Yes that’s correct… the M25C2 Turbo is another perfect example of your description. Kind of usless with a de-domed XP-G2 in it, weak narrow maybe 800lm girly man beam, but put a de-domed SST-40 in it at 8amps….you better like a massive Blue spill. :person_facepalming:
On the lowest level the hot spot is washed out by the camera, this pic shows the corona and spill, the blue is not this intense, a bit exaggerated by the camera, but it still really blue. At this distance the hot spot is about 2.5”
The 6500k, one of 2 out of about 40 SST-40’s that I successfully de-domed. There was alot of experimentation going on too, tried different methods, fluid’s techniques, but still they kicked my ass. I hear even the Master Modder Vinh gave up de-doming the SST-40, just shaves them, I don’t blame him!
It’s actually the only emitter you would want to shift warmer when you de-dome them, but they don’t, not by my eyes. They are still too Blue for me and I’m a CW fanboy! :person_facepalming:
I have 12 of the 7500’s from Kaidomain that I was going to swap out the XML’s in my TR-J20 just to make a BLASTER out of, but I’m so disgusted with the SST-40, the 7500’s just sit. The best I can do with them is just shave them close and polish them. Ive given UP!
Still shaved and polished they work very well, home made HI if you will. Same with the XHP35HD E4 bin, if you don’t want to take the chance a fudging up or the time to totally de-dome them, why settle for an E2 make your own E4-HI.
Tnx for the tip, that will save me a lot of frustatrion. :+1:
I guess its shaving and polishing then.
My skills are not up to it but luckily I now someone from the German forum that is an expert and is willing to help me out :+1: :+1: :+1:
And I promise I won’t go any further with this off-topic issue……
They are using the same exaggerated specs as the MT35/MF02 (2,700 lumen) so you know the candela (1.46mcd) is exaggerated as well.
It looks like it’s using the same 2S2P carrier as the earlier lights which means it’s probably is using a boost driver. Maybe the same as the smaller light? I would think so.
Well……the reflector is slightly bigger, 124.1mm versus 118 as in the BLF GT.
The bigger the reflector, the more impact those few extra millimeters have on the throw capacity.
If the XHP35 HI (latest binning) is driven hard it would do around 150cd/mm2.
With a 124mm reflector the light could reach above 1.4Mcd.
And scroll down (pic nbr 3) you’ll see a schematic of the reflector indicting it is 124,1 mm on the inside.
It would also mean that it is a different reflector then the one in the BLF GT, and it looks like it when you look at the other picture (pc nbr 4) of the reflector.
Again: I’m assuming this from the pics and info available, it’s all still quite unclear.
