Interested too upon price release
天貓淘寶海外,花更少,買到寶!
天貓淘寶海外作爲面向華人的跨境電商平台,覆蓋200多個國家和地區的消費者,其中核心站點包括:中國香港、中國澳門、中國台灣、新加坡、馬來西亞、澳洲、加拿大。
Looks better than i thought.
I suspect they are using the same driver like MF02
If price is close to BGF GT then I won’t buy it.
Not worth to mod :-x
From another thread.
lusan_senna:It is come… :sunglasses:
They are using the same exaggerated specs as the MT35/MF02 (2,700 lumen) so you know the candela (1.46mcd) is exaggerated as well.
It looks like it’s using the same 2S2P carrier as the earlier lights which means it’s probably is using a boost driver. Maybe the same as the smaller light? I would think so.
Well……the reflector is slightly bigger, 124.1mm versus 118 as in the BLF GT.
The bigger the reflector, the more impact those few extra millimeters have on the throw capacity.
If the XHP35 HI (latest binning) is driven hard it would do around 150cd/mm2.
With a 124mm reflector the light could reach above 1.4Mcd.
Guess we’ll have to wait and see….
Grtz
Nico
JasonWW:From another thread.
With a 124mm reflector the light could reach above 1.4Mcd.Guess we’ll have to wait and see….
Grtz
Nico
Nico is this a fact that the inside diameter of the reflector is 124mm?
I’m as much depending on information available as the next guy but if you follow this link
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.67002e8d1d1C9a&id=56716
And scroll down (pic nbr 3) you’ll see a schematic of the reflector indicting it is 124,1 mm on the inside.
It would also mean that it is a different reflector then the one in the BLF GT, and it looks like it when you look at the other picture (pc nbr 4) of the reflector.
Again: I’m assuming this from the pics and info available, it’s all still quite unclear.
Grtz
Nico
It would also mean that it is a different reflector then the one in the BLF GT, and it looks like it when you look at the other picture (pc nbr 4) of the reflector.Again: I’m assuming this from the pics and info available, it’s all still quite unclear.
Grtz
Nico
Thank you…
If its NW or warmer i am interested
I can’t read the Chinese writing in that ad, but I think it’s safe to say it will probably have the same color temperature options as the MF02 and MT35 since they already have them in stock.
Maybe someone who can read Chinese can tell us what the ad says.
Grtz
Nico
I could not get that link to work. It seems to go to an “item not found” page. I’m not certain since I cant read the language but that is what it appeared to be.
I am interested as well. Price and tint will be a deciding factor.
If the link showing the Mateminco MT35+ is accurate, we’ll be looking at 788 Chinese Yuan which translates roughly to $125 USD. I’m totally in for that, hopefully the GB offers something similar to the MF02 price.
Nicolaas:I’m as much depending on information available as the next guy but if you follow this link
Grtz
NicoI could not get that link to work. It seems to go to an “item not found” page. I’m not certain since I cant read the language but that is what it appeared to be.
Yes, it looks like they just took that webpage down. Maybe they put it up for sale too soon?
Edit, wait, I think that link is cut short. Try this one.
Yep, Nicolaas cut it short.
here’s the comparison from the mf02 to mf04. would have liked to seen a stainless bezel on the mf04 for the extra strength, but im still impressed.
RMB788 is their preorder price for first 50 units.
td1042k:If the link showing the Mateminco MT35+ is accurate, we’ll be looking at 788 Chinese Yuan which translates roughly to $125 USD. I’m totally in for that, hopefully the GB offers something similar to the MF02 price.
What will pricing look like for the second batch? I think I’m #91 on the list
This is a big increase (since I’ve decided I’m not happy with the throw of my Mateminco MT35).
After a few updates of the list am not part of it. Please join me in the correct position.
Interested!
I’d like on the list. Thanks.
They have not decided yet but it is definitely lower than BLF GT.
freeme:RMB788 is their preorder price for first 50 units.
Do you guys prefer MF01 diamond knurling tube pattern or MF02 "chocolate bar" knurling pattern for new MF04?
