FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #446 by Man_Without_Shadow Post 446, page 15
Man Without Shadow
Man Without Shadow
FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #17 by Petroleum_Lantern_Gu Page 1, Post 17
FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #603 by Petroleum_Lantern_Gu Page 21, Post 603
Petroleum Lante……. ( Petroleum Lantern Guy )
If you are willing to continue, it would be very helpful.
Thanks! Updated.
I have only three names now which do not match, and one is confirmed as a deleted account.
I’m still adding the code to handle cancellations, so there are still several lines in your list which are not merged into post #4 yet.
BTW, the format I’m using is simple. One request per line, and lines are either a sign-up or a cancellation:
+ name http://link-to-signup
- name http://link-to-cancellation
A script reads this to produce the list in post #4.
Excellent, a good design decision. Looking forward to adjustable strobes!
Man Without Shadow
Thanks again! I’ve updated my list and script so it can find these two, and more generally so that it can match names which are longer than what BLF displays in the post header.
I think everyone is now accounted for.
kahvitahra:Interested +1
You are number No. 811 on: Interest list updated by pepinfaxera, View page 71, ,
FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #2127 by pepinfaxera ,How many lanterns do you want in total? . . . …x… units? .
One is fine. I thought that I had enetered this, but didn’t find my name on list. Now I see it there, thanks!
O. K.
Here I continue, I continue.
once every 7 days.
Greetings and thanks.
pepinfaxera
For now, I’m making a thing to verify each name matches someone who posted in the thread. That should help. It may also help with matching up requests to the posts where they were made.
Edit: It found 23 name errors and I fixed all but 4. I don’t see posts in this thread from:
- ManWithoutShadow
- Petroleum Lantern Guy
- Rick
- Throw me in to darkness …
It looks like the posts or accounts may have been deleted.
I think “Man Without Shadow” has spaces in between the words, if that matters Here you go http://budgetlightforum.com/user/22767
ToyKeeper:Edit: I fixed all but 4. I don’t see posts in this thread from:
- ManWithoutShadow
if that mattersHere you go http://budgetlightforum.com/user/22767
View: FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #2789 by pepinfaxera .
RobertB: ToyKeeper:Edit: I fixed all but 4. I don’t see posts in this thread from:
- ManWithoutShadow
if that mattersHere you go http://budgetlightforum.com/user/22767View: FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #2789 by pepinfaxera .
Oops, I guess I skipped through a few of the posts. Thanks
- ManWithoutShadow
- Rick
I had to add spaces to my name “Man Without Shadow”
How about a member called “- Rick -”? Without the spaces. I can’t make it any closer, or it will be Rick-crossed-out.
Reminds me of the “good” old days with DOS & SHMBO. The smallest error results in a “command unknown” respons.
Henk4U2:How about a member called “- Rick -”? Without the spaces. I can’t make it any closer, or it will be Rick-crossed-out.
Thank you!
Go to bed!
Hello! ToyKeeper, could you please add me to the list for 2 of these. Thanks!
1 please
Fritz made it, people loved it, the idea was born to make it available… first a small batch then a production run. But all along, the idea was…
“For a lot of us mere mortals, seeing the cool things machinists make on their lathe is just a dream.
Hence the finish of the FW3A will be clear anodisation, no sanding/beadblasting before anodisation.
The idea is to give all the chance to have a light looking like it came of a lathe with the protection of anodisation.”
Agreed. I will take whatever comes for $30, but my real preference is the original raw finish, showing precision manufacture. Ideally with true deep HA3 mil spec ano, greenish but un-dyed, but that could cost. Bead blast and cheap (edit) clear or dyed ano. not my thing, covers up a multitude of sins and is weak, easily scratched, best taken off and polished to bare alloy. It’s what many are used to, but the real deal is quite different.
The taper on the head looks good to me, comfortable, and maybe adds a tiny bit of extra thermal mass.
I withdraw my doubts about the thin-walled co-ax tubes (assuming a decent strong heat-treated alloy is specified), tail e-switch etc. these are what makes it special and unique. Well done Fritz. And the team.
Now Lumintop, do this justice please.
I can wait until it is right.
Im in for one of these. Seems like a neat light to add to my collection. Anduril in a nice, clean triple EDC sounds awesome.
The clear ano will be really nice too.
Looks cool! I’m in for one if not too late.
I like the bead blasted version better.
You get also a better anodisation. Without, the ano tend to chip off on sharp edges. Blasting remove burrs and rounds edges a bit. It covers also scratches.
A skilled machinist deburrs his stuff. With the automated machining stations and no blasting we maybe get sharp edges?
However the FW3A has a clear ano you wil see a worn ano barely.
