BLF After Dark, CSS theme
143 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 11 min ago
Got a little distracted, but the meter works now too.
Not that it didn’t work before. It was just bright green. Smile
hank
hank's picture
Last seen: 9 hours 49 min ago
I lost track of the discussion about blocking signature files, pointer welcome, I am sure it’s in another thread but search isn’t finding it for me.
ToyKeeper
ToyKeeper's picture
http://budgetlightforum.com/comment/965782#comment-965782
I’ll copy it here:
ToyKeeper wrote:
hank wrote:
Uncluttering help?
I haven’t figured out a way to choose to block large volume signature lines that repeat every time.
You can do it with a CSS override, same as the site theme I made. However, it’s all very manual and can’t be triggered on a “sig too long” condition. Instead, you can hide signatures on a per-user basis or a per-content-type basis. If three people’s sigs bother you, you can hide only theirs. Or if you want to block all images in signatures, you can do that. Or perhaps all tables in signatures.
For example, to block all images in signatures:
div.clear img { display: none; }
Or to block several people’s signatures:
div.posted-by-54321 div.clear,
div.posted-by-65432 div.clear,
div.posted-by-76543 div.clear
{ display: none; }
hank
hank's picture
Ahhhh, that works. Text I had long since memorized no longer appears every time.
Now, to program my glasses to filter out certain billboards and t-shirts …. oh, wait, that’s science fiction ….
And nobody has invented not-hearing-aid filtering either, just yet.
LG
Last seen: 5 days 7 hours ago
This is awesome. Thank you!
ToyKeeper
ToyKeeper's picture
I’m not a fan of bright white high-contrast web designs. I find it more more comfortable to read some dimmer lower-contrast greys.
Kinda goes with being photosensitive, I guess. I can see well in the dark, but I can’t really see during the day unless I have dark sunglasses.
Pete7874
Pete7874's picture
Last seen: 34 min ago
Kudos for this After Dark theme! I always wondered what dark skinned BLF would look like.
Thank you!
Pete7874
Pete7874's picture
TK, Which line do I edit to change the color of the “NEW” and “UPDATED” markers that show next to thread titles? It currently shows as deep red and I find it hard to see, probably due to my partial color blindness.
EDIT: Found it. It's this section:
Quote:
span.marker { color: #9e0000 !important; font-variant: small-caps !important; }
ToyKeeper
ToyKeeper's picture
Ah, interesting. Those only appear in a part of the interface that I don’t use. Hadn’t even noticed those were there.
The “new” markers I configured are bold black text on a red shadow. Thin red text on a grey background was probably inherited from an earlier version a few years ago, before BLF’s code got updated.
I’ll have to remember to fix that.
Pete7874
Pete7874's picture
Another question: product descriptions below images in the screenshot below are unreadable. They do become readable when I hover my mouse over them. How do I change that font color in your CSS?
Thanks!
Link to that specific thread, although it’s not the only one with that issue:
http://budgetlightforum.com/node/57247
ToyKeeper
ToyKeeper's picture
You can probably do something like this to remove the shadow from links in those posts…
/* override style for people who insist on using too much CSS in their posts */
div.posted-by-9004 a {
    text-shadow: none !important;
Pete7874
Pete7874's picture
That helped. Thank you.
puglife2
Last seen: 1 hour 42 min ago
So nice! thx Big Smile Big Smile Big Smile
ToyKeeper
ToyKeeper's picture
There are still a few bits here and there which aren’t re-styled correctly, but it mostly works. Some of the table border lines, in particular, haven’t responded easily to overrides, and I haven’t tracked down the reason why.
I also have a few little extras locally, like to remove the search box. I had kinda forgotten it’s even there, since I’d rather type a bit more during a search than have the widget always taking up space.
ToyKeeper
ToyKeeper's picture
Le sigh.
New Drupal, gotta redo the theme again.
Maybe in a few days. That blood moon eclipse was exhausting, so I’m taking some extra time off.
Stylish became malware/spyware, and was removed from Chrome’s extension library. Use Stylus instead.
puglife2
also stylish was removed a month ago from firefox and chrome web store due to security issue
ToyKeeper
ToyKeeper's picture
Hmm, it may just be that. I forgot to update to Stylus on this computer, and it appears to have finally disabled itself.
Last night BLF was really really slow and it seems magically better today, and the style override stopped working, so I thought it was a server-side update… but it may just be an outdated client.
DB Custom
DB Custom's picture
Last seen: 37 min 44 sec ago
Screen…
… so
………bright!
Aaaaaggghhhhhhh!!!!
ToyKeeper
ToyKeeper's picture
Okay, confirmed. BLF’s stylesheet didn’t change… it’s just that Chrome-based browsers started disabling Stylish because it was bought and became spyware.
So, to get things working, uninstall Stylish, install Stylus instead, and do everything else the same as before.
DB Custom
DB Custom's picture
Thanks TK, screen looks SO much better! Big Smile
shirnask
shirnask's picture
Last seen: 2 hours 5 min ago
Thumbs Up
Coscar
Coscar's picture
Last seen: 2 hours 18 min ago
ToyKeeper wrote:
install Stylus, and do everything else the same as before.
Sorry my CTE is acting up Tired but I am unable to get this to work. I have Stylus installed and enabled. I am still using FF56 cause anything later breaks 90% of my addons. I had Stylish working before FF disabled it … I tried to read the whole thread but it only confused me. Can you point me to a post that specifically explains what I need to do or maybe provide a CSS file that I can import? Thx TK
Im not a Pessimist …. just an Optimist with a lot of experience
Pete7874
Pete7874's picture
FYI, I use FF56 as well.
If you already have Stylus installed and enabled, then go here:
https://userstyles.org/styles/124240/blf-after-dark
And then click “Install Style”.
IIRC, that’s all there is to it.
At this point you can further tweak it to your liking. For example, I made some of the colors slightly brighter as I was having a hard time seeing certain text.
Coscar
Coscar's picture
Thanks Pete…. I was playing around with it before I read your post and I got it to work although I am not sure if it is safe.
I re-enabled Stylish and exported the BLF info, then imported that into Stylus and disabled Stylish again …. I checked and it is working like it used to BUT is that okay or is some of that code vulnerable?
Edit: After doing the above and reading your post I went to the http://budgetlightforum.com/comment/1358466/edit link you provided and clicked the link ‘Install style as userscript’ ………. would that have overwritten the other script? Sorry for the confusion…. CTE makes my brain disfunctional! Tired Tired Tired
Thanks for the help
DB Custom
DB Custom's picture
Being awake makes my brain dysfunctional… Sick
mkdive
Last seen: 6 months 3 weeks ago
I have PC using chrome….I went to here and clicked install (that was it). Works and is much nicer.
DB Custom
DB Custom's picture
right mkdive, get used to it and then lose it and you’ll find the normal screen kills ya! lol
hank
hank's picture
Here is the page with extension links for installing Stylus for Chrome, Firefox, and Something Else (icons, upper right)
https://add0n.com/stylus.html
When I go to get the “after dark” script, for some reason all I get at
is a spinning beachball “wait” cursor, right now.
hank
hank's picture
TK, is userstyles.org having collywobbles lately? I can’t get in, haven’t gotten a password reset, and get a beachball cursor trying to search for “BLF
There’s recent interest in this from people who saw me mention using it to eschew tedious signatures, and I’m just as confused as the next user about how to revive my old Stylish script. I did see mention of how to convert, I“ve got to go read that.
I did get Stylus extension to install in my Firefox (Mac, 10.12.6)
jon_slider
jon_slider's picture
Last seen: 10 min 44 sec ago
Ive installed Stylus on Firefox Mac (thanks hank!) and have used code from ToyKeeper (thanks!) to hide all signatures on BLF
the app is here
https://addons.mozilla.org/en-US/firefox/addon/styl-us/
the code is this:
.forum-post-content > div.clear { display: none; }
and figured out how to Completely Hide posts by any member, with the following code:
/* Someone */
div.posted-by-54321,
div.posted-by-54321 { display: none !important; }
to get the user ID you want to block, hover over their handle and read their number
then replace the 54321 placeholder
