petemer
(petemer)
March 21, 2018, 6:18pm
925
Xiaomi 240LM Stepless Dimming 11 Modes 3350mAh USB Rechargeable Mobile Power Mini LED Flashlight
Designer multifunction flashlight from Xiaomi with head rotation dimming feature. It’s also USB rechargeable and have built in powerbank function.
White body is made of aluminium - not plastic.
It’s now in preorder for $16.99 (first 50 pcs), then price will go up gradually up to $19.99, target price is set at $29.99.
» Jump to First post quick links/deals list «
petemer
(petemer)
March 21, 2018, 6:41pm
926
petemer
(petemer)
March 21, 2018, 11:28pm
927
Convoy L6 XHP70 3800LM Super Bright Long Range LED Flashlight
Coupon code a60080 has just been renewed: lowers the price to $52.76 / $55.96 ($13.19 / $13.99 ) depending on LED tint.
petemer
(petemer)
March 21, 2018, 11:39pm
928
XANES HX2 XP-G2 S3 1000LM Brightness Mini LED Flashlight With L Shape Head Light 18650
New dual head 18650 light from Xanes is now in preorder - first 50pcs for $19.99 , then price will rise gradually up to $22.99, target retail price suppossedly set at $32.99. Both heads - straight and L-shaped are included , headband as well.
petemer
(petemer)
March 23, 2018, 3:44pm
929
petemer
(petemer)
March 24, 2018, 5:39pm
930
Astrolux K1 Bronze XP-G3 350LM USB Stainless Steel Mini LED Keychain Gift Collection Special Edition
It’s now in flas sale for only $15.99
Offer ends in 1 day and 8 hours.
Ideal for all steampunk fans out there BTW - any other non-custom steampunk flashlights out there? I know of exactly… none
petemer
(petemer)
March 24, 2018, 6:07pm
931
Infun F50 50LM Automatic Brake Induction 180° Floodlight Taillight 45g 4 Modes IPX5 Waterproof USB Rechargeable
Use coupon code ODLIGHT to lower the price by –20% from $20.99 (already dropped from $26.60) to $16.79
36 separate chip COB LED
CNC aluminium body
great 180 degree visibility
max 50lm
4 modes (2 constant + flash + breathing light)
max runtime 50h (flash mode)
600mAh battery built in
USB rechargeable
automatic brake light (built in acceleration sensor no brakes connection needed)
weight: 45g/1.6oz
petemer
(petemer)
March 26, 2018, 2:26pm
932
petemer
(petemer)
March 27, 2018, 11:14am
933
Nicolicous
(Nicolicous)
March 27, 2018, 11:17am
934
Can i get the code for LUMINTOP HLAAA ?
petemer
(petemer)
March 27, 2018, 1:49pm
936
Nitecore HC65 XM-L2 U2 1000lumens Triple Output USB Rechargeable LED Headlamp +18650
Coupon code with discount is available.
» Request via PM here«
max: 1000lm (main LED)
min: 1lm moonlight
additional flood 26lm high CRI COB LED
auxiliary 11lm red LED
3400 mAh 18650 cell included
USB rechargeable
max runtime: 800h
constant current driver (no PWM)
5 constant main LED modes + 2 auxiliary modes + 4 special (3 white and one red blinkies)
built in LED power indicator (shows voltage accurate to 0.1V)
full metal construction (alu with HAIII finish)
petemer
(petemer)
March 28, 2018, 12:43pm
937
petemer
(petemer)
March 28, 2018, 12:56pm
938
petemer
(petemer)
March 29, 2018, 10:00am
939
petemer
(petemer)
March 29, 2018, 10:30am
940
petemer
(petemer)
March 29, 2018, 10:28am
941
petemer
(petemer)
March 29, 2018, 10:53am
942
Naturehike Outdoor Bicycle LED Headlights Tent Lamp Rechargeable Lithium Battery Camping Lamp
It’s now in direct promotion until 31st March for $10.99 (-$9.00 )
This is quite interesting outdoor light with very versatile mounting options: can be used like headlamp, tent light, has detachable spring-loaded clip for clothes etc. and hanging hook doubling as a stand. Has two light options: spot and flood light and is USB rechargeable.
petemer
(petemer)
March 30, 2018, 10:49am
943
Astrolux MF02 XHP35 HI 3000LM NW Long-range Searching LED Flashlight 1587M
Use coupon code 85dd97 for massive $45.96 discount.
Note: code only works for neutral white version.
Limited pieces.
petemer
(petemer)
April 2, 2018, 8:44pm
944
Nitecore TINI XP-G2 S3 380LM 4Modes USB Rechargeable Mini Metallic Keychain Light
» Detailed review with TIP comparison and great photos by Budda here «
Cree XP-G2 S3 LED
max 380lm
built in 280mAh li-ion battery
micro USB rechargeable
4 modes (380lm, 145lm, 38lm, 1lm)
Low -> Mid -> High mode order
TIR optics should produce nice uniform flood beam
up to 60h runtime
up to 365 days standby
backlit dual buttons with power indication
7 colors available (black, blue, red, green, gold, silver, grey)
