No. The small recess was already there.
Right.
Right, as long as you secure the magnet somehow.
Aluminum.
Right.
Aluminum.
This explains why the tint shift on the TO46R I measured was worse than on the TO10R and the output less than expected. The silicone dome was nowhere to be found…
The hobby is getting serious: we are getting “decapitated” LEDs :smiling_imp:
In normal conditions I assume that the values would be pretty similar between the 2 lights, right ?
The board, emitters and optics are identical so there should be no difference in the beam. Tint will always vary a bit but three emitters will probably even it out a bit. So I’d consider my TO10R tint measurements more representative of both lights.
Thanks for the explanation and tests maukka!
The thing I found most “annoying” with these LEDs was that even without the optics and lenses, there was a huge green “shift” (?) !
Hopefully that will be corrected with these new emitters
Swapping the optics to frosted Carclo should help with the XP-G3 tint shift. The clear 10507 will always show it.
..or just applying some DC-fix..
[However, I have to say that the tint shift bothers me only when hunting white walls from a short distance..]
That’s what I’ve done too, and it improved the beam a lot.
It lost some meters in distance range (mostly outside) but specially indoor, it became much better!!
Just swapped in three Samsung LH351D CRI90 4000K emitters to the TO46R. Data here.
edit: output is the same with the Samsungs, 1200 lumens.
[However, I have to say that the tint shift bothers me only when hunting white walls from a short distance…]
I suppose the shift will not bother me that much now that the snow is soon gone
Are both of these lights DD in Turbo?
Why does the 10R have only half the lumen output of the 46R?
Is it a different driver? Or because the 16340 cannot provide enough current?
I sure hope these lights don’t all have quality control issues with LEDs missing domes…
I’m interested in one of the emitter boards as well.
Different driver. Not DD.
It’s not typical for Wuben. They have had very high quality, as far as I can tell.
Good. :+1:
I’m interested in either, depending on price
The purchase period starts now!
I’ll start sending the payment instructions by PM. Sending all messages will take some time, so please be patient.
Ordered a TO46R.
Thanks for this GB ! :+1:
