Interested in TO46R depending on GB price
What is the diameter of these boards?
Interested at least for one board.
20mm.
Thank you maukka.
You can put me in the list for one board also. Together with TO46R.
Added to the list. Processed all requests up to post #130
I’m interested in either, depending on price
I’m interested in one of each light, depending on price.
Interested in the TO46R depending on price! One please.
Had some time today to tinker with the samples..
Emitter board is copper and DTP.
Dimensions 20mm dia x 1.8mm thickness.
TO10R can be "easily" modded to fit 18350:
..and the heads are interchangeable => Modded TO10R body + 18350 IMR + TO46R head = Nice pocket rocket. :)
TO10R can be “easily” modded to fit 18350
They should have done that in the factory already.
Not everyone has access to a lathe or knows how to use it……
Grtz
Nico
I agree WRT 18350. Especially since the other end of the body is already wide enough to accommodate an 18mm wide cell. With a 16340, there’s a lot of extra room.
Not everyone has access to a lathe or knows how to use it……Grtz
Nico
+1 I wish it was so easy to widen the space inside the tube
To make a 18350 fit would be a nice thing from “stock :weary:
Anyway, thanks for the inspiration and the work done withe emitters!
I will still try to use the 46R head on the 10R body :smiling_imp:
Nicolaas:TO10R can be “easily” modded to fit 18350
I fully agree. In fact, I have been trying (hard) to convince them into doing that at least for the GB lights.
So far the answer has been a firm NO, but let’s see what they say after seeing my mod.
interested in TO46R
This is the 10R body from the tail view? The tube does not separate from the head?
Can anyone confirm this mcpcb will fit my Jaxman E2L triple? I believe it’s using a Carclo lens.
(I’m okay with sanding the edges a bit if needed)
You know, I had the same Idea with my E2L’s but I think these have to be sanded to fit a E2L.
beam0 & sovereignknight
The triple noctigon also has 20mm and you need sanding. So here, too, it will be required.
I had a feeling since it’s 20mm it will fit with sanding, I was more concerned if the layout/spacing of the emitters will fit the Carclo lens. I have a feeling it will but want to make sure it’s not something else (if there is something else!)
This is the 10R body (with a 16340) looking in from the tail? So the tube I.D. is wider at the tail than it is closer the head?
