Yea, now it’s available for preorder. But i wouldn’t pay $160 if i don’t know when and if the shipping take place.
ripple testing...don't know how is realistic....
https://www.fasttech.com/products/1/10050781/9642788-chargerlab-power-z-qc3-0-usb-pd-tester-voltage
Aliexpress have a big sale, that means it is the right time to post review ideas for discounted stuff from them.
i have 93 items in my cart on aliexp and usually i buy them evaluating price fluctuation and EUR/USD forex variation.... beware that there are legit sale but many prices are also rised few days before and marked as sale when they just have the normal price, or less discount...sometimes the price is even few cents more than usual discounted price.
This is the lowest i found 38.96 on Aliexp General Sale
My 2 cents
Sound like an invitation for links (;
POWER Z USB PD Tester Voltage and Current Double Type C Instrument FL001
https://aliexpress.com/item/POWER-Z-USB-PD-Tester-Voltage-and-Current-Double-Type-C-Instrument-FL001/32821476834.html
POWER Z USB tester QC3.0/PD Digital voltmeter
https://aliexpress.com/item/POWER-Z-USB-tester-QC3-0-PD-Digital-voltmeter-amperimetro-Digital-voltage-current-amp-volt-Type/32820662689.html
POWER-Z USB PD Tester QC3.0 2.0 Charger Voltage Current Ripple Dual Type-C KM001
https://aliexpress.com/item/POWER-Z-USB-PD-Tester-QC3-0-2-0-Ladeger-t-Spannung-Stromwelligkeit-Dual-Typ-C/32845819624.html
RD UM24C USB 2.0 Color LCD Display Tester voltage current meter Voltmeter amperimetro battery charge measure cable resistance
Kotomi+Pro High Precision Color USB Current Voltage Meter Capacity Coulometers PD QC Trigger Line Resistance Test
https://aliexpress.com/item/Kotomi-Pro-High-Precision-Color-USB-Current-Voltage-Meter-Capacity-Coulometers-PD-QC-Trigger-Line-Resistance/32817004758.html
35W constant current double adjustable electronic load + QC2.0/3.0 triggers
2018 LiitoKala Lii-S1 18650 Charger battery for lipo rechargeable battery aa ni-cd 26650 AA AAA,Auto-polarity detection 5V 1A
https://aliexpress.com/item/2018-LiitoKala-Lii-S1-18650-Ladeger-t-batterie-f-r-lipo-akku-aa-ni-cd-26650/32852907697.html
Support Type c MiNi Micro usb iPhone5s/6s Lightning protocol Single wire clamp USB data transfer test board USB adapter plate
https://aliexpress.com/item/Support-Type-c-MiNi-Micro-usb-iPhone5s-6s-Lightning-protocol-Single-wire-clamp-USB-data-transfer/32687054173.html
High quality CAR USB tester voltage current capacity testing voltmeter Battery tester Monitoring Crocodile wire Alligator clips
https://aliexpress.com/item/High-quality-2016-Auto-Tester-Car-voltage-current-capacity-testing-voltmeter-Battery-tester-doctor-Monitoring/32679175674.html
USB Alligator clips Crocodile wire Male/female to USB tester Detector DC Voltage meter ammeter capacity power meter monitor, etc
1Pcs/lot High Quality 2 X 18650 Battery Holder SMD With Bronze Pins Battery Storage Box TBH-18650-2C-SMT
https://aliexpress.com/item/5Pcs-lot-18650-Battery-Holder-Battery-Storage-Box-Black-Plastic-2-x-3-7V-18650-Batteries/32370231319.html
Hello,
After the Fonken Qc3 test, there is a basic version “Smart 2.4A”
Very inexpensive 3-4 euros.
It would be interesting to have a test
Thanks
I have other Fonker chargers on the way (One review is already written) and now I have also added this to my queue.
:+1: Great Thanks
I will.
This actually looks pretty cool, I wonder if the refresh rate is high enough to properly test ripple. HKJ will you be buying this to test?
it’s looklike that, but an oscilloscope would be better to capture some peak
XTAR USB probe
“XTAR USB probe is specially designed by XTAR engineers, with good conductivity, perfectly connected to DRAGON VP4 Plus for testing voltage and internal resistance of battery”
http://www.xtar.cc/products_detail/productId=164.html
I did look a bit at them in my Dragon review. They do improve IR measurement significantly because some wire and connection resistance is eliminated, but they are not perfect. The probes for YR1030 & YR1035 eliminates all connection and contact resistance.
It only works with the VP4 Plus Dragon and HKJ already tested it here:
https://lygte-info.dk/review/Review%20Charger%20Xtar%20VP4%20Plus%20Dragon%20UK.html
How do you know they don’t work with other USB power meters?
From what I see they are just passive probes.
Yes, so they can be used with any USB Voltmeter. But only in the voltage range of the voltmeter.
Like the YZXStudio ZY1263.
https://lygte-info.dk/review/usbMeter%20YZXStudio%20ZY1263%20UK.html
