Oh, I agree that many people are far too paranoid about lithium-ion cells. But, I wouldn’t keep a cell that stays hot when it’s not being used. That is trouble.
Stick it in a metal can and let it cool down. Line the can with some plastic so it doesn’t short. When it reads close to 0 volts, throw it out or recycle it. I assume it’s an internal short, so it should discharge by itself over a few hours or days.
I wouldn’t trust Nitecore to have used only cells from quality brands. I wouldn’t trust shady chinese cell makers (there are tons of them) to produce anything that passes regulated tests.
The temperature OP describes shows either the cell or the circuit is damaged (or both). Not necessarily will this lead to a thermal rundown, but it very much increases the risk. As this produces at least poisonous fumes and fire, who wants to use this cell anymore except somebody who doesn’t care about himself or others?
And the voltage clearly is way off, so using the cell might damage anything you put it into. Why bother.
only way i can see that cell reading 9.xx v is on a harbor freight meter with a low battery.
they can be wildly inaccurate when the battery is low.
the heat is damage to the charger/protection board.
i would take it off and convert it to unprotected.
cell is likely fine.
If those measured voltages are right (9.96V, then 9.68V after a few hours means damaged cell), such cell should be disposed. I've seen cheap 4.2V cells die just by overcharging them up to ≈4.35V. It's not worth taking a risk in this case.
If the instruments you’re measuring these batteries with consistently measure other known voltages accurately; please do not sleep in a residence with this battery in it.
Easy enough to read less voltage from a battery, requires a specific circuit to put out a reading at 2X what you’re expecting.
There may be special circumstances but if the battery was “quite a bit hot as I got it out of my MH20, which btw was off and not in use for hours” there’s a problem.
I’m not sure that test indicates the cell is charged up to 20v. It may just be that they use a 20v load on it in order to force current through it to overcharge it. Can a lithium-ion cell even have a resting voltage more than about 5v?
Batteries Plus, or anyplace like that, will take the discard cells.
DO NOT toss it in the saltwater solution like Robert B said! BAD ADVICE!
I’d remove the wrapper and cut the protection circuit, see if it stays a problem with the protection circuit disabled. If it seems fine then I’d remove the protection stuff and re-wrap it, keep an eye on it in use in a regular flashlight and see how it goes.
If the resting voltage is 9.68 volts like the op stated above what use is it. If he sticks it in a flashlight it could fry his driver or give to much current from the higher voltage and go “POOF”.
I=V/R
His over twice the normal voltage. You might try removing the PCB but I don’t think the circuit can boost twice the voltage. Far as I know it’s just a simple controlled FET switch.
Not sure I’d consider Nitecore shady. Do you have evidence of any shady issues Nitecore has engaged in?
As far as that goes, it’s far more likely to be a fake Nitecore. That is, some Chinese guy is recycliing used laptop batteries and has 200,000 Nitecore wrappers to use up. Nitecore chargers have been and are being counterfeited. (see links below) The OP received it as a gift so we cannot even authenticate the purchased location.
