Discussion of compact size production throwers 700m+ under $60
Good point about the step down, yes need to consider.
I’m not completely sure but I think the D1S can keep up with that 3 minutes of the UT02, plus it’s user-adjustable in the firmware.
(Quote from TK’s review):
Thermal Regulation:
“it might not activate on the D1S at all, because the host is almost perfectly tuned to handle the heat on turbo without getting too hot.
However, the temperature limit is user-configurable, so you can tune it to fit your preferences”
Thanks for pointing out. I didn’t look into it in the review, just comparing Mfg. specs. first, but I had a good feeling it was over rated.
Another vote for the D1S. Hard to beat that UI and the quality.
I’m pretty sure at one time there were deals on it for around $30, now I’m seeing around $40, if you know the lower deal can you post a link to the deals thread?
Also why the UT02 over D1S?
It’s probably going to end up being between the D1S and UT02.
Catapault V6… hasn’t a NW option and almost double the price.
Maeerxu M8… the UI may not be good, ramping only (slow) and no pre-set group.
It has better feature like 26650, USB charging, batt low indication on switch and XHP35 HI.
Ya, nowadays its price stay around $40, very close to D1S. But its feature is much superior in my opinion. But I don’t configure FW much, I just use the flashlight.
Design wise I think UT02 is more handsome too.
In this thread you have shown the turbo time for D1s:
LINK
UT02 is better for me because it has a better battery, longer working time, quality of finish, USB charging, the ability to work in turbo without going down, voltage stabilization so practically constant output level. You do the R100 mod and you have a small sweeper.
Hmmm, UT01 and D1S are the same price.
I have to consider then,
  • UT02 bigger - longer and fatter head.
  • 26650 makes it feel less compact in size, but provide a lot more runtime.
  • USB charging I don’t need, but could come in handy on camping trip for instance, to charge from vehicle.
  • Batt level indicator switch is nice too, at least D1S blinks, but only shortly before shutdown:
    “The light blinks and drops brightness at 3V to warn users of impending darkness. There is low voltage protection at 2.8V when the light turns off”
  • I need to know why XHP35 HI is better than XP-L HI? Lumen output is the same on UT02 and D1S both 1300lm, does it have more spill beam?
  • It’s okay to have extra settings in the firmware, once you get it set up how you like, then you just use the flashlight :slight_smile:
Kicking myself though now for not getting UT02 when it was (I think) $29.99 :person_facepalming:
Yes good points, thanks.
Well you could build one, convoy c8 host 11 dollars, fet driver 7 dollars. Xpg2 dedomed 6 dollars all from rmm. Add a couple dollars shipping for around 30 dollarsish you have a 700+m pocket thrower that won’t step down unless you want it to.
Do you have BLF GT? All flashlights are featherweight nowadays if you ever hold a BLF GT, just kidding :sunglasses:
At least UT02 is not overdriving XHP35 HI to get that output, I think I measure about 12.6V of Vled for its Turbo mode. I don’t have D1S, I am not sure its output is sustainable to drive XP-L HI for that output.
Smaller die. Smaller die with equal lumens will result in higher lux, which is what matters with throw
Yes I’m going to have some fun doing that eventually, I already have most of those parts. :slight_smile:
But right now I want to try a compact side switch thrower - stock off the shelf.
Here’s the tail switch throwers I have on the shelf to mod/build:
(Some from long ago and some newer)
  • Convoy C8
  • UltraFire HD2010
  • SupWildFire
  • LuckySun D80 BLF
Planning on XP-L HI w/FET driver and XHP35 HI w/boost driver for these.
I already have a few FET/DD drivers w/Dr. Jones guppydrv.
I think Xpg2 dedomed beam is thin? (don’t want a pencil beam, I’d like some decent useable spill)
I also might try to do something with my long 2-cell side-switch thrower: Small Sun ZY-T13
D1S does seem compact though, this photo makes it hard to resist:
I’d love to see a photo of the D1S along side a UT02, looked around a while but haven’t found one yet.
I bought UT-02 last December and the quality was way lower than my first, half year earlier.
  • Very dusty inside reflector
  • battery tube would have too long thread, leading to large gap between it and the head. There’s a lot of mess gathering there, I need to file it down eventually
  • USB cover is very flimsy. Once I dropped it on gravel when twisting the light to mechanically lock it.
The first and the second are easily repairable. The last one is actually the most severe and I don’t have a fix for it.
And after complaining to GB it turned out I paid $14 for it. Try to beat it for that price…
Overall I still love this light. My first was stolen and decided to buy another rather than Emisar. But considering the quality drop and the price hike (it’s roughly as much as Emisar now), I would probably trade USB charging, constant-current driver and better battery capacity for better host quality, better UI (I actually like that of UT-02 but Emisar is better) and lighter / more compact body.
There is a photo where you can see both flashlights. In the Ma02 test for MF02:
LINK
The head sizes are fairly similar for UT02 and D1S. What benefit is there in having thinner 18650 tube behind such a wide head? Neither are particularly pocketable. I would much rather have extra run time of 26650 in a light with that form factor.
The UT02 form is my favorite modded, I have put just about every emitter you could put in the UT02 from MT-G2 XHP70.2 XHP50.2 XP-L HI XP-L W2 (domed/de-domed) and an old school de-domed XP-G2 pulling 6.3amps. With Lexels T/A 30mm drivers and Narsil UI and lighted switch. I run 2x26350’s for the XHP’s and run 26650 26700’s 21700’s and 20700’s in the other 3v emitter lights. I was never happy with the stock UT02/XHP35HI but with Lexels 1S boost driver at 3amps, I have one stock UT02 sitting here waiting on this driver.
To me the D1s is not attractive at all… :confounded:
Good find, thanks!
The D1S might look shorter though since it’s position is in front of UT02, but that does give an idea of the size difference.
