Thrunite TC20 - XHP70 - 3800lm
The 70.2 is a flip-chip technology emitter, meaning the connections are on the bottom of the chip, no bond wires. As such you can clear more of that phosphor away, right up to the edge of the die itself, and this clears up a lot of the yellow aura. Also helps to tighten the hot spot.
I bought a scalpel and a lot of blades for it, have found that if I hone and polish the scalpel blade and use a bit of silicone grease on it the resulting slice across the die face to remove the dome is nice and smooth…. it takes a single stroke slice action, not a push but a slice across in a continuous motion, this nets the smoothest cut for me and the result is a nicer beam profile. YMMV
Here’s a 50.2 in a little copper X5…
Hmmmm a square MCPCB? mine is round on the one I have.
EDIT: komeko , Am I missing something or is that really the centering piece that came in your TC20? Mine has a perfect round one like it should that came in the light.
Here is the LED in my TC20 as Dale mentioned in his post above after I sliced and diced it…………
And here is what the beam looks like at 20 feet on medium / High / Turbo ….(Exposure cut back a little so pictures didn’t wash out)
And here at 100 yards from gate on High and Turbo with normal settings I use on all my beamshots…….
This or the Rofis… This or the Rofis… or this or the Astrolux MF-01… (they’re all close to the same price)
So, if ya’ll had ~$75 to spend on 1 light, what would ya’ll get?
The TLC forum has already reported that the first versions had a round tile and the newer ones have a square one. Picture from that forum:
Further shaving of the diode will not do anything, it will blow yellow and that’s it. I am waiting for a new diode 3A and then we will see how it will be.
At this point, all my flashlights have the same color as in the chart:
Everything under the BBL line is cool. H03 has a very delicate bile symptom, so small that it practically can not be seen.
I’ll see what I can do to make TC20 like it too :slight_smile: Maybe the N4-3A diode will be what I need.
robo819, and you shaved CW or NW?
Mine was NW. Maybe CW is better after shaving.
Not shave the emitter more , but get right to the very edge of the die itself and get all of the yellow off the edges of the substrate, that is where the biggest part of the yellow comes from. Mine was a yucky mustard yellow almost when I sliced the dome only , but then the tint changes considerably when the extra yellow is taken off the edges around the main die.
I just used an Exacto blade and cut straight down on all sides of the die to the substrate and then gently used the back of the Exacto blade to remove the excess phosphor around the edges , being very careful not to hit the phosphor on the die itself.
Mine is / was cool and yes the cool is much better for shaving or dedoming as a neutral will end up too warm most of the time
Rofis does not have NW, it’s just cold white and I do not like it. Of the two, I would choose MF-01 but UI is bad so I would probably change the driver on NasilM
I wait for those too :slight_smile:
Mike
Isn't a square one less efficient because of less mass? Just wondering if Thrunite was cheaping out on the new batch.
It is not less efficient. What counts is the rate of heat dissipation on the casing, and this ensures copper and good contact (paste and pressure). The surface itself no longer matters, especially such a size difference.
komeko, thanks for the explanation
Call it like you see it I guess, I sure wouldn’t power up a 70.2 on that square MCPCB. The larger round MCPCB makes more surface contact with the host body, I usually recut the emitter shelf on an L6 so it can take a 26mm MaxToch MCPCB for example, then push it to 20A or more for in excess of 9,000 lumens. Depends on how far you’re taking it of course, but I like to use maximum contact surfaces… go big or go home. :wink:
That's why I asked the question as it did not make sense in my mind to make it square, thanks DB!
OK, I have not followed thread recently. But I see a lot of MODS that were done to improve light? I will order the TC20 CW version. What should be done for better throw, tint color, spill? OR leave as is. Anyone on here with keen knowledge or do MODS for small fee? Please advise. Thanks.
Any tips on getting the bezel off? Does it just screw off with enough force?
Rofis MR70 and TC20 are similar, but those two are quite different from MF-01
Do you want a fat body super flooder? Then get the MF-01
If you want a light for an all-around use that’s a nice size to pocket and carry? Then the MR70 or TC20.
  • TC20 shorter length than MR70
  • TC20 better knurling than MR70
  • TC20 has NW option, MR70 does not
If you’re OK with the above differences and you really like that diffuser side light, then get the Rofis.
My personal choice between those two? …TC20
….And after you buy the TC20 you can begin saving up for the MF01 :smiley:
Thrunite got me anyway, the Catapult V6 announcement got me by the short hairs and I pre-ordered immediately. :stuck_out_tongue:
The Catapult V6 looks like a great light for the size.
Then again, so does the TC20. :wink:
To be honest, they got me with the diamond knurling, the big diamond block knurling. I’ve got normal knurling on most everything, but only have that diamond look on one or two and I’ve liked the Catapult V5 for a long time, just never got one. So now they’ve made it compact, 26650 WITH included cell, and built in charging at 2A, utilizing the XHP-35. How could I resist? AND they’re offering the same 20% discount as on the TC20, win win either way, so while I already have plenty of general purpose style lights for out here in the country a compact thrower is a welcome addition.
