Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
Got my S2+ pill and M2 quad spacer today. Everything was packed nicely and tracking was accurate. Waiting for some LED4Power parts to arrive before I can complete the quad build. Will follow up after it’s assembled.
Got my p60 copper slug, q8 ring and thanks for hooking me up with the brinyte b158b pill.
You rock!!! I will be definitly buying more items in the future.
Just got my order, after many post office delays, here they are
I got my M2 quad together. It’s running LED4Power 12A driver, 4x Luxeon V on his MOSLED board, and his lighted tail switch.
It’s hard to tell if the O ring is being fully compressed but I can tell it’s at least getting some pressure so i’m not going to be concerned with water resistance. I’m not planning on submersing this in water.
Kiriba-ru did mention that the spacer is meant to not fit “snug” which surprised me at first. However, with thermal paste on both ends of the spacer and everything screwed down I don’t think anything is going to move and I’m getting ridiculous thermal transfer to the body. The light will get hot from head to tail if I let it.
I did ream out the middle hole with next size up drill bit I could find in my tools but only because the LED4Power setup requires 2 LED wires and 3 other ~24G wires for FET,Moon,Temp parts on MCPCB.
Ceiling bounce numbers:
Constant Current 12A setting: 4,000 lm
Direct Drive setting: 5,385 lm (@ turn on)
Moon is just a little brighter than my D4 Nichia.
It does 4,000 lm for about ~75 seconds before stepping down to 1,000 lm. I let it run 5m total and it never stepped down from 1,000 lm but the body was not comfortable to hold at this point.
A few questions about C8TT
next bach will be anodized in black or not?
can i use with 17mm driver without 20 to 17 adapter?
can i use with default lens instead of AR?
In my opinion the Head looks really nice, good work kiriba-ru!
According to current demand, next batch would not exist.
You can use 17mm driver if you solder it to the retaining ring.
You can use any suitable lenses. My idea was to supply most part so you could build second head and swap it when it is necessary.
Just received the new Quad M2 kit. Everything arrived in awesome packaging as always.
Thanks!
First post updated with actual quantities.
Found some old items in my garage:
HD-2010, P60, SK68
PM if interested.
I’ll take the P60, PM sent, thanks.
I received my order today, very well packaged, it took 20days to Australia
@kiriba-ru
I find these plastic boxes you use for shipping your orders very useful for storing bits and pieces of flashlight projects. Can you post a link to where you get them?
http://m.fix-price.ru/catalog/item/5069213/?cat=52&sub=123445
Cool, if they ship internationally maybe I’ll try to get over there via google translate XD, thanks
This is local $1-shop. I soppose you can find something similar in your country.
Ordered 4/25, they shipped the next day and arrived today. Wicked fast shipping from clear across the world.
Thanks for the good quality pieces kiriba!
Any C8 triple spacers left? I’m not sure if the dimensions have changed or not but looking to make a desert sand Convoy C8+ triple.
No.
I was not sure that there is any need in spacer since cheap triple sofirn host is available.
Also I dont think internal rivalry with C8TT is a good idea.
One hd2010 pill
One sk68 pill
are waiting for your offers.
PM sent for 2 P60 pills.
