So I’ve bought four Samsung 30Qs, and I’m underwhelmed at the Q8 light output compared to two and even one regular 5A Sanyo batteries that I’ve been running the light with previously. To be precise, I don’t see a difference between 2xSanyo and 4xSamsung 30Q. All fresh out of charger, of course. Also, I don’t see a difference between 4x30Q and 3x30Q. Should I be able to see it? I know naked eye is very poor at spotting small-ish differences, especially when comparing sequentially and not side by side.
And a related question. As I ramp up the Q8’s output, at some moment just before the max brightness is achieved, it blinks shortly. Is it when it switches to direct drive? I don’t see a difference between the flat-out max mode, and the closest ramp-down mode (just before the light blinks). Do you guys see any difference there as you ramp your Q8 up?
You probably won’t see a difference in brightness between 2, 3, or 4 cells. You should definitely notice a difference at 1 cell, when it will only be about half as bright at maximum.
This is a bright light, at over 5,000 lumens, but don’t expect a blinding light. It’s equivalent to about 3 or 4 100 watt light bulbs. So, a fairly bright room.
The light blinks when it finishes the ramp to maximum. You won’t see anything when it switches from the linear driver to the direct drive, which occurs much closer to the low-end of the range. You can tell when you release the switch, though. If the switch blinks once, it’s using only the 7135 linear driver. If it blinks twice, it’s using the FET direct drive.
Didn’t torture a single cell. Meh, I was lead to believe the number of cells does have an impact on the absolute max brightness, as does the type of cells (regular vs. high current). Thanks for clearing that up for me.
You mean incandescent lights? Makes sense, with about 10x efficiency for LEDs vs. bulbs and considering that each LED in Q8 is well over 10 W.
So the linear modes are PWM free, and direct drive modes are PWM?
They do, but your eyes are not that good at measuring it. The difference between 5k and 6k lumen is hard for human eyeballs to see especially when you have to take a break to change out the batteries. You have to remember what the first brightness level was as your looking at the second brightness level.
A lux meter would definitely see the differences as would an amp meter measuring the current.
I’m talking high-drain only. If you try 2 vs 4 regular cells, you probably will see a difference. There’s also a difference between 4 regular and 4 high-drain cells, though you probably won’t be able to tell with your eye between battery changes.
Also, the battery voltage makes a huge difference. You’ll only get full output if your cells are fully charged to 4.2v.
IIRC, PWM is used for all modes, unless you’re right at the output max for the 7135 or FET. It’s very high frequency, so you won’t be able to see it. Perhaps you might notice on moonlight, but that’s probably the only mode.
Gotcha, thanks. Yes, I understand how difficult it could be spotting a difference in light intensity with a naked eye, definitely could use a lux meter.
There is even a special flashlight app for that: search for ‘ceilingbounce’. It makes use of the same phone sensors as the various luxmeter apps so in accuracy it is not anything special but it has all sorts of nice features that makes flashlight measurements more convenient.
Great idea! I have went as far as installing a couple lux meter apps, but I didn’t find a suitable piece of semi-transparent material to cover the sensor to prevent it from saturating. Totally didn’t think of bouncing the light off the ceiling.
I have two of them, and on one of them the green light on the button started to flicker and eventually stopped working after the first week or so. Not a big deal, still works great, and I love the Q8!
Lol sb, I thought you were replying to raccoon city. I thought, at first, you were talking about having two trolls. I really need to switch to decaffeinated coffee.
I have a question - how does stepdown act when in ramping: for example what does it do when it’s set to about half output and set to 5 miutes stepdown? what about thermal stepdown? I know it steps down on turbo according to settings, but what happens at lower levels? Thank you!
