Both are listed - in fact also another one (older one with 2$ higher price but also working).
It’s best to use search function (Ctrl-F in most browsers) and check for all deals in first post.
New headlamp from Xanes with 2x XP-L2 LEDs. It’s now in preorder: first 50 pcs for $12.99, up to 500pcs for $13.59, then $16.99 and final price is supposed to be $25.49.
2x Cree XP-L2 CW
2 Aluminium OP reflectors
1x18650 power supply
6 modes with stepless dimming
micro USB rechargeable
max output up to 1650lm (with decent high drain battery - Samsusng INR18650-30Q is suggested)
Apparently there’s no moonlight if the description is accurate. Lowest setting seems to be ~200lm
This however looks like a nice candidate for modding - I was thinking XP-L HI CW with reflector for throw in one socket and high CRI Nichia with TIR Optics as second LED for close range flood beam.
(the charging design looks the same, even the headstrap color looks the same; and the pre-order price is almost similar to the price of the Boruit one)
The Boruit product page mentions “L2 beads” (probably mean ‘LEDs’), but doesn’t specifically say “XP-L2” whereas the Xanes one does.
The Banggood Xanes model’s picture of the LED doesn’t seem clear enough to identify if it’s really XP-L2 or not (and it does not indicate “Cree”).
It’s possible there’s an OEM manufacturer for the same type of headlamp/headstrap though…
Too bad i was thinking use it as midnight pee light.
Ya, dual LEDs has more possible ways to mod. You have great idea combining xpl hi and high cri nichia.
I would suppose L2 beads means XM-L2 and this is what the LEDs look like in the pictures linked @aliexpress. Whether those are authentic Cree is different matter - they can be some lower bin as those are cheap enough already.
I could not find production lamp with that combination. I like the idea of Nu25 - nice combo with small package, but still would want a single lamp with XP-L HI and Nichia with TIR optics (like in NC TINI) as it would be much better and brighter than used COB LED.
