The most important point - the output far below the promised 7.500 lm - will not change due to the low binning of the used XHP35. Please check TA’s statement. The MT09R with XHP35 will never reach much more than something around 4 klm and was never able to do more.
Please define “soon” - I do not think that every single new MT09R-owner will take a soldering iron and will change the electronics by himself.
Keep in mind: we also have the warranty-issue - what happens, if somebody kills his flaslight during this process? Who will pay for this?
A statement will not create a flawless flashlight…
I thought I read in TAs posts that he reached about 6k lumen with the default XHP35 in the delivered lights (EDIT: OK, it was the stock lumen value measured by TA on the 35). Still not what has been promised but at least better. If there will also be a new driver for the 35s (looks like) TA could also use better binned 35s. He’s planning to do that with the 70.2 to reach those 23k lumen he mentioned.
With soon I mean in the next few weeks. As TA has already posted in this thread the new driver will most likely be ready end of next week. But only he can give you an update on the current status.
The warranty issue is still a valid point, as not everyone is able to change the driver on their own (including me). Not that I have my 35 anymore, right Tombstone?
But exactly this warranty issue is why we need a statement from Dale here…
But your wrong in one point: the statement from Dale itself will of course not fix the light, but it would be a first step. All the flaws we have at the moment can be fixed with TAs driver. Now we need to know how Haikelites plans are for future production units and more importantly for the units already delivered.
I’m always excited about Haikelite new releases as the company aims to make stellar performing products (although some bugs in this round). It’s not the SC26 right? Also I’m glad to hear Haikelite is not going to discontinue the MT09R. The 70.2 flashlight is a monster light with the best practical beam I’ve seen. Very long reaching throw and great flood to illuminate the entire scenery in front of you. With v2 release, hopefully they also use a higher binned XHP35 to produce 7k+ lumens w/ 1,000+ m throw. I might buy another one or two of them.
4k or 6k…the thing here is everyone in the german TLF measured only about 4k lumen with the 35, while Terry and TA measured something about 5.5k to 6k. That’s where Winston Wolfs statement comes from.
Regarding your last two sentences: shouldn’t the light from the group buy already be the final one? *jumps into cover
7500 lumens does not look possible with Hi emitters, even though it should be on paper. I think it is because the highest output xhp35 HI’s are higher Vf then other LED’s and we can’t drive them to the max in a triple and the lower Vf LED’s are not as high output.
With some E2 bin LED’s I think it managed somewhere between 6500-7000 lumens, I did so much testing I forgot the exact numbers. I know I saw 7k at one point but I think I was overdriving them.
The stock LED’s are maxed out at 6k lumens on my meter (do note that my meter tends to read a bit lower then others as a rule). Even on my bench power supply they simply have nothing more to give. Once again I didn’t keep good records of this testing as speed was more important.
Really the advertising on these was done prematurely. They should of waited to see the real numbers and not just used the paper numbers. Even I am a bit perplexed at not being able to hit closer to 7k easier but then I have no idea what bin these LED’s are. They are not D4/E2 that is for sure.
I just got the PCB’s for the driver in and spent the last 3 hours putting 6 drivers together. Now taking a break and about to start working on the firmware, gonna have to start over since I am adding a second channel to the V2 version.
Ok, I just remembered that Terry sent me both a CW and NW 35 HI light for testing with the driver. I just put some freshly charged 30Q’s in both of them and tested them bone stock with the stock driver on my sphere.
I got ~5500 lumens with the CW and ~5700 lumens with the NW.
Edit: Just tried the NW with a bench power supply and it maxes out around 6300 lumens on my meter at 9A.
That reminds me of asking you to get me the new driver for my friends 35… :sunglasses:
@ SKV89:
This was a misunderstanding - I referred to Phils statement regarding the output. Here in the TLF none of the lights reached much more than 4.000 lm, so this is what I compare to the 5.500-6.000 lm mentioned by TA. The 7.000 he indicated are in combination with the new driver AND the new LEDs - so I expect something around 5.000 lm max, but with a completely refurbished flashlight that has nothing to do with stock.
Or the XHP35 in the US are already “newer” versions nearer to the spex? I do not know and I also do not expect this, because the one Wieselflinkpro received just these days was sent far after CNY…
Don’t get me wrong - I would have loved to see the 7.500 lm. But while the XHP70.2 is a real bomb (from my point of view already from the beginning - I only count output, heat or so is less important for me personally), the XHP35 is a pain in the part of the body you sit on.
It is not uncommon now days. The CW usually gets a ~10% advantage due to meter bias but I have seen 80CRI LED’s that give almost the same lumens as higher bin 70 CRI LED’s (such as the XHP70.2’s I am using that are only 1-2k lumens less then I expect from P2 bin 70 CRI).
This is mostly due to the Vf of the LED, the neutral LED’s are simply pulling more power if I had to guess. Once again it is pretty common for wamrer tints and higher CRI LED’s to have lower Vf and thus pull more power.
Specially when the manufacture (CREE) of the LED rates (CW) Higher in out put. So I tend to disregard everything else, seeing the manufacture has lab equipment for measuring out put. I don’t think (Cree) they use really cheap light meters from Bang-U Good or Fastech?
You are comparing the wrong LED’s. you should be comparing this 4000k P2 bin xhp70.2 to that 5700k P2 bin. Both of which are rated exactly the same, in which case the +/- 7% tolerance that they have makes it luck which one is brighter all else being equal. The warmer versions generally have a bit lower Vf as well.
You are also not factoring in the lower Vf that the warmer / high CRI LED’s generally have in order to reach the efficiency guaranties set by cree. With a regulated driver this is a non-issue but with a FET Direct driver driver such as these the warmer LED’s generally pull more current. That extra current = more lumens and the outcome in my L6 for example is around 30% more current with 80cri LED all else being the same.
The net outcome was a bit over 9k lumens with the 70cri and around ~8500 lumens with the 80cri. It is not an equal test in that they are using vastly different power levels to reach those numbers but it is real world results. Which is what I was talking about earlier. Interestingly, the lower Vf of the 80cri meant that the overall efficiency was actually not that much worse then the 70cri version.
In the MT09R, the stock LED’s were pulling 25-30A and my 80CRI LED’s are pulling around 40A.
Now, when it comes to the stock LED’s, we have no idea what the bins are on the LED’s. They are not top bin, that is for sure. So it is probable that the NW are simply a higher bin LED, and thus get higher lumen numbers. Although the numbers are so close you would not notice the difference anyways.
Okay I finally for to test one of TA's new drivers and keep in mind this is version 1 he is currently perfecting version 2 which will be a bit better.
I plan to go out and take a little video footage and try to get it posted ASAP.
Narsil at it's best at full ramp on the 35 high version 5590 lumen, a quick double click and go into turbo and I was easily getting 6450 lumen using one of my better matched sets of 30q's. I can promise you that all thermal protection works perfectly. You can almost bank on the the step down when it get to set temp.
Originally I was going to do this with an upgraded set of emitters but there were some light issues with the emitters not the light or driver so I just removed it from the test light and place it in a totally new stock factory light with factory emitters. Cool white.
I do still have a few available that will be fitted with TA's driver when it is completed that will be sold a special TA edition MT09R. Keep in mind that the drivers are not free I have to pay for them like everyone else if ordering from TA. And I do believe I would prefer my own to be hand assembled by TA.
I’ve been meaning to ask… can someone who has both a CW XHP35HI and a NW XHP35HI describe, or post a photo of, the colour difference between the two? As I showed in my post #1251, the “NW” that I received looks very much like a CW (cooler than a CW Acebeam light I have), so I’m wondering if the CW XHP35HI looks about the same, or if it’s even cooler than my very cool NW.
One calculation I forgot. I just measured it 3 times at 5 meters using 2 different meters and it's right.
Keep in mind this is using TA's version 1 driver in a 35 high MT09R
Total lumen output for the version 1 driver I have been playing around with is 6500... It will be extremely hard to get very much more without overdriving the LED's.
The overall output for a thrower is not nearly as important as what is actually designed to do which is throw.
So far it's easily 1000 meter thrower.
That video I really wished I had put a camera much closer to the target so it would show a little better just how well at 822 yards it can easily light it up.
If time and local law enforcement will cooperate I may do that shot again. But if you can see it on camera that is at the same distance as the light you can bank on having made the grade.
At 5 meters I got a reading of 11300 lux... if you understand how to do the math double check. Lol I did 3 times with 2 meters.
I was sent one of both for testing, I have not tried them side by side yet but one after the other there is a noticeable difference but the NW is on the cooler side of Neutral I would say for sure.
There is a variance in the tint of LED’s in general and seeing as these are pretty low bin, I am guessing that the binning is also not very tight. So this is not very surprising.
