So I just picked up a Thorfire s70s…. I’ve got some shockli 26650s coming but to save a little I opted for the slow ship so they won’t be here for a while. I wanted to go ahead and test the light so I dropped 2 Panasonic NCR18650GAs in it and fired it up. Everything worked fine and I was happy. Well it wasn’t even dark out yet so all I really did was shine it around my office a little.
While I was waiting for dark I was fiddling with the light and thought I remembered reading a review that said that the square ring on the tail cap was just for using the strap (which I don’t plan to use) and to keep the light from rolling if placed on an uneven surface and that it could be removed. So I took it off to see if I preferred it like that. Later when it got dark I went to test the light and the first time or two I turned it on everything went fine. Then I noticed some issues. I thought it wouldn’t turn on and thought it must be the battery’s not making good connection (flat tops that are raised a little but not button tops). The only button top I have is a cell that was included with a task force light from tsc so I tried it in place of the rear battery. Still no luck.
I think though that when I thought the light wasn’t lighting up it was actually just in moonlight mode. The s70s has a main power button on the tail and on the side is a button that turns it on and cycles modes. You click and hold this button to go into moonlight .
Upon further inspection I noticed that without the ring on the tail the tail cap will tighten down a good ways further than with it on. Also that button-top I mentioned earlier is REALLY long. Like the longest 18650 I’ve ever seen. It’s too long to fit in one or 2 of my lights. Could I have spun the tail cap on too far and when combined with the added length of that cell squished things together too much ? Is there some other battery issue I’m missing here?
Currently the light acts really weird. Like if I leave it alone without batteries for a few hours I can drop two in there and the light will act normal the first time I try it. But if I turn it on it may work the second time or it may go into strobe ( achieved by double clicking side switch after tail switch Is clicked ) the third time I turn it off and back on it may strobe or it may go into moonlight (as if I had pressed and held the side switch. Pretty much after the third or fourth attempt the only thing it will do is immediately go into moonlight.
Here’s the weird part. If I remove the cells and walk away from it for a few hours and come back, it will work the first time or 2.
Do what do y’all think? Is their just something defective in the light ? Or did I mess it up with the long cell and over screw ? Or are my batteries just not powerful enough to push the light ?
