“Any random person needs to be able to use the Q8 without a manual.”
(No - this is a specialised light for a niche market, clear from the outset, if it is being sold OUTSIDE THE FORUM’S CONTROL as something else, that is not the fault of the forum)
If you want anyone to be able to use the light, turn it to a medium setting and then turn it off. The next time it is picked up one click goes to medium, one click to off - no problem.
“I (after considerable initial research) bought (ordered) these as emergency lighting.”
They are great for this, but apparently your considerable research did not identify that it had many modes and functions all accessed through the same button, but despite this, only a few seconds instruction about what not to do are required. Don’t hold the button down after it has stopped ramping, and if something does not seem right, unscrew the tail and reset. There- you’re done.
All of your frustration seems to stem from your own misunderstanding of the potential problem, and your stubborn insistence that it must be everyone’s problem and it must be someone else’s problem to sort it out to YOUR satisfaction.
Jumping Jesus!!! I can’t help but wonder what would happen if this was a topic of conversation on a gun forum. Passcode protected, modes for the uninformed, fire warnings, random citizens using it……………….Oh to heck with it, here’s a bat, get out of here.
We have been struggling with that you know. We designed the Q8 for our own niche market but of course we knew that it would be sold outside BLF too. Although what Thorfire does with their own products after the group buy is their responsability, but we did insist that in the description on the seller’s page all the information and links were present to be able to judge the features and possible safety concerns
Yes, this is rather funny. I get that the Q8 is fairly easy to get into a programming mode you didn’t intend, but it’s intended for flashaholics or a least people that RTFM. No newb should not buy or use a 4x18650 light, without understanding the dangers and proper methods of dealing with lithium-ion batteries and high-power lights. This is not a light you lend to a neighbor’s 5-year-old child.
And, yes, it’s ridiculous that someone thinks this light should be redesigned to make it idiot-proof. There are already hundreds of idiot-proof lights on the market. Buy one!
As for this light, if you’re uncomfortable with it, throw it away! You’re out $50, but that’s probably cheaper than burning down your house because you turned it on high and left it under a pile of newspapers because you thought all lights should be able to do that.
The guy made an assumption - despite reading the material that should have cleared it up. He is now frustrated, and is venting that frustration by passing the buck. Most people can relate to some time when they have done that themselves, only to realise, sometimes much later, that they had lost all perspective and objectivity and were fixating. Happens to the best of us at times, I think it is best to remain civil and resist any urge to make things worse by adding ridicule or caricaturing the person involved. This may be a significant investment for him that has, in his eyes, been a failure. A month from now he will probably have taken a step back and re-evaluated.
Remember if he bought several of these lights plus batteries and chargers, he could easily be out of pocket $200-$400.
What dangers, could you briefly point them out? All I can think of is the fire hazard if the light is activated on full accidentally and left lying somewhere it shouldn’t be.
(Yes, I’m a newb who bought his first soda can light).
And a couple questions on batteries for Q8:
Why do you recommend protected batteries when the light already has built-in undervoltage protection?
Why do you recommend Samsung 30Q, the notorious high-current batteries? This flashlight does not seem to require high-current cells:
The LEDs are rated as 10W. Say, you over-drive them to 15W. 15W / 3.7 V = 4.05 Amps. Divide by 80% driver efficiency (a pessimistic figure, hopefully), and you get just a bit over 5 Amps per LED. Four LEDs, four batteries. Any regular non-high-current (5 A) battery should suffice, as long as you’re running all four. Where am I wrong? Does each LED consume more than 4 A in turbo?
Well, there’s all the inherent risks of using lithium-ion cells. Treat them properly, and you’re probably fine. But, treat them improperly, and there may be a safety risk. There are tons of threads on proper 18650 care, so you’re probably already aware.
There have also been reports of what happens if you accidentally insert one of the 18650 cells the wrong way into the Q8. It goes bang, and fries the springs. That’s if things go well…
And, as you note, this light can catch stuff on fire if you hold flammable things close to it on max. Or burn a hole in a bag that you’re carrying the light in and the switch is accidentally pressed.
Some of those are common issues with all high-power lights.
I don’t, but protected batteries will prevent shorts as mentioned above, so are better for safety.
This light uses a direct-drive when on high. That means that the higher the voltage of the battery, the higher the output of the light. High-drain cells have less “voltage sag” when driven hard, than regular cells. So, a high-drain battery will give you higher output.
If this light used a boost-driver for regulated output, then lower-drain cells might be okay. But, that’s not how it was designed (probably because of cost).
Thorfire did one single test with a full run on maximum.
As far I remember it run ca. 40 min till the temperature starts to fall.
Don’t know which batteries they used. I assume 3500mAh ones.
The light survived.
So the lamp should cope with the heat.
That 30 second idea sounds good. 8 seconds can be accidental by someone trying to see if it will go higher, they will have given up on that idea long before 30.
Protected cells usually have four or five different protection circuits. Over discharge protection is just one of those.
With a direct drive light the internal resistance of the batteries plays a major role in the output of the light, so does the forward voltage of the emitters, the chemical mix of the batteries, etc…
If you look at the 30Q and the Sanyo GA both batteries can easily output more than 5 amps, but if you put them in a Q8 you will get a higher amp draw (higher lumens) using the 30Q compared to the Sanyo GA (maybe 500 lumen or more). A protected Sanyo GA might loose 1,000 or more lumen to a 30Q. The protection circuitry typically adds a lot of internal resistance.
Look at this chart here.
The more you study direct-drive lights the more you’ll start to see how the battery directly influences the emitter.
You can’t even run the Cree xhp50.2 direct drive, even on little 18350 celks in series, because it will pull too much current and blow the emitter.
I guess Tom E. used 8sec to be able to switch quickly between RAMPING and MODES.
The sequence to change is:
Hold the button till it blinks the first settings, then one or two clicks and then hold the button till the lamp confirm with four blinks.
In retrospect I think it would also better to change the first setting to
1 click = RAMPING
2 clicks = MODES
Today it’s reversed.
Only for the reason RAMPING is mostly used and people try to switch off the lamp if it starts blinking.
Gotcha, thanks for the reply.
So the turbo mode is just shoving as much current down the LED’s throat as it the Ohm’s law will let it. Is that safe for the LEDs? Not that I’m concerned, I personally don’t intend on using that mode for prolonged periods of time, just curious if the LEDs may degrade when used like this, or Cree is just being super conservative in rating XP-L at 3 A max.
Thanks for the chart. By the way, I have never seen a high-current protected battery, by the way. My local battery shop that’s known for selling original Korean and Japanese cells does not have them, and by “local” I mean it’s probably the best in the country. It only offers protected 5A cells. But I assume protected 30Qs do exist.
Assuming I will not insert the cells the wrong way into my Q8, do you think protected batteries are a must? What kind of protection do you think is the most useful for Q8 as far as preventing undesired situations?
Yes, the leds may not reach the rated 50,000 hours. But also, in the Q8 and many other modern flashlights, the leds are mounted with an extreme good heat path away from the led, that makes a huge difference while the Cree specs do not take that into account. On this forum we test leds in that environment and find what the real performance is. But we do not see yet what happens after a few thousand hours.
If a LED ever getting dim after a few years you can swap it out with a new more efficient one.
In the Q8 modding thread there are 3D printed protection rings which make sure a flat top (or reverse end) doesn’t make contact.
Or you fit something into the head which is ca. 0.2mm higher then the brass contact ring. If the nipples are higher than 0.3 the batteries make contact.
Lock the lamp out when you transport it. If its lying on the floor of a car and it rolls around, it can switch it on by its own weight.
That’s pretty much it (on a FET driver).
Turbo mode means the FET is constant closed or 100% duty cycle (I hope that’s correct) so it’s like a solid wire from the LEDs to the battery. You can partially limit current through resistance. Smaller guage wire, resistance in springs, resistance in the FET, different batteries, etc…
Other driver types, Constant Current, Buck, Boost have controllable max outputs.
The protection circuits add a lot of resistance so it defeats the purpose of using a high current cell. You typically see high mAh batteries used with protection circuitry. (EDIT:Imalent has protected 30Q cells rated at 15A)
Any type of protected battery in the Q8 would probably limit it to 4,000 to 4,500 lumen I’m guessing. That’s still pretty bright. If your not after the most lumens and prefer safety, then using protected cells are a good idea.
It’s still not going to allow a high amp draw on turbo, though due to the extra resistance.
On other driver types, the extra resistance from the protection circuitry doesn’t hurt performance at all.
Typical things the protection circuitry does is prevent:
Over charging (stop at 4.2v)
Over discharging (stop at 2.5v or similar)
Over temperature
Over current
Reverse polarity
Side note:
No batteries come from the manufacturer with protection circuitry. It is only added by other companies and the little circuit boards can vary from one company to the next. You can have the exact same battery with protection circuitry added by two different companies and have two different maximum current limits.
