Sony US18650VT3 1500mAh (Green)
Official specifications (This is for VTC3):
Nominal capacity: 1600mAh
Rated capacity: 1500mAh
Capacity at 1.5A discharge: 1425mAh
Nominal voltage: 3.7V
Charge current: 1.5A
Discharge cut-off: 2.5V
A older 18650 battery for tools.
There are two curves for all discharge currents, this must be a perfect match between the two batteries. The batteries has nearly constant discharge capacity up to 20A.
Conclusion
The battery has fairly low capacity by todays standard, but it can deliver a lot of current.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
