You might have corrupt software or a defective component, none of which are visable.
On the other hand, a component might be lacking a little solder or there may be a little too much solder causing a bridge. Which could also cause your issues.
Did you fill out Neal’s form saying you have an issue? Since it seems the driver might be at fault, Neal/Lumintop can probably send you a new driver.
I don’t know exactly how their warranty procedures work.
There is one thing you can do, you can check the voltage divider to see if it is outputting the correct voltage but I need to find a good picture of the GT driver so I can point out where that is.
I will try to look for one later when I have more time.
I assume you have filled out the issue survey for the GT already? If not the link is in the OP.
I know of a few issues that have been taken care of so far but it is going much slower then I would like. I am hoping now that the shipments are on hold for a little bit Neal can focus on dealing with the issues.
As long as you have filled out the survey you are on the list of issues I will be tossing at Neal every chance I get until it is dealt with.
Packageradar seems to be one of the better tracking sites. It’s currently giving me detailed information about every stop of the rail journey that my Lii-500 is making from China…
Packageradar didn’t seem to work for this tracking #.
It’s a 16 digit number with no letters, so I think it’s a canada post tracking number, cause that’s their style and I’m in Canada.
But I don’t get a status yet, for one of the following reasons:
The item is in transit, but we haven’t yet received it from the sender
The item is coming from another country and is not in Canada yet. Track it on the postal website of the originating country first.
Does anyone know what the internal resistance of the included cells should be? Currently charging the first two in my C2-6000 and it’s showing me 78 / 82 milliohms. To me, that seems quite a lot for high drain cells.
I see - that explains it, thanks. Not familiar with the 35E cells, and thought they were similar to 30Q’s - should have checked HKJ’s site for Infos! Now I can relax, knowing that I haven’t been sold duds!
The GT isn’t a high drain light. With 4 cells in it, at most each cell pulls 3 amps. With 8 cells each one only pulls 1.5 amps at most.
So it was decided that a higher capacity cell (3500mah) would be a better match for this light compared to a high drain cell like the 30Q (3000mah). You get more run time in total.
I do get that the light isn’t going to draw a lot of current, with only a single XHP35. But in a previous thread (about the Emisar D1?) it was mentioned that although high drain cells weren’t required, they were nevertheless recommended, due to the lower voltage sag. But with only 1.5A drawn from each cell, I guess we’ve probably entered the area where even voltage sag becomes negligible, if I understand correctly?
The GT was tested with 30Q and Panasonic 3500mah cells (2A at the emitter). Which should be pretty close to the 35E cells.
You’ll note that with the 30Q it stays in regulation a bit longer due to less voltage sag, but the 3500 cell has longer run time. So it’s a bit of a tradeoff.
I assume you mean the springs are not compressed enough to keep the battery from wiggling side to side?
This is normal. The carriers are designed for both short and long “protected” cells. So that is about 65mm to 71mm. With a short cell the spring is only partially compressed.
