UT01 needs button top correct? MTN has been out of stock on the button top Efest for a long time, so I was getting the Windyfire’s because they describe them as “outperforming the Efest”:
Richard hasn’t released his boost driver yet, close though, it’s done well in testing so he’ll be listing it soon.
I go the TK05 in the mail today, on a Windyfire fresh off the charger (first avialable 14500 I saw) it makes 579.6 at start and 508.9 at 30 seconds. The beam profile is ugly with the XP-G3 though. Jaxman’s choice of emitters make for a much better overall light without the need to modify it.
Jaxman has good tints but tend to use XPG’s instead of XPL’s, and they don’t like to drive their small lights too hard. So they end up wanting power modded. I think the E3 would be a much better overall light if it had it’s current output levels, plus an added high/turbo level of 500-700lm
I have PKCell 14500 (which are flat-tops), and they work intermittently on my couple of UT01 (more often than not, the flat-top 14500 does not work, or if it worked, slight shaking the flashlight will turn it off and not work).
so many threads in so few days…I cant read and reply smoothly, it will need too much time to read every threads carefully……
the middle modes is powered by PWM which works at 500 Hz, and it will not be seen by your eyes. but maybe seen by a camera, and I think the middle mode will be seldom used in most time, so I choose PWM for a convenience. The low and high is not PWM.
hi, the design of anti-reversing of battery forbids full flat batteries to work.
So flat 14500 batteries can not be use in this flashlight. You can use 14500 with a little higher cap like AA batteries, and I have this kind of 14500.
if dears cant get the battery,I can give you as a gift——need you leave a word in your order—-only few pcs this battery.
while,if you use 14500,the E3 will lost low and middle modes, it will be only one mode—high mode.
I am worry about if you can know what I am saying…
I want learn a good English ability from all of you.
I found it is hard to get the truth ability of foreign languages if you are not live in the place of that language.
Ok, since all of us are the man who love DIY, I fully understand what dear all are thinking.
Host is not a problem. but need some time, now we are too busy to making business. Later, we will make a link for the host.
Thanks! I’ll likely order one and leave a message to request for button-top 14500… Hope shipping flashlight+battery to my country won’t be a problem (unlike shipping of pure batteries)…
