What did you mod today?
Emitter swap.
Out: XP-L Hi cool, in: Nichia E21A sm203 R9050 warm! on my custom 119 board trimmed to shape to fit in the pill, center piece was left out to get the emitting surface of the (lot thinner) new led in the focal plane of the reflector.
Old output: 600-ish, new output 260. Max. current on a fresh battery 2.5A. Spot is smaller but spot brightness seems not much different. Beamshot is at 2.5 meter. I especially like the efficient performance on lowest setting: 1.5 lumen at 6.7mA current, so that should run for 4 days on a 700mAh 16340.
Thanks for the tip :wink: I will take a look on that!
BTW, does the reflector work well with the XPL-HI LED?
I tried to use it with other leds (not the stock one) and I was getting some rings on the beam.
I then opted for a Luxeon V under a Pebbled TIR lens (the 16mm MCPCB was also trimmed)!
Thanks, yes I trimmed it a bit by hand. And reamed out the holes in the pill a bit to accomodate the higher gauge wires.
Wow, nice mod as well. You seem to mod one every day :wink:
Is that a white wall?! Weird looking die. That’s a very nice warm nightstand light, but not really an efficient one :person_facepalming:
At lowest ‘nightlight’ it is pretty efficient for such a warm 90CRI led actually, but it is a small battery of course.
It is a white wall and an extreme warm 2000K led :slight_smile:
MascararumB, reflector works great with the led. But that’s me not being a beam profile snob. It throws nice though with a usable hotspot.
However I didn’t perfectly center the led.
I filed down the noctigon asymetrical and it was a snug fit to the pill. So the led couldn’t center very well. But for me its okay.
I looked at the luxeon V as well. Nice led, but I had this one still lying around. Also I don’t know if it can mess with the illuminated tailcap.
Yes I would call that extreme haha. Nice, I hate all these cold blue lights.
But 260lm at 2.5 Amp is a bit steep for daily all round usage… But nice for nights at home! Where’s the wine bottle? :wink:
Here’s the led & beam at 2.5mtr MascaratumB:
Thanks for your answers and pictures Dutchee! I guess that being XPL-HI doesn’t create the “rings” that I saw in mine with the XP-G2 and the Luxeon V, before the TIR.
Even not being completely centered as you said, there is not much “noise” in the beam! Nice work once again :wink:
I am tempted to get another Tool AA to do something similar to what you’ve done :wink:
Unless LT releases a differente version of the light with some corrections (UI, Driver, LED :p)
Thanks again mate :wink:
Two Cafe lights from used materials (except the drivers and the LED module):
More Info:
Swapped out the led in my T20T with an old dedomed sst-90 4500k. Results are not quite what I wanted, the tint seems a bit green to my eye’s. Plus the firefly mode doesn’t light up the new led. I think I’ll try a different led. The led shelf had a step in it so I lathed the shelf flat to suit the larger led.
Haven’t seen one of those for a while.
An SST-90 still looks cool!
Yeh, I actually like the look of the led itself :sunglasses: but in this situation not much of it can be seen.
Simple mod today. Installed 219C 4000K into Lumintop Prince. Also added spring to the driver, so flat-tops work now.
Album with pictures
^ nice pictures!
Got a really neat little Thorfire TK05 in the mail yesterday, a friend liked it so much he sent me one to play with so he’d get a better idea how he wanted me to mod his own. lol
So I pulled the XP-G3 and replaced it with an XP-L V6 3D on a Noctigon sized to fit, that helped a lot but it was still somewhat anemic. So I build an FET+1 driver and flashed Anduril and now it does 1386 lumens out the front. :slight_smile:
Anduril allows controls on the floor and ceiling of the ramp so it’s easy to set it up for the high end of the ramp to be more gentle on the cell and not make so much heat, a quick double click yields full Turbo if needed.
And lightning/candlelight modes make it exceptionally sweet for EDC! :smiley:
… DIY Hard Boiled Egg Patina on my Copper Lumintop Prince …
Hard Boiled patina ages nicely. I treated the top CU a year or so ago and bottom CU I just treated overnight.
^ pretty. Is there a way to keep it that way? (a coating of some sort?)
Sure. You can use many transparent spray-lacquer.
Olight Prince sure is an unknown model :innocent:
