Where is the new list? Is it the post linked above?
I don’t appear to be on it… that list is missing numbers between #360 and #760. I’m # 378 on the original list, 1pc.
i hope there will be a choice of emitters or ……….
after the first run is done, do another GB with a different emitter….
after that do xhp 50 and a reflector
While I don’t know what the emitter will be, I can at least say it won’t be XHP 50. The voltage on those is too high and the driver can’t convert it. That would make this a totally different light.
How many flaslights do you want in total? Total 8 flaslight The FW3A? … Total 12 flaslight The FW3A? … Total 16 flaslight The FW3A? …
Please, say: Total .x. torch; … Total .x. units; … Total .x. flashlight.
I understand why he might feel this way. The general design and UI are established, but the specifics are still elusive. Tapered or not? Bead-blasted or “right off the lathe?” Emitters? Options? Date?
It looks like an intriguing light, if it ever happens, so I would like to express my interest in two.
However I have my doubts about the complexity and precision (and weaknesses) needed to make the co-axial tubes purely to put an e-switch in the tail, instead of a simpler side switch in the head (my preference anyway).
Discussion of the aesthetics, taperings, raw or bead blast finish seem incidental to me. I will take it, provided it is is a marvel of packaging, performance (luminous and thermal), UI (not in doubt) etc.
Then there is the question of the manufacturer, and their willingness to perform. Presumably this would be their second special, following the GT. I’d like to think they will cope better with production and distribution this time, having learned.
Still hopeful, if this comes off it could be quite special.
