BLF GT official support thread [FAQ updated 11 Jan 2018]
339 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 1 day 6 hours ago
M4D M4X wrote:
 after someplaying i found time to notice my Turbo is only 7% more Lumens (ceilingbounce in 3 locations) than full ramp Sad
using my BenchPowerSupply (@16,8V) it draws 1,9A full ramped and 2,5A on Turbo
any idea?
btw:
using 4 30Q BT i get 1% lower numbers in front cage, and 3% lower numbers in rear cage
In testing I was barely able to see any difference between Turbo and High. From memory I measured just over 10% difference in output but that was with the proto led.
High should be 2 amps at the led and turbo 2.5 amps.
JasonWW
JasonWW's picture
Last seen: 1 hour 2 min ago
Here is MRsDNF runtime chart for 4 30Q from post #4 of the main GT thread. You can see that at 2.5A your run times suffer quite a bit (blue line). At 2A the runtimes are much better (red line). So for short usage where you need max output turbo makes sense, but for long runtimes (at almost the same output) it’s better to use 2A.
If you look at that 160 line (roughly when output starts to drop) the 2.5A reaches it in 35 minutes. The 2A reaches it in 55 minutes. At the 2A setting you get a 57% boost in run time for a tiny bit less output! I think it’s for this very reason that NarsilM v1.2 was designed to have the ramp stop short of max. (Correct me if I’m wrong)
So 2A is definitely the mode to run for practical purposes and longer run times. The 2.5A is there for max output and distance even though it drains the batteries way faster.
square74
Same to mine, but Texas_Ace is right.
Lumens are not linear.
From high 2,0A (2490lm) to turbo 2,5A (2630lm) there is only a higher output of 5,62%, so 7 % are not bad ;).
Or from 1,9A (about 2440lm) to 2,5A about 7,7% in your case.
If I will get open the GT, a TLF colleague will programm the driver with ramping to 100% output (2,5A) and also put a XHP35 Hi E2 3C 5000K on it.
Ramping to 100% is good for me, because I want to use ramping and I don´t like the short flicker if I will change to turbo with double click.
I know this short break (light off) is necessary, if you don´t want to flash the light in turbo for a short time, if you will use the battery level indicator or the electronical lockout.
sorry for my poor English ;).
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 13 hours 41 min ago
The XHP35HI is maxed out at around 2.5amps so you cant expect to many more lumens. Plus it depends on the binning of the LED.
square74
New binning is E2 instead of D4.
Amps will be same at 2,5A.
Binning D4 is about 550lm at 85°C at 350mA and about 4,8 times more at 2500mA (2630lm, Test Texas_Ace).
I know that calculated lumen are most not correct, but I hope, that with Binning E2 I can get:
Binning E2 about 590lm at 85°C at 350mA and about 4,8 times more at 2500mA, so about 2850lm, so about 8% more lumen output and perhaps 8% more range.
that is very optimistic I know.. Wink
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 1 hour 15 min ago
8% more lumen and sqrt(8%) = 3,9% more range.
square74
Really?
So I don´t change the LED… and don´t need to open the flashlight.
Driver can be removed easily.
Thanks
JasonWW
JasonWW's picture
square74 wrote:
Really?
So I don´t change the LED… and don’t need to open the flashlight.
Thanks
I’m really lost on what your saying here. Are you trying to remove the driver?
If your wanting to reflash it you have room to do so without removing it. Check post #33 and you can see the room you have.
Wieselflinkpro
square74 wrote:
Really?
Thanks
I calculated the square root of 1,08 wich is 1,039.
square74
Quote:
I’m really lost on what your saying here. Are you trying to remove the driver? If your wanting to reflash it you have room to do so without removing it. Check post #33 and you can see the room you have.
I don´t have know how and equipment for flashing drivers, so I removed driver and switch board and will send it to a colleague.
Driver will be reflashed with NarsilM, but with changing Ramping up to 100% (2,5A).
LEDs on switch board will be changed to blue or orange, or complete switchboard will be changed.
I like blue and orange indicator very well.
thanks.
Quote:
A calculated the square root of 1,08 wich is 1,039.
Thanks Wieselflinkpro Thumbs Up
Wieselflinkpro
M4D M4X
M4D M4X's picture
Last seen: 3 min 19 sec ago
nice idea with that centering piece!
Danke fürs zeigen!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Wieselflinkpro
Danke fürs zeigen!
I have seen it somewhere in the GT-Thread.
I am the second who showed it.
Hayseed
Hayseed's picture
Last seen: 1 year 11 months ago
I’m not sure who to send this to so please excuse me ,To anyone that could help me Thank You
I haven’t heard anything about my BLF GT w/batteries starting to get a little concerned at this point if it will ever show up, could someone please let me know what’s going on ,,Thank You I think I was # 975 I paid for it on 12-10-2017,,Thank You I’m not sure if this is the right Neal to contact.
Any Help would be greatly appreciated..
JasonWW
JasonWW's picture
Check post #1 of the GT thread. The last orders (about 50 lights) should be picked up by the shippers today. Sometime after that Neal will get the tracking numbers and send them out to the customers. That’s the latest news I’ve heard.
R.D.
Just noticed something strange; when I turn on the GT it flashes 3 times and then dims a bit. If I perform the battery test (triple tick) it looks like it is indicating 2.2V? I have tested (and recharged) the batteries and they are at 4.2V.
Also, sometimes when I turn on the light it flashes 8 times and then switches off. I have performed a ‘factory reset’ (perhaps my son played around with it and messed up the configuration) but this gives the same results. What could this be?
Texas_Ace
Texas_Ace's picture
Last seen: 14 hours 11 min ago
That is very strange. It is possible that the resistor that lets the driver know the voltage is messed up I suppose but it is a rather odd thing to have happen.
Are you using button top cells?
Did it always do this? Or did it just start doing it?
joechina
Last seen: 2 weeks 5 days ago
NarsilM thinks the voltage is too low.
3 blinks indicate low voltage protection kicks in and the lamp steps back.
But I have no clue about the reason
R.D.
I ordered the light together with the recommended button top batteries (so directly from Lumintop).
It has been working fine for the last few weeks, last night I saw the issue for the first time and decided to look into it this evening.
Personally I’m not that handy with a soldering iron but I have some colleagues who are; is there a way they can test if the resistor is not functioning properly?
Texas_Ace
Texas_Ace's picture
Hmm, that is very strange indeed, particularly if it was working and is not now. That makes even less sense.
First thing I would do is rule out the batteries and carriers. First look over both carriers by eye for any signs of damage, shorts, loose or missing screws. Then try some other cells if you have them. Only use one carrier, try that single carrier in both the front and back position, try the other carrier ect.
See if any combo of cells and carrier makes a difference.
If none of that helps at all, then I think we have ruled out the cells and carrier and the issue must lie in the driver.
Next step would be to pull out the driver, this is pretty simple and you can try getting a good picture of it for us to look at. See if you notice any shorts or missing components.
Do you have the ability to reflash the mcu?
R.D.
Thanks for your rapid response; I will try everything you mentioned above and report back here with the results.
I have no experience with reflashing an mcu but always can dive into that if needed…
Texas_Ace
Texas_Ace's picture
Reflashing the MCU should not be needed, it is just another thing that is reasonably easy to test if you have the flasher.
Do you have a multimeter? That will be needed to test the voltage on the driver if nothing else works.
james y
Last seen: 1 year 3 months ago
If you have a multi meter, you can also test the 4 cells when they’re mounted in the carrier and make sure they are around 16+ volts.
Texas_Ace
Texas_Ace's picture
Yes, another good test to run.
R.D.
Ok, I tried the various carrier combinations and that did not help. I also used a multi-meter and both carriers measure 16.99 volts but still the voltage check of the light itself reports 2.2 volts (and I get either 3 flashes and the the light dims or 8 flashes and the light switches off).
I’ll try to open the head, inspect the driver and take some pictures next…
Edit: hmm, tips on how to get to the driver? Smile
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 13 min ago
Driver retainer might be loose. Remove battery tube and flip the head over, the large Aluminum ring with 4 holes is the driver retainer. Check if it’s tight. This retainer needs to be removed to get the driver out.
KB1428 “Live Life WOT
Texas_Ace
Texas_Ace's picture
Correct, a pair of small needle nose piers can usually be used to loosen or tighten the ring.
It is strange the carriers are reading 16.99v, with fully charged cells at 4.2V each they should only be reading 16.8v. Could your meter be off? Not a big deal but still odd.
R.D.
I was able to remove the container and take a look at the board but the wires are pretty short and probably I need to desolder the wires to get the board completely out?
Are there spare driver boards available which might solve the issue?
JasonWW
JasonWW's picture
To remove the driver you have to unsolder the 2 big red and black wires on the led, then unscrew the switch bezel and push the switch pcb through the hole. Then the driver will come out.
You turn the switch pcb sideways and use the notches.
Lumintop is supposed to have some extra drivers available for warranty purposes.
I’ve found that sometimes just loosening the driver and then tighten it back up can sometimes fix things. I think when you loosen the driver retaining ring the driver can slide around. I make sure to center the driver before tightening the ring back up. Thus helps make sure I don’t get a short circuit on any driver components.
For instance, C17 and R6 are pretty close to the drivers edge. If the driver gets shifted to the side, you might short one of those and cause all kinds of issues.
You can also hold a loaded battery carrier directly on the driver so that you know it’s making good contact. Try this and see if it makes a difference.
R.D.
Thanks, with your help I was able to get out the driver. I looked at the pcb but don’t see anything weird, missing or damaged.
Is there something I can do myself (or with the hardware dudes at my work) to further ‘test / check’ my driver pcb?
