Light Meter question
16 posts / 0 new
beam0
beam0's picture
Measuring Range:
2000/20000/100000 Lux
200/2000/10000 Fc
MAX and MIN Reading Hold Function
Would this meter (above) work for basic output measurements and comparisons, or would I need the LX1330B?
LX1330B: https://www.amazon.com/dp/B005A0ETXY/ref=sspa_dk_detail_1?psc=1&pd_rd_i=...
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
kiriba-ru
kiriba-ru's picture
Last seen: 22 min 1 sec ago
I dont use it much, but as many members Im happy with uni-t lux meter bought for ~$13 from BG.
Link UT383 Digital Mini Lux Light Meters Environmental Testing Equipment Handheld Type Lux Meter Illuminometer https://banggood.app.link/Iuh4RaPbqL
beam0
beam0's picture
kiriba-ru wrote:
I dont use it much, but as many members Im happy with uni-t lux meter bought for ~$13 from BG. Link UT383 Digital Mini Lux Light Meters Environmental Testing Equipment Handheld Type Lux Meter Illuminometer https://banggood.app.link/Iuh4RaPbqL
Thanks, looks like it’s $16.99 now (Reg. $22.91) https://www.banggood.com/UNI-T-UT383BT-Bluetooth-Digital-Luxmeter-Illumi...
Some mixed reviews about it in this thread: http://budgetlightforum.com/comment/1140983#comment-1140983
Also would it be better to have the split meter? (sensor separate on coil cord)
moderator007
moderator007's picture
Last seen: 4 hours 13 min ago
If you think you will ever build a integrating sphere, yes.
beam0
beam0's picture
Yes good point. I didn’t think of that, I may someday build the PVC pipe version.
moderator007
I have been doing my homework on building one myself. It be interesting to see what some of my mods are gaining.
Winston Wulf
Winston Wulf's picture
Last seen: 1 year 4 months ago
At the end it depends on what you expect:
- you want to “compare” certain lights on similar levels? Then it might be ok
- you want to “measure”? Then all of the described models are just crap
After studying all the different models, the possibilities and limits, you will get a different view on all the “measurements” that some people take as “defined”…
But as I said: if you want to compare, it will be good enough.
Always be yourself. Unless you can be BATMAN.
Then always be BATMAN.
beam0
beam0's picture
Yes just to compare certain lights on similar levels, mostly at maximum.
Although wouldn’t I be able to measure (at least ball park) by using an ANSI rated light from a reputable company as a reference point?
Also what model(s) do you recommend for taking more accurate measurements?
Enderman
Enderman's picture
Last seen: 1 hour 20 min ago
Someone on TLF did a comparison of multiple cheap luxmeters (not including this one) but the LX1330B was the most accurate when compared to a professional $1000 luxmeter.
beam0
beam0's picture
That I didn’t know, thanks!
Enderman
Enderman's picture
Thumbs Up
http://www.taschenlampen-forum.de/threads/luxmeter-check-1-6-ger%C3%A4te...
Agro
Agro's picture
Last seen: 40 sec ago
Thanks Enderman!
BTW, quite a few people use HS1010A which can be bought for <$10.
Enderman
Enderman's picture
You’re welcome.
My LX1330B has been working great the past few years.
I’m considering also buying a uni-t one to have a second point of reference, also it will match all my other uni-t measuring tools Smile
djozz
djozz's picture
Last seen: 27 min 19 sec ago
I never saw that TLF test, but the test results of the LX1330B look almost too good, my variety of budget luxmeters are way more off than this one! It made me order one (at DX) to check that out (on more varied led sources than the TLF test).
Enderman
Enderman's picture
Thanks, I’ve seen your luxmeter reviews and wondered why there was no 1330B when it’s one of the most popular budget ones.
Looking forward to a second set of data for comparison Smile
beam0
beam0's picture
Agro wrote:
Thanks Enderman!
Really? I was also looking at those:
https://www.banggood.com/HS1010-HS1010A-LCD-Digital-Light-Meter-Illuminance-1-200000LUX-p-932711.html?cur_warehouse=CN
https://www.aliexpress.com/item/Hot-Sale-200-000-Digital-Light-Meter-Lux...
