Hello my dear friends!
today i got a not deal for a great multi purpose light:
Rofis R3 only $56.99
XM-L2 U3 1250LM Magnetic Charging Adjustable-angle Head LED Flashlight Headlamp
Brand |
model = my Link |
Code (copy/paste) |
price (US$) |
Rofis |
R3 |
0cad0e |
56.99 |
Features:
-R3 is an innovative multifunctional magnetic charging LED flashlight with adjustable-angle head.
-Utilizing the XM-L2 U3 LED,it delivers the max output of 1250LM whten using 18650 Li-ion battery,compatible with 2*CR123/RCR123A battery .
-The head rotation structure combines with non-acute angle design stable and reliable,the head can rotate freely.The flashlight designs with magnetic tail cap and mental clip,it is conwenient for multifuntional use.
-With compact size.it can be used as headlamp while using with headband.
-The head and body of the R3 flashlight are connected by a stainless steel central axis,the head can be rotated and beam angle can be adjusted as well.
-The hard surface is made of aero grade aluminum alloy,premiun type III hard-anodized anti-abrasive finish.
-When R3 is used as headlamp,the user can put into silicone head caps without removing metal clip,which is easy to operate.It would work better with tail cap removed.
-According to the position of the switch and the roration direction of the head,it is recommended that the user use right hand to press the switch(Put the switch stay towards right above and rotates head into opproprate position to provide lighting).
-Angle surface with non-acute angle design,rotates smoothly;Ergonomic ratation design,one-hand operation.
-R3 comes with a detachable metal clip,combining with head rotation function,which enriches its usage scenarios.
-Powerful magnetic tail cap,can be attached to metal object,combining with head rotation,the application scenarios of R3 is greatly expended.
-With a set of high efficient constant current circuit,constant brightness,no flicker.Automatic contral of turbo mode,prevent from overheating.The built-in circuit has overdischarge function so as to take full use of battery capacity.
-The brightness range from 0.25LM~1250LM.It will meet the brightness demands in different environments.
Charging Indicator:
-Red light keeps on,means charging.
-Green light keeps on,means charging is completed.
-Red and green light blink alternately,means incorrect battery installation or no battery exists.
USB Magnetic Charging Funtion:
Parameters:Charging current:1.5A.
Charging time:about 3.5 hours.
(Note:Built-in ROFIS 18650 3400 mAh lithium-ion battery)
Battery power detection and low battery power reminder:
-Battery power detection:
After installing battery and screwing on the tail cap,R3 will automatically detects remaining battery power.
The green power indicator keeps illuminating about 2 seconds,which means that the battery power is more than 40%.
The red power indicator keeps illuminating about 2 seconds,which means that the battery power is less than 40%.
-Low battery power reminder:
With the light on,when the battery voltage is low,the red indicator will blink every second to alert user that the battery power is close to depletion and we suggest to charge battery promptly.
Package included:
1 x Rofis R3 XM-L2 U3 1250LM USB Magnetic Charging LED Flashlight Headlamp
1 x 18650 battery
1 x Headband
1 x Clip
1 x Charging cable
1 x Lanyard
2 x O-ring
