that ebay alternative is driven only 1.4A and probably worse quality
That is a C10 model.
There are dozens of C8 and several C10 designs on the market, so there are plenty of "alternatives".
There's isn't a runtime advantage in the 1.4A since the ones driven at 3A can be used on medium for the same output, (50% of 3A).
Is this then the best-built C8 on the market? It's certainly not the cheapest, but I'm looking for something in this form-factor that's nicely made.
I have been very well impressed with my XinTD C8. I bought one when they first came out. It looks, performs and feels like it should sell for more money.
I see that the current batch has the well respected 105c driver.
If there is a better C8 on the market, I have never seen it.
Is this legoable with other C8s? From KD, etc? Say I want to change just the body tube (which I might, since I'm not keen on the logo.)
Not great. KD "C8" XM-L (noname) and Ebay UF C8 XR-E are substantially different. Different reflector and different pill .... not interchangeable. Total length is different too.
A lot of C8's might look the same, but have different measurements, especially on threads and diameters. I've had 3 different brands and there is very little interchangeability.
The XinTD is refered to as a "C8" only because of its general size and shape and 42mm lens and reflector. The actual model number is SC-82.
The original C8 is the Ultrafire, all others are clones or just similar flashlights.
About the only part of the XinTD that is the same is the 42mm lens.
Compared to other "C8" style lights, the XinTD is about .5 inch longer and heavier built. The XinTD uses a special reflector that screws into the pill which screws into the body. That results in outstanding heat sinking. The XinTD uses a top quality driver with choice of modes.
Does this light suffer with bad PWM like the UF980L?
With Nanjg 105c driver installed, you will have a hard time noticing PWM.
It´s a good one, far better driver PWM-wise than in 980L.
Thanks CheapThrills, this light is really ticking the boxes, does it tailstand?
Yes, it does.
Thanks, I have ordered one, hopefully no postage issues this time....
Hi,
Is the tailcap switch also luminous, or does it simply glow in the dark? Do you have any pics?
Thanks in advance!
GITD only.
I've read quite good things about this XinTD as also e.g. KD C8 type of light. The technical differencies are quite obvious so I tried to look for some comparison beamshots - do such exist here in BLF or somewhere else?
^ Last bump... Anyone here having both aforementioned lights and a camera in her/his possession?
No doubt for XinTD C8.
Real XM-L T6, not sure for stock C8
Better heatsink
Massive alu
I din't take pics for stock C8.
XinTD C8 & C8 warm mods with 8*7135
*** add more pics for comparison in reply#1 *** Tailcap draw from 18650 no load. Lux reading from 4 meters convert to 1 meter@ 0.25 lux. Image ISO200 1second. [image] From left to right 1. Mag2DT6 2. TrustFire TR-J12 3. UniqueFire UF-V6 4. SkyRay STL-V2 5. TrustFire X8 6. 32650 XM-L 7. Sunwayman V60C 8. DRY 9. Fenix TK35 [image] From left to right 1. UltraFire WF 502B mod wit XP-G , 4x7135 2. UltraFire WF 502B XM-L from DD 3. UniqueFire UF-A10-B XM-…
^ OK, thanks. I was not sure whether the Kaidomain version is a "stock C8" or not... I'm thinking about getting a 1x18650 XM-L light with an orange peel reflector to complement my SkyRay STL-V2.
Just got mine, it is pulling 2.78A with a HiMax 2600, and 2.75A with a cheapo unprotected Trustfire.
If it has PWM, it is very hard to see it.
This is by far the best quality torch that I have found in a Chinese light for $30 or so, and no blinkies!!! Well worth the additional price over a KD C8, it is in a different class altogether.
Woot!
