Test/review of Keeppower 18650 2600mAh P1826R (Black) 2017
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 27 min ago
DSC_2621
Official specifications:
  • Part No.: P1826R
  • Protected 18650 Li-ion Rechargeable Battery
  • Minimum Capacity: 2500mAh
  • Typical Capacity: 2600mAh
  • Normal Voltage: 3.7V
  • Maximum Continuous Charging Current: 5A
  • Maximum Continuous Discharging Current: 15A
  • In Built Safety Circuitry
  • Protection Circuit (Against over charge, over discharge, over current and short-circuit.)
  • 4.20V maximum voltage and 2.50V cut-off voltage
  • Over 500 charge-discharge cycles
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-info
This is high current protected batteries with moderate capacity.
DSC_2618DSC_2620
DSC_2622DSC_2623
DSC_2624
DSC_2625
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Capacity
The discharge curves looks very good with perfect tracking.
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Temp-10.0
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Temp-15.0
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-CapacityTimeHours
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Energy
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-PowerLoadTime
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-TripCurrent
The protection trips above 15A, but below 20A, I could not do 20A discharge curves.
Keeppower%2018650%202600mAh%20P1826R%20(Black)%202017-Charge
Conclusion
This is a good battery and with the protection there is no risk over over discharging the battery.
Notes and links
The battery was supplied by Keeppower for review.
Compare to 18650 and other batteries
mrheosuper
Last seen: 1 day 9 hours ago
could you take out the wrapping to see what is its cell ?
Forgot my pen
HKJ
HKJ's picture
When the manufacturer do not provide the original cell name, I will not spoil it for them, but others are welcome to check my comparator for a match and post it here (Remember that the high current traces will be lower due to the resistance of the protection)
the4ds9
Last seen: 8 hours 45 min ago
Where can I purchase the Keeppower P1826R battery? The one listed on Illumn.com is the Samsung ICR18650-26F
shadockan
shadockan's picture
Last seen: 3 hours 47 min ago
Sony Konion US 18650 VTC5 2600mAh 20A
Look at the Lygte Battery Comparator from Henrik
the4ds9
That is wonderful. It means the Jetbeam TH20’s supplied cell may well be a Protected VTC5. This cell was the choice of top modders before the VTC5A was introduced. Nice! So exciting! Silly
