Thrunite TC20 - XHP70 - 3800lm
448 posts / 0 new
komeko
komeko's picture
beam0 wrote:
DB Custom wrote:
The UT-02 is pretty compact, nice light to be sure. Really needs a bit of current boost but thats not difficult, the hard part is not overdoing it! lol
I’d like to see a photo of a TC20 along side of UT02 for size comparison.
So fast, so the quality hmmm:
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
beam0
beam0's picture
Last seen: 1 month 4 weeks ago
Wow that was quick! Just what I wanted to see!
When I posted I was actually fishing for you to reply because I knew you had both! Smile
Thanks komeko!!
DB Custom
DB Custom's picture
Last seen: 1 day 7 hours ago
Once again, the TC20 impresses with it’s diminutive stature… serious little handful of light this one. Wink
komeko
komeko's picture
I would pay attention to words Smile because DQG 26650 fanatics will come and they will defend their baby.
DB Custom
DB Custom's picture
They are welcome to do that, of course. I have my own that I am quite fond of but it won’t replace such a light as the TC20, pretty sure.
Difficult to get a light any smaller than the DQG, to be sure, so it holds a standard of it’s very own that will probably not be equaled by anyone, much less bested.
beam0
beam0's picture
Agree. It won’t replace my TC20… But I really need to get one! Thumbs Up
Rambo007
Last seen: 2 years 5 months ago
My O rings are damaged both.I know there are 2 replacements .The only thing I did was apply CRC 2-26 to threads and changed the battery.What size O rings does TC20 use? What causes the Orings to get damaged on a new flashlight ?
Itsme
Last seen: 43 min 26 sec ago
In my experience, the only time that I have damaged an O ring was by taking a light apart while the light was very cold. This tore the O ring. I make sure to warm my lights up before I take them apart now
Rambo007
Thank you great tip @itsme
Rambo007
I emailed Thrunite and they explained 29mm*1.5mm is the size of the O-rings .They will send me a replacements.
mmalive
Last seen: 1 year 6 months ago
Nice man. Now I might just grab another CW version. BTW, what are the best MODS to do or leave “ AS IS “ ? Thanks.
Rambo007
Instead of buying another TC20 order the V6 Catapult for throw. The Nitecore NUP10 Tactical pouch will carry both for me and a Benchmade 275
SKV89
Last seen: 4 hours 13 min ago
I just cleaned the springs and battery terminals with 70% rubbing alcohol and on the same fully charged batteries, the startup brightness increased from 487 lux to 498 lux. It’s not alot but shows you how grease or other contaminants can be one of the factors for lumen variation between same batch of the same lights.
beam0
beam0's picture
I occasionally go over the contacts on my lights (lightly) with a piece of a fine Scotch Brite pad to remove the oxidation, restoring the contact surfaces to a bright color. Then I use the alcohol (91%)
I think that oxidation itself creates more resistance than the grease or oil that just the alcohol removes.
mmalive
More Throw but less lumens? About half lumens
beam0
beam0's picture
Yes but it’s actually not really a huge difference. Half the lumens doesn’t mean you’ll see half the output, just like 4000lm is not twice as bright as 2000lm. That is VERY evident using the TC20…
When going from high (1800lm) to Turbo (3800lm) theres a noticeable difference, but no where near twice as bright, and about the same difference you would see between it and the V6 Catapult.
There’s been some posts on the subject before, the “perception of luminance”
  • “it takes 4 times the lumens to see a doubling in brightness”
  • “a perceived 50% lower perceived brightness is more towards 18% of actual luminance”
http://budgetlightforum.com/node/16289
The emitters used in today’s dedicated throwers (XP-L HI, XHP35 HI) do not produce the higher lumen output of XHP50-XHP70, but the XHP50-XHP70 cannot throw as far due to their floodier beam with larger hot spot.
In fact it was the bright floody beam with limited throw of my TC20 that put me on a quest to find a good, somewhat compact size thrower: http://budgetlightforum.com/node/59699
Instead of carrying two separate lights as Rambo007 described, several manufactures have designed models that combine the two beams into a single light, Niwalker may have been first several years ago with their NOVA MM18.
The MM18 has seen upgrades to the MM18II and now the MiniMax MM18III, plus a little brother added, the MiniMax MM18JR
More recent ones currently in the works are the Astrolux MF03, and the Manker MK39 Ranger (my personal favorite)
There’s also the upcoming fan-cooled Acebeam X70
robo819
robo819's picture
Last seen: 3 days 21 hours ago
A good example of what beam0 is saying , from some of the beamshots I have already , would be the Maxtoch 2X compared to the TC20.
The 2X is making about 1460 lumens compared to the TC20 at about 3800 lumens , but the 2X will put much more light downrange than the TC20 is capable of by far. I am not saying the TC20 don’t blow the 2X away at close range , but after 175 to 200 yards then the dedicated thrower (s) leave the TC20 in the dust as far as range using much less lumens due to the focus.
The TC20 will not even come close to putting enough light on target to see 800 yards or probably even 400 yards for that matter really , as it is a much more floody beam and “wall of light” closer up.
They are just 2 totally different types of lights and light beams.
Here is an example of what I am describing with a shot from the factory Maxtoch 2X with dedomed XM-L2 U4 1A emitter at 807 yards from a barn and then that same shot enlarged and then the 2X and TC20 both at 100 yards so you can see the much more concentrated beam from the thrower compared to the TC20.
2X at 807 yards
2X Enlarged 807 yards
2× 100 yards
TC20 100 yards on Turbo
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
sp5it
sp5it's picture
Last seen: 4 hours 35 min ago
sp5it wrote:
I have a problem with turbo. All cleaned, it drops from circa 8A to 6A in 1 sec.
Problem solved, battery issue.
With Lii-50A 26650 5000mah is OK.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
sp5it
sp5it's picture
Guys, can you help me finding good bicycle mount for that flashlight?
Tia, Mike
Rambo007
Amazon upto 33cm
[2 Pack] Vonpri Flashlight Holder, Mount Bicycle Mounting Bracket Flashlight Holder Torch Clip 360º Rotation
sp5it
sp5it's picture
Thanks Rambo007.
Is there any pic how is led mounted? I wonder if mt-g2 on 20mm noctigon will fit there.
Mike
komeko
komeko's picture
Well, I could not stand it Crazy
I cut the Thrunite battery. It pissed me off that with a bigger current it gets so bad and I came to the conclusion that it is probably a security device and not the battery itself. I dumped everything and the battery itself was left. Now it’s flying like Lii-50A. At UT-02 I am 6A and TC-20 9.5A. Turbo holds over two minutes and then drops because the temperature reaches 60 degrees Celsius. You have to take into account that the ambient temperature is 30 degrees, very warm ufff. That’s how the battery lay for me because I do not have any lamp with power consumption below 5A. Now it is flying in the TC-20. Crown
sp5it
sp5it's picture
Great info. My Thrunite battery dimmed turbo after 2s. I will rip it apart Smile
Mike
Edness
Edness's picture
sp5it wrote:
Great info. My Thrunite battery dimmed turbo after 2s. I will rip it apart Smile Mike
I realized that the other night as well. I’m going to rip it apart today.
beam0
beam0's picture
sp5it, Edness… How much are your lights dimming in output? (estimate)
With the Thrunite cell mine is down about 100lm at 30 seconds compared to turn on, I didn’t record how soon the drop actually occurred after turn on, but it’s not really enough to notice visually. I’m going to do some measurements again when I have time, and also check it with a Lii-50A.
Edness
Edness's picture
For mine it was dropping out of turbo almost immediately. I thought it’s my eyes but when i meausred it with lii50a, lux meter don’t lie.
I just took the battery apart, it no longer drops out of turbo and the number matches with lii50a and efest purple.
Edness
Edness's picture
my battery has a blue wrapper under the Thrunite wrap.
JasonWW
JasonWW's picture
Last seen: 6 hours 17 min ago
100 lumen in 30 seconds is just the led heating up and is normal. The other guys are probably getting about 700 to 800 lumen drops (from 8A to 6A at battery).
sp5it
sp5it's picture
Mine dropped a lot. Was fine on LII-50a battery. Now is fine on both cells.
Mike
Newlumen
Newlumen's picture
Hey i have a thrunite tc20 and lumen tube.. i tested it shockli imr.. 3.98 v at the time of testing.
3164 lumen @ turn on
3087 lumen @ 30 seconds
9_CE6066_D-7_F2_E-4976-9142-17_EC2_F309902
