Assuming the battery tube, switch/driver/led housing is the same as the MF02, would a kit to upgrade with the reflector/housing/lens/bezel assembly be considered?
I’m in position of the GT and to be honest mine just measured over 1Mcd and I know a few guys who measured just below 1Mcd. I will say the average output will be 1Mcd. Maukka for instants measured it 860Kcd at maximum ramp (2A). Using a distance of 6.1 meters which is also not far enough to get the real lux value. I’ll say a proper distance for this type of light will be 15 meter plus to get accurate reading. Remember the measurement was also not taken at turbo (2.5A). The turbo is not really that much improvement either. Could properly add another 5% onto it.
