Sofirn SP10B - Impact resistance issues?
Just happened. One day it stopped working. Unscrewed the head to find the emitter off.
Take more than one light…. or get a Zebralight and drop it as much as you like
I’m impressed with Sofirn’s attention to this thread. :sunglasses:
It sounds like their light has a problem, but they are taking direct action to address it. Hopefully, they’ll figure out what is causing the problem and fix it for future manufacturing runs.
I bought an SP10A and a SP10B. They both arrived today. The SP10A failed with the same symptoms as reported in the OP. The difference is I didn’t drop it. I just swapped the AA NiMH for a 14500 and the flashlight flickered and quit. It tried to start a few times but is now inert.
I’m thinking bad switch or flaky driver. This one will be going back to Amazon for replacement.
ahh, you guys are gonna make me regret my decision to order blue sp10b :person_facepalming: i am thinking maybe better choice was to get another sf10, it is cheaper and looks more reliable…
Check to see if the emitter is attached. The head has to be removed because the spacer will hold it in place with reflector in it. Mine flickered before it died. I’m guessing cold solders.
I have a blue and a red SP10B on order, when they arive I will do some throwarounds on the oak floor and see how they fare after that.
I took my chance and I ordered 1 red and 1 blue.
The waiting process begun. :slight_smile:
I haven’t seen many complaints.
Both SP10B’s have arrived and how nice they are! :slight_smile:
But I promised a drop test, I want to know too if my units are prone to failure. With the kind assistence of my 7-year old son, here it is. I’m happy to say that although the drops did cause mode changes and switching off, both lights kept working fine.
Thanks for the test. Hardwood or laminate?
How do you like the UI Djozz?
Looks like they handled the drop test just fine. :+1:
Wow djozz. Theres got to be a few mums worried about their daughters in your area. Glad I live over here. :wink:
I LOVE IT!!!
Now THAT is the way to perform a drop test. :beer:
And, tomorrow, let us know (after 10 more drop tests) if they both survive the night :wink:
A couple days ago, only a day or two after I received it, I accidentally knocked my new Sofirn SF14 off the counter onto a bath mat. It stopped working. I ended up taking it apart and noticed that the LED was no longer attached to the MCPCB. I did a sloppy half-assed “reflow” so I could confirm that the disconnected emitter was the root cause, and not something like an inductor breaking loose. I confirmed the diagnosis, and in the process did an accidental dedome mod. I wrote sofirn via aliexpress. I haven’t heard back from them yet.
Sometime in the interim, I dropped the red SP10b I’ve had since ~December onto a harder surface. It still works fine.
5mm solid oak on top of 16mm birch plywood, so a 21mm pretty solid wooden floor :slight_smile:
The UI is quite perfect: short clicks for switching on and mode changes, slightly longer click (just right) for switching off. No memory, start in low :laughing: . Just the low mode is off, way too low. I hope with another emitter it is a bit better. (I guess the low can not be adjusted, like with the Manker UI?)
LOL, he is not into women yet, he finds the girls mostly boring and annoying. He loves Australia though, there was a nature series on Australia on TV and now he wants to go there. So beware of your daughter after all :smiling_imp:
Thanks, next is not a drop test but an emitter swap, I’m going to try that high CRI Samsung led in the red one.
If he ever comes to Australia I hope he brings his dad. :slight_smile:
I’d love to pay the Moose family and the sacked assistants a visit you if it ever comes to visiting Australia!
Great video djozz, your son did it right…. no mercy. :+1: … :wink:
I had a SP 10B emitter come off for no reason except probably cold soldered . Sofirn is very easy to deal with. Sent me a new light , reflowed the old one . Stainless steel frying pan on medium heat electric stove top burner and a little solder paste works great. Vesture of Blood video gave me confidence to do it.
