I’m just personally not very interested in the XHP35-HI version. I jumped on the first C8.2 because I tend to reach for high output lights because they’re fun. It also suits my purposes because I didn’t need throw, but I wanted at least a little more reach than my BLF A6. To me, the C8.2 with the XHP35-HI is in a weird spot because it’s a large emitter made for more throw, but the C8.2 doesn’t have a reflector large enough to really leverage it and you’re probably getting less throw than something like a D1S. So it’s basically for people that don’t need an incredible thrower and value overall brightness, but feel the XHP50 variant is just a bit too floody. Again I’m not one to value throw highly, but if I were to use the XHP35-HI I’d get it in a larger reflector
I do love the C8.2 though especially how it barely warms up even when hitting 2k lumens. The beam is very like the BLF Q8, but in a smaller form-factor. It is sad to see people experiencing issues with Kaidomain though. My only issues have been slow shipping times and missing or unusable tracking #s.
Man I’m happy for you, I wish mine worked but things just haven’t worked out. I had no recent correspondence regarding a replacement so I filed a charge back through my credit card company per PayPal.
Still sad it didn’t work out, but I guess I’ll just turn it into a xpl-hi and fet combo
Apparently not, I believe it employs the H1-A driver, and there’s nothing shown about step down in its description either.
According to this statement in post #57 of this thread the H1-A doesn’t have step down, only LVP@3V:
“H1-A maintains regulated output until input voltage hits 3V, at which point it begins to taper the output down as to maintain the 3V on the input, it cuts off somewhere below 100mA on the output, once input can no longer hold 3V.”
Also in this driver thread the KD’s H1-A and H2-C are the first two drivers tested, he shows a step down for the H2-C but not for the H1-A.
I guess that could be a good thing or a bad thing, depends how you look at it.
I have a S2+ and some P60’s. I will give you my thoughts when I get back in town tomorrow evening.
The size of the C8.2 is small enough for a side carpenter pocket. I have been running it on low or low2 since it is very bright up close on high.
Later
I have an KD Xhp-50 (5k) C8.2 and it is quite a bright, wider beam. After several months of observation, this light is a SOLID 100 yrd. thrower with a LOT of side light (and in a clear field, I’ve used out out to 200 yards, but most here would argue it’s too faint that far out— but works for me through a better scope just fine). The C8.2 5K XHP 50.2 has a beam very much like the C8Fs (or my Q8) with regard for over-all beam width and decent throw— it gets out there nicely for most needs. Not as bright as the two aforementioned lights, but close- and with the about the same throw too.
But, when I compare my three other C8s: Sofirn C8A, C8T and my custom SST in a Sofirn C8s host, sst-50 (shaved dome with Lexel’s Bistro driver)— these lights all out-throw the C8.2 by about 40-60 yards. The C8T has the XPL HI…V3 I think in it, but it (ironically) doesn’t throw much better than the C8A (which does throw REALLY well for the XP-L2 it’s using). When I compare the C8A and C8T, I actually prefer the C8A for it’s (95% to my eyes) equally good throw and the tint is warmer— I LIKE it more too after comparing to the cooler tints the warmer C8A is the favorite. (I totally expected to pick the C8T over the C8A in no time flat- this was a surprise).
My custom SST-40 shaved LED is still very white- the “shave job” didn’t change the tint OR throw much. It throws about the SAME as the C8T, but it’s got a lot of blue in it (as the C8T also has). It has a more narrow bean (as expected) along with the C8A and C8T as well. All good lights, but for the more general “wow factor” the C8.2 does burn brighter than any XLP or XP-L2 C8 I have IF looking at those first 100 yards.
The KD light is well done and I am sorry to hear of these problems as I thankfully have had none. IF KD were into supplying pills and some parts they feature in this light, it would be WAY MORE POPULAR here at BLF. Their site may have them but I can’t find them and shipping is proving (again this month) to be especially SLOW lately. I got a notice my March 29th order shipped out 20 days later (and so I do not have it yet of course). But my other order made 5 days later got here last week!
So no rhyme or reason on shipping, but I’d guess KD will made good on any problem light. Mine ALSO held up on my GUN for 50 rounds or so— zero problems. WHEN I FINALLY GET my late order— I plan to test several sofirn C8F custom builds (with 3 XPL-HIs still coming… from KD) in ONE of them— the other already floated and packing 3 shaved XP-L2 V5 emitters on an MCPCB (but waiting on a driver) ).
Always waiting on parts But I’d bet KD gets it sorted for any problems with enough time— good luck! :+1:
