Group Buy: Wuben TO10R and TO46R (real 90+CRI triple XP-G3) - CLOSED!!
503 posts / 0 new
_the_
_the_'s picture
Last seen: 1 hour 3 min ago
the wrote:
maukka wrote:
beam0 wrote:
This is the 10R body (with a 16340) looking in from the tail? So the tube I.D. is wider at the tail than it is closer the head?
10R body from the head. There’s no tailcap.
Same as in my pic. Tube I.D. is wider at the head.
Actually, there’s a “tailcap”, but it’s only for removing the magnet if needed.
Here’s two pics of the tail section of TO10R, as requested.
1. Tailcap removed. It was glued and required some force to open. Note the solid end of body tube!
2. Inside of the tube with tail spring in place
=the=
_the_
_the_'s picture
MascaratumB wrote:
One question for you _ _the_ _: did your TO46R had the head glued? I asked this to other members in the review threads, and apart from 1 or 2 members that received early samples, all others were glued and hard to open...
My sample wasn't glued. On the other hand, I haven't yet seen a glued light which wouldn't open with a pair of these:
=the=
MascaratumB
MascaratumB's picture
Last seen: 52 min 33 sec ago
the wrote:
MascaratumB wrote:
One question for you _ the _: did your TO46R had the head glued? I asked this to other members in the review threads, and apart from 1 or 2 members that received early samples, all others were glued and hard to open…
My sample wasn’t glued. On the other hand, I haven’t yet seen a glued light which wouldn’t open with a pair of these:
Thanks mate Wink
I guess I’ll have to spend some in a pair of those as well… Facepalm
But…I hope my “sample” isn’t glued as well Big Smile
Thank you!!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
TheAuditor
Last seen: 2 hours 4 min ago
I am interested in one of both, depending on price.
Bonum commune communitatis.
Yarp.
d_t_a
Last seen: 6 hours 31 min ago
I’ll add 1pc emitter board (it’s in addition to my existing order of 1pc TO46R and 1pc TO10R).
_the_
_the_'s picture
There are still some TO46R left to reserve, but please note that we are approaching the 100pcs limit!
A few things to check/remember:
  1. Check that you definitely are on the list: If you got the prices by PM and didn't reply to me you are probably NOT on the list!
  2. I might have missed some post / PM => Remember the abovementioned #1
  3. I'll use message/post timestamps to judge who will get the last ones..
  4. Please show some love to TO10R as well Smile It's a great little light with a magnet on the tail. I think I love it even more than my TO46R!
=the=
MascaratumB
  1. Check that you definitely are on the list: If you got the prices by PM and didn’t reply to me you are probably NOT on the list!
  3. I’ll use message/post timestamps to judge who will get the last ones..
  4. Please show some love to TO10R as well Smile It’s a great little light with a magnet on the tail. I think I love it even more than my TO46R!
I’m on the list and received PM with the price, so everything is OK for me! Thumbs Up
I have a “request” though, about the “spare” emitters (if there will be any for sale). Earlier on the thread I mentioned I would want 1.
IF – but only IF – there are other spare emitters, I would like to add another 1 (total 2 + the TO46R I subscribed for).
Thank you Wink
beam0
beam0's picture
Last seen: 1 hour 41 min ago
So it appears you had to make a small hole through the tail?
The base of the spring appears to be about the same diameter of the tube’s I.D. at the bottom.
So It’s okay to drill through the tail as long as there is enough ledge remaining for the spring base contact area?
Is the tail cap (magnet holder) aluminum or plastic?
_the_
_the_'s picture
No. The small recess was already there.
Right.
Right, as long as you secure the magnet somehow.
Aluminum.
=the=
maukka
maukka's picture
Last seen: 1 hour 7 min ago
This explains why the tint shift on the TO46R I measured was worse than on the TO10R and the output less than expected. The silicone dome was nowhere to be found…
MascaratumB
The hobby is getting serious: we are getting “decapitated” LEDs Big Smile Evil
In normal conditions I assume that the values would be pretty similar between the 2 lights, right ?
maukka
maukka's picture
The board, emitters and optics are identical so there should be no difference in the beam. Tint will always vary a bit but three emitters will probably even it out a bit. So I’d consider my TO10R tint measurements more representative of both lights.
MascaratumB
Thanks for the explanation and tests maukka!
The thing I found most “annoying” with these LEDs was that even without the optics and lenses, there was a huge green “shift” (?) !
Hopefully that will be corrected with these new emitters Wink
maukka
maukka's picture
Swapping the optics to frosted Carclo should help with the XP-G3 tint shift. The clear 10507 will always show it.
_the_
_the_'s picture
..or just applying some DC-fix..
[However, I have to say that the tint shift bothers me only when hunting white walls from a short distance..]
=the=
MascaratumB
That’s what I’ve done too, and it improved the beam a lot.
It lost some meters in distance range (mostly outside) but specially indoor, it became much better!!
maukka
maukka's picture
Just swapped in three Samsung LH351D CRI90 4000K emitters to the TO46R. Data here.
edit: output is the same with the Samsungs, 1200 lumens.
maukka
maukka's picture
I suppose the shift will not bother me that much now that the snow is soon gone Smile
beam0
beam0's picture
Are both of these lights DD in Turbo?
Why does the 10R have only half the lumen output of the 46R?
Is it a different driver? Or because the 16340 cannot provide enough current?
sovereignknight
sovereignknight's picture
Last seen: 1 month 1 week ago
I sure hope these lights don’t all have quality control issues with LEDs missing domes..
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x2 Sk68 modded 1 Nichia 319AT, 1 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x2 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - x1 Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d - x2 Lumintop Tool AA 2.0 Ti - x1 Olight I3T EOS
jturn480
Last seen: 1 year 6 months ago
I’m interested in one of the emitter boards as well.
_the_
_the_'s picture
Different driver. Not DD.
=the=
_the_
_the_'s picture
It’s not typical for Wuben. They have had very high quality, as far as I can tell.
=the=
sovereignknight
Good. Thumbs Up
Flashlights:
fikrirah
fikrirah's picture
I’m interested in either, depending on price
_the_
_the_'s picture
The purchase period starts now!
I’ll start sending the payment instructions by PM. Sending all messages will take some time, so please be patient.
=the=
sovereignknight
Thumbs Up
Flashlights:
casi29061965
Last seen: 4 hours 25 min ago
Ordered a TO46R.
Thanks for this GB ! Thumbs Up
Mstevens113
Mstevens113's picture
Last seen: 3 weeks 2 days ago
My orders in. Fingers crossed for a quick delivery now.
toddcshoe
toddcshoe's picture
Last seen: 57 min 40 sec ago
Got my order in. Looking forward to it. Thanks the appreciate all the work.
"Everywhere I go, there I am"
