Light Meter question
Measuring Range:
2000/20000/100000 Lux
200/2000/10000 Fc
MAX and MIN Reading Hold Function
Would this meter (above) work for basic output measurements and comparisons, or would I need the LX1330B?
LX1330B: Amazon.com
I dont use it much, but as many members Im happy with uni-t lux meter bought for ~$13 from BG.
Link UT383 Digital Mini Lux Light Meters Environmental Testing Equipment Handheld Type Lux Meter Illuminometer https://banggood.app.link/Iuh4RaPbqL
Thanks, looks like it’s $16.99 now (Reg. $22.91) UNI-T UT383BT Bluetooth-Digital-Luxmeter, Mini-Lichtmessgerät für die Umgebung Sale - Banggood Deutschland-arrival notice-arrival notice
Some mixed reviews about it in this thread: BLF style 18650 1s thrower( poor mans Olight M2X) - #407 by luminarium_iaculator
Also would it be better to have the split meter? (sensor separate on coil cord)
If you think you will ever build a integrating sphere, yes.
Yes good point. I didn’t think of that, I may someday build the PVC pipe version.
I have been doing my homework on building one myself. It be interesting to see what some of my mods are gaining.
At the end it depends on what you expect:
- you want to “compare” certain lights on similar levels? Then it might be ok
- you want to “measure”? Then all of the described models are just crap
After studying all the different models, the possibilities and limits, you will get a different view on all the “measurements” that some people take as “defined”…
But as I said: if you want to compare, it will be good enough.
Yes just to compare certain lights on similar levels, mostly at maximum.
Although wouldn’t I be able to measure (at least ball park) by using an ANSI rated light from a reputable company as a reference point?
Also what model(s) do you recommend for taking more accurate measurements?
Someone on TLF did a comparison of multiple cheap luxmeters (not including this one) but the LX1330B was the most accurate when compared to a professional $1000 luxmeter.
That I didn’t know, thanks!
:+1:
Thanks Enderman!
BTW, quite a few people use HS1010A which can be bought for <$10.
You’re welcome.
My LX1330B has been working great the past few years.
I’m considering also buying a uni-t one to have a second point of reference, also it will match all my other uni-t measuring tools :slight_smile:
I never saw that TLF test, but the test results of the LX1330B look almost too good, my variety of budget luxmeters are way more off than this one! It made me order one (at DX) to check that out (on more varied led sources than the TLF test).
Thanks, I’ve seen your luxmeter reviews and wondered why there was no 1330B when it’s one of the most popular budget ones.
Looking forward to a second set of data for comparison :slight_smile:
Really? I was also looking at those:
