For the Thorfire C8.
What is the colour temperature of the LED?
I don’t see it in the description.
Thanks
I would suppose L2 beads means XM-L2 and this is what the LEDs look like in the pictures linked @aliexpress. Whether those are authentic Cree is different matter - they can be some lower bin as those are cheap enough already.
petemer: DENGOH:For XANE D25, may I know what is the lowest output for its moonlight mode?
Apparently there’s no moonlight if the description is accurate. Lowest setting seems to be ~200lm
This however looks like a nice candidate for modding - I was thinking XP-L HI CW with reflector for throw in one socket and high CRI Nichia with TIR Optics as second LED for close range flood beam.Too bad i was thinking use it as midnight pee light.
Ya, dual LEDs has more possible ways to mod. You have great idea combining xpl hi and high cri nichia.
I could not find production lamp with that combination. I like the idea of Nu25 - nice combo with small package, but still would want a single lamp with XP-L HI and Nichia with TIR optics (like in NC TINI) as it would be much better and brighter than used COB LED.
For the Thorfire C8. What is the colour temperature of the LED? I don’t see it in the description. Thanks
Looks like standard 1A cool white tint.
There are some reviews at youtube:
(this one complains about no waterproof rating - there was no info Amazon but
BG it says IPX-8, and was tested - even freezed in next video)
Niwalker MM18JR(72) 2x XHP70.2+1x XHP35 HI 10000LM Brightness Triple Switch Design LED Flashlight
Coupon code with nice discount is available.
» Request via PM here«
Miboxer C4-12 LCD Display USB Rapid Intelligent Charger For Li-ion/IMR/Ni-MH Battery 4Slots US Plug
Coupon code with discount is available.
Miboxer C2-4000 LCD Display Rapid Smart Battery Charger For 16850 26650 Battery 2Slots US Plug
Miboxer C2-3000 LCD Display Rapid Smart Battery Charger For 18650 26650 Battery 2Slots US Plug
Xiaomi 240LM Stepless Dimming 11 Modes 3350mAh USB Rechargeable Mobile Power Mini LED Flashlight
Designer multifunction flashlight from Xiaomi with head rotation dimming feature. It’s also USB rechargeable and have built in powerbank function.
White body is made of aluminium - not plastic.
It’s now in preorder for $16.99 (first 50 pcs), then price will go up gradually up to $19.99, target price is set at $29.99.
Astrolux MF-01 18x XP-G3/Nichia 219C 12000LM Super Bright LED Flashlight 18650
It’ now in preorder for $77.99
Shipping should start on April 3rd
Convoy L6 XHP70 3800LM Super Bright Long Range LED Flashlight
Coupon code a60080 has just been renewed: lowers the price to $52.76 / $55.96 ($13.19 /$13.99) depending on LED tint.
XANES HX2 XP-G2 S3 1000LM Brightness Mini LED Flashlight With L Shape Head Light 18650
New dual head 18650 light from Xanes is now in preorder - first 50pcs for $19.99, then price will rise gradually up to $22.99, target retail price suppossedly set at $32.99. Both heads - straight and L-shaped are included, headband as well.
Klarus ST15 Xp-l Hi V3 1100LM Classic Tactical Setting LED Flashlight
Astrolux K1 Bronze XP-G3 350LM USB Stainless Steel Mini LED Keychain Gift Collection Special Edition
It’s now in flas sale for only $15.99
Offer ends in 1 day and 8 hours.
Ideal for all steampunk fans out there BTW - any other non-custom steampunk flashlights out there? I know of exactly… none
Use coupon code ODLIGHT to lower the price by –20% from $20.99 (already dropped from $26.60) to $16.79
- 36 separate chip COB LED
- CNC aluminium body
- great 180 degree visibility
- max 50lm
- 4 modes (2 constant + flash + breathing light)
- max runtime 50h (flash mode)
- 600mAh battery built in
- USB rechargeable
- automatic brake light (built in acceleration sensor no brakes connection needed)
- weight: 45g/1.6oz
Rofis MR70 XHP70.2 CW+XP-G2 NW 3500LM Dual Light Multifunction Rechargeable LED Flashlight +26650
Better coupon code is available.
:arrow_right: 26650 5500mAh battery is included.
LUMINTOP HLAAA Headlamp XP-G2 R5 120LM 3Modes Mini LED Flashlight AAA
This is the version with bundled headband.
Can i get the code for LUMINTOP HLAAA ?
PM sent.
Nitecore HC65 XM-L2 U2 1000lumens Triple Output USB Rechargeable LED Headlamp +18650
- max: 1000lm (main LED)
- min: 1lm moonlight
- additional flood 26lm high CRI COB LED
- auxiliary 11lm red LED
- 3400 mAh 18650 cell included
- USB rechargeable
- max runtime: 800h
- constant current driver (no PWM)
- 5 constant main LED modes + 2 auxiliary modes + 4 special (3 white and one red blinkies)
- built in LED power indicator (shows voltage accurate to 0.1V)
- full metal construction (alu with HAIII finish)
