https://www.amazon.com/UltraTac-Flashlight-Rechargeable-Ultra-Compact-Waterproof/dp/B078WV27B1
Rechargeable too. Nice pocket clip. I like it. Looks decent.
Really like it too, looks handsome and is really small. But I would need some feedback on the user interface before I would buy it.
Looks quite nice. 99mm long and a nice square-shaped anti-roll head design.
I’d be onboard if there were NW/WW option…
Well I put one in my Amazon cart. The wife has a few things she needs to shop for and add as well. As soon as she is done shopping it will be on the way. Guess I will find out if it’s as cool as it looks.
Good find thanks for pointing it out.
I agree with others here 100mm is a nice shorter length, plus it has a deep-carry clip.
But I need to know the CCT, and how the (H-M-L-Strobe) UI actually works.
But I’ll admit I haven’t had time to even start reading the reviews (nearly 100) EDIT: 96 reviews for the K18, only 1 review for this! I think it’s too new.
I’d love to try it but I need a source that is not Amazon.
Actually I do not see why some chinese sellers sell exclusively via Amazon, they throw away three quarters of the global market.
Gearbest has a few models, K18 I think almost 3 years, maybe we can get them to stock some of these too, maybe one of the aff linkers here can request it.
But I still need to know the UI first.
Also I see that KD has all of the Ultratac line, so we will probably see this one there as well sometime.
http://www.kaidomain.com/Search/SearchResult.UltraTac
EDIT: I’ve asked in the KD thread, BanL keeps up with that. KD (kaidomain): Deals and new products thread - #912 by beam0
Unfortunately all of the Ultratac line has Cool White tint. So I seriously doubt this one will have that option.
I’m thinking this probably has the same UI as the K18:
Frpm UPz’s K18 review (2017): [Review]UltraTac K18 v2017 (XP-G2 S4, 1x AAA / 1x 10440)
- On and off: To turn on the flashlight, we must press the digital switch for half a second, and repeat the operation if we want to turn off the flashlight.
- Changing modes: With the flashlight on, simply click on the digital switch to change modes, alternating between the three intensities in ascending order: L-> M-> H
- Memory: The K18 features mode memory function. This is remembering the last mode we used prior to its shutdown, and turns on it on its next power up. The memory is maintained even if, when the flashlight is off, we remove the battery.
- Strobe Mode: Like other small AAA flashlights, we have a hidden stroboscopic mode, which we can access if we make a quick double click with the flashlight on.
- Lock-out: As I mentioned, the new K18 v2017 can be electronically locked to prevent accidental activation. Simply make a double click from the off to lock and unlock it. Of course, we can continue blocking the K18 v2017 by a slight unscrewing of his head.
- Low voltage warning: When using a 10440 the new K18 v2017 will warn us when the battery voltage is too low, going to low mode and performing a triple blink every approximately 5 seconds.
^ thanks for the UI.
Hmm, if I read this well it seems there is no option to avoid memory and go directly to the lowest mode.
(I often want low without getting blinded first and with my memory it is best to avoid it)
Hmm . . . ran across this light in the KD thread. I’d be interested if it did NOT have memory (or simply a way to force it on in low level first) and had a NW option (or at least knew it was an easy emitter swap).
Keeping an eye on this,
-Garry
Keep in mind this is not for sure the UI, but most likely:
It’s listed at KD now: http://www.kaidomain.com/p/S027575.UltraTac-S20-CREE-XP-L-1100-Lumens-4-Mode-Rechargeable-Pocket-EDC-LED-Flashlight
Could somebody make a comparison with Sofirn SP32A?
https://www.aliexpress.com/item/Sofirn-New-SP32A-Powerful-LED-Flashlight-18650-Cree-XPL2-1500lm-High-Power-Two-Groups-Light-Torch/32836337317.html
I have the SP32A only, I think this Ultratac S20 is relatively new, only one review on amazon and no reviews anywhere else I could find.
Differences from what I see already:
Sofirn is longer length. (122.7mm vs 100mm)
Sofirn has NW emitter (CCT Range): 5350K-5700K (Neural White) Apparently Ultratac is CW.
Sofirn has 2 mode groups, regular and ramping, Ultratac only one group, no ramping.
Sofirn in regular group has 5 levels (LL-L-M-H-Turbo) Ultratac only 3 levels (L-M-H) Both lights have Strobe.
Sofirn has quick access to turbo (double click from OFF or any mode)
Sofirn has metal switch, Ultratac appears a rubber cap.
Sofirn is brighter and has the latest Cree XP-L 2nd generation, Ultratac has older version Cree XP-L:
- Sofirn:…….XP-L2………1500lm
- Ultratac:… XP-L V3……1100lm
So the Sofirn is better, unless your main concern is length and you don’t mind CW tint and the lower max output.
I like just 3 modes, length is critical to me (18650 lights are on the border of pocketable), and I can replace leds myself. So that makes the S20 more interesting to me than the SP32A. Critical as well is direct access to low mode from off, that still has to be confirmed.
Wow, sounds like you (djozz) and I have similar taste in EDC’s - direct access to low, no memory, LED swappable to our own choice, simple 3 (or maybe 4) modes, as short as possible - just add deep pocket clip availability to that list for me. I know it’s anathema, but I’m actually not carrying an EDC much anymore because I need to find something shorter than doesn’t bother me in my pocket. Phones keep getting larger which means more of a problem carrying my EDC light. I started trying to put the light in my rear pocket, but that’s not always comfortable either. I might try going to a belt clip/pouch.
-Garry
