piers can usually be used to loosen or tighten the ring.
It is strange the carriers are reading 16.99v, with fully charged cells at 4.2V each they should only be reading 16.8v. Could your meter be off? Not a big deal but still odd.
I was able to remove the container and take a look at the board but the wires are pretty short and probably I need to desolder the wires to get the board completely out?
Are there spare driver boards available which might solve the issue?
To remove the driver you have to unsolder the 2 big red and black wires on the led, then unscrew the switch bezel and push the switch pcb through the hole. Then the driver will come out.
You turn the switch pcb sideways and use the notches.
Lumintop is supposed to have some extra drivers available for warranty purposes.
I’ve found that sometimes just loosening the driver and then tighten it back up can sometimes fix things. I think when you loosen the driver retaining ring the driver can slide around. I make sure to center the driver before tightening the ring back up. Thus helps make sure I don’t get a short circuit on any driver components.
For instance, C17 and R6 are pretty close to the drivers edge. If the driver gets shifted to the side, you might short one of those and cause all kinds of issues.
You can also hold a loaded battery carrier directly on the driver so that you know it’s making good contact. Try this and see if it makes a difference.
Thanks, with your help I was able to get out the driver. I looked at the pcb but don’t see anything weird, missing or damaged.
Is there something I can do myself (or with the hardware dudes at my work) to further ‘test / check’ my driver pcb?
No, just take close up pictures maybe.
You might have corrupt software or a defective component, none of which are visable.
On the other hand, a component might be lacking a little solder or there may be a little too much solder causing a bridge. Which could also cause your issues.
Did you fill out Neal’s form saying you have an issue? Since it seems the driver might be at fault, Neal/Lumintop can probably send you a new driver.
I don’t know exactly how their warranty procedures work.
Maybe add this to the OP or post 2?
Could be handy ;)
